Question about Equator EZ 3600 CEE Front Load Washer / Dryer
Equator ez3600 CEE Dispensing Tray water
I was wondering why my detergent dispensing tray often fills up with water?
3 Suggested Answers
ngafm
  • 166 Answers
SOURCE: Looking at purchasing a uses
Friend,
ngafm at your service!
Discount Parts
Major Appliance
& Consumer Electronic Parts.
TOLL FREE 1-(888)-338-3790
8:00AM - 12:00 MIDNIGHT
7- DAYS A WEEK
Bless you
Please give me a good rating before you sign off !
Posted on Sep 05, 2008
SOURCE: cold water valve
Hi Yes I fixed it myself! lol I just tried every combo of wires that there was, and it is working gr8! Ty so much though, for having a site like this! I even called the Equator company and they could.n't tell me! Again it is fixed and thank so much! Rose
Posted on Apr 02, 2009
Detergent dispenser
You can drain the detergent tray and clean the tray specially the area where the dispensing nozzle is place, use a air pressure or a jet wash, which must clear the fault as it can be due to dirt accumulation..
Jul 11, 2013 | Washing Machines
Fabric tray does not clear
Usually means soap dispensing drawer needs to be cleaned, as conditioner is dispensed by syphoning system, Take out soap detergent drawer, clean thoroughly in warm water, make sure drain hole in conditioner compartment is clear.
Nov 20, 2011 | Washing Machines
I need a drive belt for a Ez3600 C
You can get the belt from Appliance Desk, their number is 800-490-8018
Let me know if you are able to get the belt.
Mar 12, 2010 | Equator EZ 3600 CEE Front Load Washer /...
Fridgidaire front load will not empty fabric
Hello, W/D here.
There are a couple of reasons why the fabric softener will not dispense. If everything else dispenses properly (detergent and bleach), then I would suspect a bit of plugging. If the softener remains in the dispenser, the water valve above the tray may be sticking. You'll have to get the top up to check it. If there is water in the tray, or some water/softener, then you'll need to look at the overflow cap. Here's how that works: Your dispensing trays for bleach and softener have a raised tube built into them, and each is covered with a loose fitting cap. When water is let into the tray, the level rises under the cap until it overflows, creating a syphon. The softener is literally pulled from the tray, and chased by the water. When the water stops, the tray level continues to drop, until air gets into the cap, breaking the syphon. The cap can be removed and cleaned. Sometimes the tray has to be removed first. Theres a catch towards the rear of the tray.
Best regards, W/D
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Bleach & Softner not dispensing correctly
I finally figured mine out! Remove the dispensing tray then take a small brush, or maybe a q-tip and clean out the small hole right above the softener tray. Mine had mold in it and wouldn't let the water fill the tray, which is what causes the softener to dispense!
Jul 21, 2009 | Whirlpool Washing Machines
Where does the detergent go on the ez3701cee, in compartment A or C?
Detergent Dispenser
The detergent dispenser has 3 compartments,
marked A, B, and C.
A. Pre-wash detergent
B. Wash Detergent, Bleach (e.g. Clorox®)
C. Fabric softener (e.g. Downey®)
Note: The Bleach must be filled into “B”
compartment.
Jul 07, 2009 | Equator EZ 3710 CEE / W Ventless...
Cold water valve
Apr 01, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Hi i ahve an equator ez3600 washer dryer unit
It may have been leaking from the drain pump and you may want to check if it the drain pump by opening the back panel and checking if it leaks just when the drain pump starts to function.
Feb 27, 2009 | Equator EZ 3600 CEE Front Load Washer /...
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bleach dispener always full of water
call for service, they will probably order the dispenser assembly (includes new drawer.)
Apr 23, 2008 | LG WM2455 Front Load Washer
Equator EZ 3600 CEE Front Load Washer / Dryer Logo
54 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
