Question about Lexmark Office Equipment & Supplies
Lexmark Interact S605 - Error: 0x0000070c
Slow printing over Wifi. Nothing is using bandwith. Printing used to be fast but slowed down significantly. Getting Error 0x0000075c. Need a printer expert
onlynisar
  • 40 Answers
SOURCE: Printing is very slow
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
WOW
LPT_Timeout
WARNING: Using REGEDT32 can cause serious damage to your operating system. Make sure to follow these steps exactly.
  1. On the Windows 2000 or Windows XP machine where the printer is connected, click Start -> Run and type REGEDT32
  2. Bring up HKEY_LOCAL_MACHINE on Local Machine
  3. In the header, click View and make sure to check "Tree and data"
  4. In the left hand pane, expand System -> CurrentControlSet -> Control -> WOW
  5. In the right pane should be a key "LPT_timeout". Double click this key
  6. A prompt for a string with a default of "15" (seconds) will appear. Change this to 3 and click OK.
Then restart Pc
Posted on Dec 08, 2007
SOURCE: laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
Posted on Nov 12, 2008
  • 14 Answers
SOURCE: Lexmark T642 Slow Slow Printing
I've had this problem with the Lexmarks's T640 printers connected via USB to Mac OS 10.5.5 machines.
Problem: The Mac OS' default resolution of 1200 DPI for this printer causes the printer to have to rasterize the print job again AFTER it arrives at the printer. The printer does a painfully slow job of this.
Solution: Change the default resolution of your print jobs to "600dpi".
Instructions:
1.)Call up the printer settings menu by starting a print job and clicking the up-arrow next to "Printer" box.
2.)Click on the drop-down list with the name of your application and choose "Printer Features".
Change your resolution to "600dpi". Oddly, I find that "1200dpi Image Quality" is almost as fast.
3.)It might be a good idea to "Save as" this new configuration in the "Presets" menu at the top of your list.
You should notice a tenfold increase in the time it takes the printer to actually produce print jobs now.
Additionally, in the "Color Matching" settings (you can get there by changing from the "Printer Features" settings), be sure that you are using "ColorSync" so your printer isn't having to do any additional processing in that area.
Posted on Dec 16, 2008
darkoh69
  • 77 Answers
SOURCE: SLOW, SLOW PRINTING
try saving the things you want to print as a pdf file, then print them from there
Posted on Jun 01, 2009
  • 21 Answers
SOURCE: HP Laser Jet P3005 Printer is printing very slow
It is usually dirty and old fuser. It would takes longer time to heat up and also triggering error messages. Try changing that.
Posted on May 09, 2010
Lexmart s605 printing grey and black squares
It sounds like a problem with the printhead. If your printer is still under warranty, please contact our technical support team to have the printhead replaced. You can find the contact details at support.lexmark.com.
If it's already out of warranty, you can purchase a printhead here: http://bit.ly/IZYhWo
Dec 03, 2012 | Lexmark "interact s605 wireless all-in-one...
I have a lexmark interact s605 and it wont feed the paper
First, try to unplug the power of the printer for about 30 seconds then plug it back in.
Second, update the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
Third, make sure that the paper is properly placed in the tray and the paper guides is set.
Nov 18, 2012 | Lexmark Interact S605 All-in-One Color...
LEXMARK INTERACT S605 WON'T PRINT COLOUR
Try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
If the firmware update doesn't help, perform a maintenance on the cartridges. Do to that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
Also, make sure to use genuine Lexmark cartridges.
If the steps above doesn't help, the printhead might need to be replaced. Please contact our tech support team if your printer is still under warranty. If not, you can purchase a printhead here: http://bit.ly/IZYhWo
Nov 07, 2012 | Lexmark Interact S605 All-in-One Color...
Interact s605 printing upside down
You can change the settings under printing preferences, just follow the steps below:
1 With a document open, click File > Print.
2 Click Properties, Preferences, Options, or Setup.
3 Navigate to:
Advanced tab > 2-Sided Printing area > select On
Note: To use the settings defined in the printer, select Use Printer Settings.
4 Select either the Side Flip or Top Flip option. Side Flip is the setting most often used.
5 Click OK to close any printer software dialogs.
6 Click OK or Print.
To return to single-sided printing, navigate to:
Advanced tab > 2-Sided Printing area > select Off
Sep 01, 2012 | Lexmark Interact S605 Wireless All-in-One...
There is a problem communicating with the printer
Please download the firmware update from the Lexmark website www.lexmark .com and install the patch http://bit.ly/pWGkeE after updating.
Jul 12, 2012 | Lexmark Interact S605 All-in-One Color...
Lexmark S605 printing blue streaks
If you're still having problem with the printer, please contact us at LxkListens@Lexmark.com or http://bit.ly/boldchat.
May 11, 2012 | Lexmark Interact S605 Wireless All-in-One...
Lexmark s605 will not print in colour
Try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H. Also, perform a maintenance on the cartridges, to do that, on the control panel of your printer, press on the Ink Levels > More Options > Deep Clean Printhead.
Make sure that you're using genuine Lexmark cartridges.
Apr 28, 2012 | Lexmark Interact S605 Wireless All-in-One...
Lexmark interact S605 has document blocking any further printing and even when I have unblocked previously the next document still blocks
If you're having problem with print jobs getting stuck in the print queue, it could be due to your computer's print spooler service not running. Try the steps below to fix the problem:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Feb 09, 2012 | Lexmark Interact S605 All-in-One Color...
S605 ink printing patchy
A firmware update for your model addresses print quality issues. Please visit the Lexmark website to download and install the Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
Try to print again to verify that the print quality has improved.
Should the problem continue, it could be that the printhead itself is the problem. Please contact Lexmark Technical Support Center for assistance.
Feb 04, 2012 | Lexmark Interact S605 All-in-One Color...
103 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
