Question about Kenwood Ddx719 Dvd Cd Mp3 Ipod Iphone Bluetooth Receiver Pandora Car Player
Miswiring dc offset error
Went to work stereo was fine. Left work and "Miswiring DC Offset Error" on bottom of screen. What happened? How do I fix?
Miswiring dc offset error comes on my radio and it wont play
That means a speaker is shorted or the wire for the speaker has come in contact with the chassis of the vehicle.
Feb 26, 2016 | Car Audio & Video
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
How to resolve miswiring problem on jvc steeo car
MIS WIRING" is displayed when there is a DC offset voltage detected at the speaker terminals ('+' and '-').
This is normally caused by connecting a '+' or '-' speaker wire to either GND or Vcc (+12V)
1. Collect cable not being used and make sure they are tapped off and reset
2. Remove a connected cable one at a time and press RESET
3. If after a cable removal and reset the error goes away, last cable removed was fault. Examine cable for short.
4. If you remove and reset all cables except for (RED, YELLOW, and BLACK) and you stilll have error, the short is internal of unit and requires service
Aug 04, 2014 | JVC KD-R530 In Dash Stereo
Jvc car stereo warning wiring chk then reset unit
MISWIRING OR CHKWIRING is displayed when there is a DC offset voltage detected at the speaker terminals ('+' and '-').
This is normally caused by connecting a '+' or '-' speaker wire to either GND or Vcc (+12V).
Apr 18, 2014 | JVC AM FM CD DET FACE CAR STEREO
Miswiring dc offset
Saying miswiring dc offset error i unplug batt radio works for a sec till i turn up then comes back on
Jul 12, 2013 | Kenwood Ddx719 Dvd Cd Mp3 Ipod Iphone...
65a Resolv studio monitors. The left one just blew out -- maybe. The blue LED stays dim, as though the monitor has been sleeping. When I power off the monitor, the speaker gives a loud pop, and the cone...
You are getting DC offset voltage on one of your amplifiers that is the reason the speaker pushes out and you might be hearing a humming noise too. Do not turn on the speakers till you get it fixed or else you would end up burning the speaker voice coil too.The dim blue LED is also an indication of a short circuit in the output stage.
Your left amplifier needs a output chip (IC ) replacement. You will need professional help to do that. Will cost you about 20$ plus service charges.
Jun 27, 2011 | Samson Resolv 65a Main / Stereo Speaker
BENQ E610 camera, system error 0010
Dear Sir,
System error 0010 on BenQ E610 means that lens inside the camera is offset against axis.Solution 1) You can send this camera into the BenQ service for new lens change.As this camera is pretty old it is not economical effective.Solution 2) Or you can try to punch the camera to the bottom.Sometimes this fix process can help and return lens to the correct possition.But as i wrote this is not 100% fix process.
Best Regards
AIOS
Mar 26, 2010 | BenQ DC E610 Digital Camera
Sony car stereo
When the amplifier shows an offset fault, it's generally because there is DC voltage present on the speaker terminals. The amp has shut down to protect the speakers.
Aug 14, 2008 | Sony XM-754HX Car Audio Amplifier
Kenwood Ddx719 Dvd Cd Mp3 Ipod Iphone Bluetooth Receiver Pandora Car Player Logo
870 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
