Question about Samsung SMH9187 Microwave Oven
Unit cuts off
When attempt is made to cook unit will start to run for 2 or 3 seconds and then cuts out completely. no error code. acts like a breaker poping or capacitor failing.
    Top Expert:
  • Samsung Master
  • 12,223 Answers
See this steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Posted on Jul 13, 2013
Sears kenmore elite has a message display to enter tcp code. kenmore microwave oven
TCP is "True Cook Plus" in Kenmore speak.
Here is a cut/paste of a section of the manual.
*CUSTOMIZING TrueCookPlus' You may find that you prefer TrueCookPlus® to cook your food more or less. TrueCookPlus " can adjust to your tastes - to cook your food hotter or cooler - automatically: Example Clear 1. Press the Clear button. (§H§ 1 2. Press the TrueCookPlus® button twice. 3. If you want less cooking time when you enter a TrueCookPlus code, press 1. This will decrease the time by 6%. 345 4. If you want more cooking time when you enter a TrueCookPlus® code: Press 3 for 3% more cooking time. Press 4 for 6% more cooking time. Press 5 for 9% more cooking time. 2 5. Press 2 to reset TrueCookPlus* to factory setting default time. 6. Press the Start button.
I didn't try to clean up the copy
Hope this makes sense and helps.
Sep 14, 2017 | Kenmore Microwave Ovens
Unit fails when attempting to cook.
see the steps and fix it. God bless you
Jul 12, 2013 | Samsung SMH9187 Microwave Oven
Ge pvm2070smss shuts down
It may be a noisy magnetron if the failure occurs in a second or two of hitting "Start" to begin cooking.
See this FixYa solution. even though your model number is different.
Otherwise, if the internal cooling fan is not running when you are cooking, it will shut down after 30-60 seconds or so and stay off until it cools back down.
Also see http://www.microwavedisplay.com/jvm2070.htm
Feb 24, 2013 | GE PVM2070SMSS Microwave Oven
Powers off immediately after starting
My immediate reaction would be to cut your losses and buy a new unit as sooner or later you will run into a part that is no longer available.
Nov 03, 2012 | Whirlpool Microwave Ovens
G E microwave model # JVM1190BY has reading sensor error or error 3 or at times just starts up when we are not even using. tried shutting circut breaker....whats going on
Hello
"ERR 3" means that the magnetron units have failed in the microwave. Food will not cook or heat up when the microwave is in use.
This code is different than "ERR 1" or "ERR 2" because with those the microwave is still operational. "ERR 3" means a complete failure.
The magnetron is the main source of power and heating in a microwave. Magnets work inside a magnetron tube to create the heat and voltage needed to cook items.
Bring the microwave back to the retailer or a repair shop for service. You may also consider purchasing a whole new microwave if the prices are cheap enough.
Oct 04, 2011 | Microwave Ovens
I have a Panasonic microwave convection that runs for 2 or 3 seconds, then cuts off. It doesn't matter what setting or length of time you program into it, it will run a couple of seconds and shut down. Is...
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Sep 08, 2010 | Panasonic NN-C994S Convection/Microwave...
Time set does not complete
You didn't mention your brand or model number, but I'll assume it's a Panasonic since you posted this under a Panasonic category.
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
May 26, 2010 | Panasonic NN-T994SF Microwave Oven
Maytag MMV5165BA Over The Range Microwave
We had this problem. It was installed improperly - to recirculate instead of to vent.
Sep 07, 2007 | Westinghouse WST3504 Microwave Oven
Samsung SMH9187 Microwave Oven Logo
156 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
