Question about Lenovo IdeaCentre K320 - 30192PU (Black) - Intel Core i7-870 ( 2.93GHz 1333MHz 8MB ) PC Desktop
4 BEEPS THE COMPUTER DOESN'T START IT JUST KEEPS REPEATING FOUR BEEPS
    Brigadier General:
  • Lenovo Master
  • 3,400 Answers
The Computer won't get to the Desktop Screen. It stops the process of logging in at a screen that shows a loading bar that keeps repeating.
You will need to either, re install the operating system or do a system restore. The latter is available on the F8 screen (press at computer start.)
Aug 16, 2013 | Computers & Internet
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Product Name : Intel Motherboard Dg31gl Type : Mother Board Problem : 3 beeps continously then space then sham four then space again space again its repeating d same give me any solution
Replace the processor. The 3 beeps means its the processor at fault..
continuous beeps with space in between means its the rams.. No beeps at all means its the clock speed.
from what your saying it sounds like the processor.
Dec 28, 2012 | Computers & Internet
Memory upgrade on gx280 beeps on boot but doesn't start. memory beeps 1 234 5 6
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer. The other issue is if that model supports 4 gig memory.
Aug 30, 2012 | Dell Computers & Internet
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
The r is repeating
Seems like there's some dirt in there. Try one of those compressed air in the can specifically designed for cleaning computer keys. If that doesn't work, you'll need to take the key out. By the way, the "r" didn't repeat in your post!
Jan 30, 2012 | HP Computers & Internet
Winwos doesn load freezes
how many beeps... what kind of pc? below is the standard beeps codes with the the issue.
Standard Original IBM POST Error Codes 1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Jun 18, 2010 | Western Digital My Book Home Edition 500...
At start up, before windows loads, a consistent series of annoying beeping occurs....
If they're occurring right as you turn the computer on, it's your Power On Self Test (aka POST) letting you know. Since I can't be more specific, here's a synopsis of POST beeps:
One single beep followed by three, four, or five beeps -- System-board problems, possibly with DMA, CMOS setup chip, timer, or system bus. The computer usually won't boot when this is the problem.
Two beeps -- The POST numeric code is displayed on the monitor, usually nothing to be concerned about, but you might google the code on another computer and see what you get.
Two beeps followed be three, four, or five beeps -- First 64K of RAM has errors. Solution is to replace RAM.
Three beeps followed by three, four, or five beeps -- Keyboard controller failed or video controller failed. Either you won't be able to see or type with this error.
Four beeps followed by three, four, or five beeps -- Problem with serial or parallel ports, system timer, or time of day. Check your BIOS settings (usually F2 at start up) to make sure everything is correct.
Continuous beeps - problem with power supply. Probably won't do much with this error. At the very best, your computer will boot and run very, very slowly.
Hope that helped.
Sep 01, 2009 | Compaq Computers & Internet
Atx12v1 cable
The repeating single beep with a small pause (actually 3 Beeps a Pause) clearly indicates problems with RAM .Replace it ,your problem will be solved . As for connecting the 12 volt 4 pin connector all mobos are designed to sense the presence of this 12 volts and ONLY THEN TURN ON.
May 02, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
Lenovo IdeaCentre K320 - 30192PU (Black) - Intel Core i7-870 ( 2.93GHz 1333MHz 8MB ) PC Desktop Logo
65 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
