Question about GE Spacemaker JVM1750 Microwave Oven
Key pad number not working - GE Spacemaker JVM1750 Microwave Oven
Frigidaire troubleshooting key pad seems to be stuck on child lock
If you have your owner's manual, read the section on how to disable the child lock. If that doesn't work the touchpad could be defective.
Jul 17, 2014 | GE SpaceMaker Microwave Ovens
Key pad flashing se . key pad locked pease tell me what to do iam a disabled lady need help please
"SE" error means you have a shorted membrane keypad.
You would need to have either the membrane keypad itself replaced, or the control panel frame assembly which comes with a new keypad, or the whole controller.
Part numbers and prices will of course depend on the model number.
Dec 27, 2012 | Samsung Microwave Ovens
Microwave key pad won't work
That is a failed membrane keypad.
It is part number 3518522640B and you can order it from the Pros here.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this repair for you, we do that for $39.95 plus parts.
Aug 22, 2012 | Magic Chef Microwave Ovens
THE KEY PAD QUICK WORKING. I HAVE REPLACED THE CONTROL BOARD BUT THEY STILL DO NOT WORK.
Hello, Thank You for using FixYa. I will be helping you today.If the buttons are not working replace the touch membrane. I would list the part number but you didnt give full model number.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | Frigidaire PLMB209DC Microwave Oven
Only the numbers 9 and 8 seem to work on the number pad. Any suggestions?
Possible key pad failure and replacement will fix it.
Contact the manufacturer to gain a contact number for spares and availability.
Hope that helps.
Dec 31, 2010 | Thermador MBBS Microwave Oven
Buttons on number pad dont work , except one
HI, the key pad or, touch pad is defective. you will need to replace it asap if possible.
These key pads run about 130 dollars tops. contact Panasonic for this part.
Jun 21, 2009 | Panasonic NN-S433 1100 Watts Microwave...
Sharp microwave model R-395F(S) bought in NZ. 1100W about 30litre. Problem from new, display weak but main problem as some buttons work some don't work and you have to push stop a few times before it...
Hi Lindsay
Sound like you need a new key pad if you have some handy man around you you can replace it, It require dismantle the front key pad remove electronic part and clean then reinstall properly the key pad itself about $40.00 Aus
Let me know if you need part number for that key pad
Cheers
Dec 02, 2008 | Microwave Ovens
Erratic keypad
It must be dissassembed Clean both surfaces (pad bottom surface and board up surface so they would have good contact) with alcohol solution liquid sweep and let them be dry. Next assemble it again and test it. if START KEY persit not working even if it is clean, a small leaf of aluminium must be stuck at the pad bottom of START KEY. Be sure you can carry out this procedure well done otherwise you 'll need to buy another keypad. Good Luck!
Jan 05, 2008 | Kenmore 63672 Convection/Microwave Oven
Key Pad only works on some numbers. Others do not respond when pushed
Unplug the unit. Generally, remove the screws inside the door that hold on the faceplate. Inside, it will become rather obvious how to detach the keypad from the main circuit board. Note that some of the screws are longer than others. Carefully unplug the wire loom from the board. Note that these plugs have a small movable section. Flush to the board is lock...up is unlocked. Make sure when you push the loom in that the section is up...then push it down. By the way...before you buy a new part, unplug each connection related to the key panel and reinstall. It may just fix it.
Dec 19, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1750 Microwave Oven Logo
18 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
