Question about Toshiba 2830c,estudio,color Copier,print,color Scan, Usb,scan To Email,11x17
2830c c580 just purchased a new (used) Toshiba 2830c to replace existing one (dead). Connecting saddle-stitch finisher from old one to new one, but getting "Call for Service" error code c580. That's a communication error b/t the copier and the finisher. Can I fix it with an 0,8 1912 code, or is there another fix?
  • 31 Answers
SOURCE: Toshiba e-Studio 350 FAX Communication error
Are you still receiving faxes although you are unable to send? Or is it no send & no receive? When you hook a phone up are you able to connect with a # dialed from that phone. It's possible that the problem is the copiers NCU board- but it's rare that they fail & even more rare that it loses just the send portion. You'll want to be absolutly sure that it's not the phone line. If you are positive that the problem is not the phone line - try turning the machine off & unplugging the power cord for 30 minutes. Occasionally the NCU card will lock up & not function properly. Unplugging the machine for 30 minutes has worked for me in the past.
Posted on Mar 29, 2007
  • 643 Answers
SOURCE: Toshiba estudio35 trouble code
U need to update firmwares, if failed. then probably need to change board...
Posted on Sep 17, 2009
  • 1126 Answers
SOURCE: What type of staples should I use in my Toshiba
Staple 700.
Posted on Nov 06, 2009
  • 59 Answers
SOURCE: I have a Toshiba e-studio 150 copier. L-1 error code flashing
hi there is problem L-1 means that u have problem CCD MCU Harness Disconnect
Posted on May 12, 2010
  • 7 Answers
SOURCE: how do i fix error code f100 1 for toshiba e studio 2040c?
F101 HDD failure,,08-9030..or update the firmware version.if not okey replace the HDD.
Posted on Mar 29, 2013
How do i print envelopes with toshiba 2830c?
according to other forums and blogs, they say it is a pain to do on the 2830c and that you would have to sit and baby sit it, newer printers were being recommended for this task.
press the helpful button
Feb 04, 2016 | Toshiba Office Equipment & Supplies
E-studio 550 says to close saddle stich. What is the saddle stich?
This is on your finisher it is a accessory that someone had to purchase with the copier. Saddle stitch is how you make books and the staples go a certain way, it is a fancy stapler device that has a door to remove jams an d such. on that access door is a hidden microswitch that tells the copier if its safe to run paper through there or not. If posted on Aug 7 you either found out by exploring, had a service call to correct it or disconnected a really expensive finisher from your copier..... ~~~~> SC
Aug 07, 2014 | Toshiba BR ESTUDIO 550 - 1-SD YLD BLACK...
I have a toshiba e studio 3510c that is getting a c580 code. any ideas on how to resolve this issue or what may be causing this to happen?
[C580] Communication error between IPC board and finisher
(1) Check if the specified finisher is attached.
(2) Check if the harness connecting the IPC board and the finisher controller PC board is disconnected
or open circuited.
(3) Check if the conductor pattern on the IPC board is short circuited or open circuited.
(4) Check if the conductor pattern on the finisher controller PC board is short circuited or open circuited.
(5) Replace the IPC board.
(6) Replace the finisher controller PC board.
May 27, 2011 | Toshiba E-Studio 3511 Color Copier
When I try to copy the screen says ready (saddle stitch tray full). And nothing happens. What's my next move?
The saddle stitch tray is full, you need to remove the copies that were made for it to restart printing the rest of the job. Hope this helps.
Nov 29, 2010 | Toshiba Saddle-Stitch Finisher Copier
There is line coming on a print page
clean the glass which is under the document feeder
Nov 23, 2009 | Toshiba Saddle-Stitch Finisher Copier
Toshib E-450 fax confirmation.
Press the user functions button on control panel
Press Admin button and key in password and then ENTER
press the LIST/REPORT button
press report settings
press COMM.REPORT button
then press desired butons for each item
press enter
hope this helps!
C
Aug 22, 2008 | Toshiba Saddle-Stitch Finisher Copier
Toshiba 2830c,estudio,color Copier,print,color Scan, Usb,scan To Email,11x17 Logo
49 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
