Question about Vacuums
Cd rom drive is not responding to a cd - Vacuums
  • Vacuums Master
  • 17,326 Answers
Try a factory cd if it is not seeing a
home made one. If it wont see a factory one, the laser might have failed.
Posted on Jul 14, 2013
How do I get my sat box to respond to remote control
First, check whether you have the correct remote control for the box, then make sure the battery is good and properly installed. Also, verify that the remote control pickup window on the box is clean and is not covered with a sticker,
Sep 21, 2014 | Vacuums
Does not respond. Stopped working in the middle of vacuuming the couch. Notting seemed stuck in there. The reset botton does not respond
If the motor is still hot the reset button will not respond. Let it cool for maybe 30 minutes. Then press it.
May 25, 2011 | Miele Revolution 600 Bagged Canister...
I bought my dvd player from Malaysia but I am using it in Middle East where I am currently residing. Initially, we are able to play all dvds (which we bought original) but suddenly, it kept popping a...
Are you using WMP or any third party players to play the dvds ?
I suggest you to check if the DVD region code is set to one (US) or not. If not, change it to one.
The region can only be changed five times, before its set permanently.
How do I change my DVD region?
DVD movies are encoded for different world regions, and your DVD-ROM drive must be configured for the appropriate region in order to play the DVD.
If you have DVD-decoder software installed on your computer, you can usually change the DVD region setting in the DVD decoder program. Follow the instructions in the program's Help file for changing the DVD region setting.
If you have a software or a hardware DVD decoder installed on your computer, you can use Device Manager to change the DVD region setting in your DVD-ROM configuration:
1. Click Start, right-click My Computer, and then click Properties.
2. On the Hardware tab, click Device Manager.
3. In the list of devices, double-click DVD/CD-ROM drives, right-click the DVD drive for which you want to change region settings, and then click Properties.
4. On the DVD Region tab, make the desired changes.
You must be logged on as an administrator or be a member of the Administrators group in order to change the DVD region.
Note that the DVD region for most DVD-ROMs can only be changed up to five times, and the number of changes still available is located on the DVD Region tab. If the tab shows that you can only change the setting one more time (Changes remaining = 1), you won't be able to play DVDs that use a DVD region that is different from your last selection. If you run out of opportunities to change the setting (Changes remaining = 0), contact your DVD-ROM's manufacturer to reset this value.
Also install DVD decoder as an issue with codec or DVD decoder could even cause the issue with DVD region code.
http://www.microsoft.com/windows/windowsmedia/player/plugins.aspx (Also applies to Windows 7)
Mar 26, 2011 | Vacuums
I need a instruction manual for a sears kenmore single dial sewing machine model 158
Most manuals I can find for free online, but I have been looking for quite some time for a 158 manual and the best you can do is $5.00 for the one I will link you to at the bottom of the answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://gotoes.org/sales/KenmoreManual.htm
Thanks
Tim
Oct 12, 2010 | Vacuums
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Can,t make my rewind cord-rewind --How do you take the back off???????.SOOOOO------I can check the problem----need respond ASAP!!!!!!!!
This is a tricky job and will require a new winder mechanism. Take it to a repair shop and ask for a quote.
Oct 04, 2009 | Vacuums
Bissell 9200e Brush motor not spinning
the problem could be in the switch or the wire
Aug 23, 2009 | Bissell 9200 Upright Vacuum
Hoover Steam Vav & Spin Scrub #F5899-100
Sorry it is not belt driven. There is a turbine that drives the brush. You have to remove the top cover to get to it. But if the motor smells hot, then you may have a problem with it also.
Apr 18, 2008 | Hoover F7431-900 SteamVac Vacuum
Irobot Roomba will not turn off
I think both of you who responded are tools.
The issue is on the main board. What JBugs is saying is the brushes continue to run even if the unit is manually turned off.
There is no fix other than to replace the main board. There is a circuit which drives the brushes. If the circuit electronically gets stuck in a closed position, then the brushes will run until out of power.
There is a way to install a switch in the brush circuits but then you must manually turn the brushes on each time you want to clean.
Best bet is to call iRobot, complain and buy one of the out of warranty replacements for $99. This replacement will allow you to schedule the unit to wake up and will perform exactly like the Scheduler.
Jan 11, 2008 | Vacuums
Vacuums Logo
16 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
