Question about Cyber Acoustics AC-648 Headset - Stereo Mini phone Wired 20 Hz 20 khz Gold Plated Behind the neck Binaural Snr Semi open 7 ft Cable Noise Cancelling Microphone
Ac-648 mic not working
Ok, basically, i have thsi headset that, when plugged into the computer, the audio works, but the mic doesnt work at all, it even says it is currently unavailable... please help soon, and thank you for the extra help ^_^
  • brandon selman Jul 12, 2013
    oh yah, i even tried to update the drivers on my computer for it and everything else just in case, so um... i even made it my default device, so please, somebody help me soon...
  • Cyber Acoustics Master
  • 5,056 Answers
Either you have connected to the wrong socket on your computer, or the controls on your computer have not been set up. For example the microphone circuit is switched off or set too low for recording.
Posted on Jul 19, 2013
When I plug in my Audio 625 Plantronics to my usb port it shows an error - Device not recognized, please help..
If you are using a Mac computer your Plantronics .Audio headset will not work The microphone plug on the .Audio analog headsets is not compatible with a Mac. It will physically fit into the Mic input jack on a Mac; however, it will not function. Basically, the digital sound card does not recognize the analog signal coming in from the headset.
Good luck from Headsets Direct!
Apr 16, 2011 | Plantronics Audio 625 Headset
My computer speakers stopped working after installing Logitech quickcam deluxe for notebooks. Please help.
Run an audio check
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Aug 28, 2010 | Logitech QuickCam Deluxe for Notebooks
Cyber Acoustics AC-201 Micrphone Problem
i have cyber acoustics headset and i cant hear anything but my Mic works, my sound is all fine, when i plug my headset out i can hear but when its plugged in, i cant hear anything.
Mar 09, 2010 | Cyber Acoustics AC-201 Consumer Headset
I have a compaq presario v3700 with windows xp.It has conexant high definition as audio. I plug in my headset. It works in terms of audio hearing on headset but u can also hear it on computer. Then my...
Don't think its the drivers, because you can hear audio.
Do you have your mic with your headset or separatedly? If with headset, maybe your headset has a physical switch where you can enable/disable mic (seen this feature on some Locitech headsets).
You can also check whether you have Mic muted in your audio control panel. Go to Control Panel, open Sounds and Devices and File - Properties if I remember correctly (sorry, I have Vista now) and put a check before Mic property to bring out the Mic volume level bar to see whether it's muted or not.
Hope this helps,
Tom
Nov 17, 2009 | HP Pavilion dv9000z Notebook
Clear chat mic doent work
in skype go to tools>options>audio setting make sue the microphone is logitech and the green bars should start moving as you talk.
if no logitech appears or the mic is not producing sound. call logitech for warranty info. if the mic is producing sound below is "make a free skype test call" to see if the program is transmitting.
Jul 18, 2009 | Logitech ClearChat Stereo Headset Headset
Mic is not recognized
i have a GE 98980 headset and window vista wont reconize the mic but the headphones work fine. How do i get the mic to work?
Jun 02, 2009 | GE (98980) Headset
My microphone will not work, and my computer won't recognize!
Common problem with this headset.
In short, the wiring for the mic in the left earpiece is quite shoddy, and over time will be worn away by changing the mic position or come loose with minimal effort.
Have had a over a dozen of these fail in our internet cafe due to this issue after a couple of months use.
May 31, 2009 | Genius HS-04SU Headset
Ive just bought a headset for my laptop, but the mic doesnt work though the speakers do. My laptop is vista and it doesnt even recognise that there is a microphone plugged in. Any ideas?
please confirm first that you plug mic jack in right socket-open volume control and check mic not in -mute--and fader in up position
Jul 16, 2008 | Audio Players & Recorders
Microphone can be detected but doesnt work
Go to start then control pannel then sounds and audio devices. Then in in the volume tab select advanced in the device volume section. When the mixer comes up go to options then properties select the recording option a recording mixer will come up make sure to check the microphone box. Raise the level in the ixer and you should be golden. If you want to hear the mic select playback mixer and raise the mic level. Hope this helps. : ]
Dec 09, 2007 | ASUS P5RD1-VM Motherboard
Mokrophone is not working
Found the problem... What Apple has is a line-in port...it requires a pre-amp to boost the signal of your mic. A PC likely has a mic-in port.
They're different ports...very similar but they accept different levels of input. Apple likely wants you to use their built-in mic for mic use and the line-in port for line-level audio sources.
Thsi appears to be our solution... Griffin iMic / USB Audio Interface
What a pain.
Oct 20, 2007 | Sennheiser BINAURAL HEADSET :unitsize...
Cyber Acoustics AC-648 Headset - Stereo Mini phone Wired 20 Hz 20 khz Gold Plated Behind the neck Binaural Snr Semi open 7 ft Cable Noise Cancelling Microphone Logo
67 people viewed this question
Top Cyber Acoustics Audio Players & Recorders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Carlos L. Burgos
Carlos L. Burgos
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
