Question about Panasonic NV-GS17 Mini DV Digital Camcorder
When a fully charged battery or even when plugged in from the mains the camera will not switch on nor will it release the tape. Please HELP!!!
  • beatjunky101 Jul 24, 2008
    I'm having the same issue with my NV-gs15. Battery is fully charged but unit will not power up.
    I borrowed it from my mate....which makes things even worse
  • jonopoly Aug 09, 2008
    i am having the same problem too. i was working fine a few days ago too, all of a sudden it wont do anything.
I have the same problem . it sometimes comes on and just suddenly stops working . won't turn on whatever you do . and after a few days works again and it happens again . i love this cam and want to fix it .
Posted on Aug 25, 2008
My Sanyo VPC-T1496R camera is dead. What is wrong?
It depends on what type of battery it uses. Some batteries once they have fully discharged are not able to recharge
Aug 20, 2015 | Sanyo Cameras
Try non-rechargeable batteries, and try testing your rechargeable batteries because they do wear out.
Sep 19, 2014 | Cameras
Nikon cool pics totally dead
The battery is most probably defect. and then,
The manual says:
Battery is exhausted.
When connecting to an electrical outlet using a Charging AC Adapter, the camera cannot be turned on.
  • Confirm all connections.
  • Off is selected for Charge by computer in the setup menu.
  • When charging by connecting the camera to a computer, battery charging stops when the camera is turned off.
  • When charging by connecting the camera to a computer, battery charging stops if the computer is suspended (sleeping), and the camera may turn off.
  • Depending upon computer specifications, settings, and status, it may be impossible to charge the battery inserted into the camera via computer connection.
So even when you think the battery is charged, it still can be empty. When a rechargeable battery is old, or not often used, it can lose its capacity, not being able to power the equipment it was meant for correctly.
To make sure your battery is good, you could try to check the voltage with a multi meter. The voltage should be slightly higher than the 3,6 Volt that is printed on the battery. like 3,8 Volt, when measured. if it is just a fraction lower than the 3,6 is is not fully charged and it will be much lower when put in a camera, after switching on the camera. When you measure 2,4 Volt, 1,2 Volt or even nothing you can be sure the battery is dead.
Best option then, would be to order a new battery. But if you know someone with a camera that has the same battery that works, ask if you can check your camera still works with a battery that is ok. because when in a rear situation it is you camera that is defective, you can save the mont for a new battery and look out for a new camera, because the batteries are not cheap.
Nov 12, 2013 | Nikon Coolpix S3300
The phone has been dead for more than a year
You cannot usually charge a totally flat battery from the USB port. These are only used to "Top UP" the battery... You need to replace it with a fully charged one,and then us the USB to keep it fully charged.
Jan 29, 2010 | Sony Cyber-shot DSC-T20 Digital Camera
Creative ZEN (4GB) not turning on (battery fully charged)
I had the same problem but it powered up after I removed the cover and wiggled the battery.
I hope this helps.
May 28, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
The computer will only run from a fully charged battery.
the problem clearly shows the fault is in the motherboard
Apr 10, 2009 | Toshiba Qosmio G35-AV650 Notebook
I have a ex-z77 it is just under 1 year old the camera does not switch on even after the battery has been on charge. when the battery is charging the charger light flashes, im sure the light used to stay...
Your battery will no longer take a charge. Replace the battery with a new one. Your computer probably does not supply the power to the camera. You need a fully charged battery in the camera to view or transfer photos onto your computer.
Nov 10, 2008 | Casio Cameras
Canon 400d will not switch on
it might be a problem with the battery connectors.
They might not touch the battery well.
another reason, it might be the battery is dead or the power button is not working.
Aug 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Dead batteries when fully charged
Does it work with "no batteries" - only plugged into power source? check your usb cable by trying to power up something else.
Jun 28, 2008 | Fuji FinePix S7000 Digital Camera
Panasonic NV-GS17 Mini DV Digital Camcorder Logo
113 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
