Question about Hot Spring Spas Iq 2020 Circuit/motherboard - 77087
HOT SPRINGS IQ SPA shutting off sporatically
I have a Hot Springs IQ (2000) spa. The circ pump and heater don't work consistently. There are two circuit breakers connected -- one a 30 amp which controls the main controls for jets, setting temp, lights, etc., and a 20 amp that I think controls the circ pump. For some reason the 30 amp keeps shutting off, although the circuit breaker switch is not tripped. However, when I switch the 30 amp and the 20 off, and switch back on with 30 amp first and then 20 amp, it works for a while. According to the technician, which seems to make sense to me, the circ pump and heater are fine. Likewise the other functions -- when they have power. So it seems to be one of a couple of possible things: (a) something is shutting off the power on the higher amp power feed (30 amp -- which controls the jets, etc.), but I'm not finding what that problem is, or (b) the circuit board has a problem where it works temporarily -- anywhere from a minute or two up to an hour or two. I've had a couple of technicians -- the first said it was was the circ pump that was bad and not getting enough flow. But the second, who was prepared to replace the circ pump, said that was fine, along with the heater. But when the 30 amp shut down after he left, he came back and didn't know what the problem was. He called someone else (a friend) who just guessed, that it was the black circuit box -- part number 71485, Watkins IQ2000. However, due to the expense and uncertainty if this is actually the problem, I'd like to find out if there is a way to be more certain before spending close to $1000 to "try" the whole panel replacement to see if that's the problem. The confusing thing for me, which I don't understand, is why / how I can lose power on that 30 amp power supply, but yet it doesn't trip anything. I'm think perhaps the GFI on that breaker switch might be going bad. But typically with a GFI breaker problem, wouldn't I need to push the white reset switch to re-engage the GFI function? As is, all I do to make it work again is simply turn off the main breaker switch on the 30 amp, and also on the 20 amp, switch back on the 30 amp breaker switch and then switch back on the 20 amp breaker switch, and things work again. Sorry if I sound stupid -- maybe I am. :-) I'm not a pro and while I have some basic understanding, I'm lost and would appreciate any help. THANK YOU!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Could be as simple as turning off "Summer Mode" that should only be used in very hot climates.
Hold both temp buttons (+ -) in until icon on display is gone.
Posted on Feb 22, 2015
On leisurerite spa pool what does code 1-3 mean
If your system is equipped with a circ pump, it may be configured to work in one of three different ways: 1)
The circ pump operates continuously (24 hours) with the exception of turning off for 30 minutes at a time
when the water temperature reaches 3°F (1.5°C) above the set temperature (most likely to happen in very
hot climates). 2) The circ pump stays on continuously, regardless of water temperature. 3) The circ pump
will come on when the system is checking temperature (polling), during filter cycles, during freeze
conditions, or when the blower or another pump is on.
Dec 06, 2016 | Pool & Spa
Invensys 100-1292-00
try disconnecting the heater leads sounds like heater element is shorted
Aug 17, 2014 | Pool & Spa
Wiring diagram for Hot Springs serial# I-341733
attatch to frame of control box
Jul 13, 2014 | Pool & Spa
Circulation pump won't run
Dec 05, 2013 | Hot Spring Spas Iq 2020...
Have a sovereign hot springs spa purchased in 2000. When turning the jets on it kicks the breaker. Also, the inside control system is not working anymore. Could our friendly electrician do this easily,...
When spas turn on initially they run through a purge cycle. This when the pump runs for a few minutes to remove any air in the heating system so the heater does not dry fire.
If your system runs through the start up cycle just fine but kicks the breaker when the heater starts then the heating element is bad and needs to be replaced.
Rod
US Parts Center
888-521-6183
Mar 18, 2013 | Pool & Spa
Hot tub heating is working but pump has stopped
you may have a system that uses a small circulating pump that circulates the water thru the heater to keep water temp at proper level (this is usually the case with hot springs spas and is because it is the most cost effective way to maintain constant water heat without using a full size pump or two speed pump just to push water past the heater core. therefore the issue is you have a problem with your jet pump and it has nothing to do with the circulating and heating portion of the spa. you can check to see if there are any reset buttons in or near the equipment as well as open enclosures to make sure everything is clean and dry also make use any contacts on spa skirting are secured propertly
Apr 24, 2010 | Pool & Spa
Jet pump will not shutt off after I replaced heater relay. Tub is a hot springs landmark with an IQ2000 panel the year is also a 2000
it sounds like the pump relay may be stuck closed. Also check the temp readout, if it thinks the water is too hot it will try to cool the water by running the jets and sometimes the blower as well.
Dec 08, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
No jet flow hot springs highlife 1990
you might have an air lock, when you first start filling the spa, start the water running in the skimmer first. that should force air out of the pump and should pick up prime right away. if not, you may have a valve problem.
Mar 30, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Hot Spring Spas Iq 2020 Circuit/motherboard - 77087 Logo
1,181 people viewed this question
Top Hot Spring Spas Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Hot Spring Spas Winter Sport Expert? Answer questions, earn points and help others
