Question about LG Electronics Kompressor Pet Care Upright Vacuum Cleaner LUV200R
Suction vacuum does not have suction and the brushes do not turn
  • LG Master
  • 17,328 Answers
If the motor comes on then either the shaft connection at the fan is loose or the belt to the beater bar is bad.
Posted on Jul 14, 2013
Need Kirby Generation 3 Vacuum cleaner manual. Vacuum is not picking up dirt from floor. Seems to have enough suction to inflate the bag, but when you check the suction under the vacuum, there seems to...
If your brush roll is turning and your bag is not overly full, then the only other thing it can be is a clog where the bag connects to the vacuum. Turn the plastic part out away from vacuum and lift off to see if you have something clogging it. It would have to be something big, but not so big that it could not get past the fan. As a rule of thumb, KIRBY never clogs. I suspect that your belt is stretched out and your brush roll is not turning while on the carpet so the brush roll is just in the way rather than brushing your carpet to pick up dirt.
Jun 08, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Vacuum brushes won't turn. It still has suction.
That means that you need to replace the belt that turns the roller brush. They naturally stretch and wear and you should replace this belt yearly. Here is the belt you need and the manual which has instructions on how to change it:
Dyson DC07 Belt and Manual
Dec 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Brush turns....suction low! Attachement works, no
Check for a blockage between brush and entry into dust chamber, if something has not made it's way to the dust chamber could result in low suction1
Dec 08, 2009 | Dyson DC14 All floors Bagless Upright...
Brush not turning and vacuum not suctioning
it probably needs a new bag or could be clogged.
Jun 29, 2009 | Eureka Capture Upright Vacuum Vacuum
Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
May 03, 2009 | Dirt Devil SwivelGlide Bagged Upright...
MY BISSELL PROHEAT WONT SUCTION
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ffuutr
Jan 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brush and belt no longer rotating
you probablly need a new belt clutch it should go to a vac shop it isnt an easy fix
Sep 14, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Suction?
You won't feel a great deal of suction like you tried to do it. But look at the fan, if it isn't worn down, and the bag fills with air when you turn it on, then the suction should be ok. If you haven't changed your belt in awhile, I am sure that it is stretched and is having trouble turning the brush roll.
May 20, 2008 | Kirby Ultimate G Bagged Upright Vacuum
LG Electronics Kompressor Pet Care Upright Vacuum Cleaner LUV200R Logo
93 people viewed this question
Top LG Vacuums Experts
Think Crucial
Think Crucial
Tim Venetis
Colin Stickland
Colin Stickland
Are you a LG Vacuum Expert? Answer questions, earn points and help others
