Question about Autopage Vehicle Parts & Accessories
Alarm activates falsely
I have an older RF410 installed in a 04 ford P/U all of a sudden the door ajar light in the instrament panel stays lit. I think this is causing the problem. After activating the alarm it will take a minute or two then it will chirp a few times and the LED will flash 3 times.Is there a easy way to tell witch door lock assy. is causing the problem?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 112 Answers
There should be a pin button that pushes in and out by your door hinges. if these stay stuck in the dome lights wont work. if its out you will experience some problems like you are experiencing. try checking these and go from there.
Posted on Jul 14, 2013
2 Suggested Answers
  • 53 Answers
SOURCE: I press the lock door/alarm activation button and
sounds like the remote is not program try programing the remote again
Posted on Jul 12, 2009
Why do I see a rear access open and a gate ajar warning on insument panel, even though it is locked?
[SOLVED] False Gate Ajar/Rear Access Open warnings: follow up post ...
forums.trailvoy.com > ... > 02-09 General Tech Q&A > General
Dec 28, 2009 - 4 posts - ‎2 authors
[SOLVED] False Gate Ajar/Rear Access Open warnings: follow up post General. ...2002 Chevy TrailBlazer LTZ ... In cold weather, I have a constant "gate ajar" warninguntil the ... Should I try to unhook/rehook the connections to the BCM? ... You might confirm it by starting the vehicle cold, see that you have ... Annoying tailgate ajar won't quit going off on 04 gmc ...
Feb 4, 2010
Rear latch assembly not functioning on Lift Gate
Oct 12, 2009
Gate Ajar - turning off
Jul 1, 2007
passenger door ajar
Nov 9, 2005
More results from forums.trailvoy.com
Rear access door ajar - false signal - Fixya
www.fixya.com/cars/t22610885-rear_access_door_ajar_false_signal
Feb 03, 2016 | 2002 Oldsmobile Bravada
Replace door ajar relay on 2012 Ford Edge
check the adjustment on the door switch it is the same one for the interior lights . or the switch is bad.
Jan 01, 2015 | 2012 Ford Edge SE 4dr SUV 3.5L V6 6-speed...
Auto door lock don't work, they click when activated. Also the door ajar light stays on and auto light does not work. F350 super duty 2002 ford
You might need to oil the locks. Our truck does that some times. We just spray some WD40 on the catches and keep clicking them back and forth till it sinks it. As for the ajar light, the sensor inside of the door jam might be damaged. or the switch on the lights is turned on. I did that once.
Feb 27, 2013 | Cars & Trucks
Keyless entry isn't working and alarm was tripped
Check your door latches. Since the light stays on, one of them isn't reading properly. Once you get that fixed, the remote should work. The light problem could be related. The computer thinks the door isn't shut so that part of the system thinks you aren't moving.
Mar 20, 2010 | 2002 Ford F350 Super Duty DRW Reg. Cab
04 EXPLORER DOME LIGHT STAYS ON, DOOR ADJAR LIGHT ON, DOOR JAMB SWITCHES WORKING PROPERLY.
At least one of your door ajar switches are sticking. Try spraying rust penetrant into the latches and open and close the doors several times. If they still stay on you will have to locate which latch it is by removing the door panels and disconnecting the switches.
Feb 24, 2010 | 2004 Ford Explorer
2002 Jetta red door ajar light stays on-car alarm won't activate
you have to find wich door is first becouse they all have kill swich in every door so u have to disconect one by one n by pass to see wich one turn the light off then u will have to replace it auto parts store shuold have these at hand, lol becouse as long the light stay on the alarm will not work,
May 02, 2009 | 2001 Volkswagen Jetta TDI
Door ajar alarm comes on while driving.
there is a switch in each door that senses the door is open, it is called the door ajar/courtesy light switch (imagine that), they stick and have this problem, replace it.
Mar 25, 2009 | 2001 Volkswagen Jetta TDI
Door ajar light on
The drivers side door switch goes bad all the time on those, try replacing or check if its sticking.the small little button int the door jam.
Feb 01, 2009 | 2002 Ford F250 Super Duty SuperCab
2002 Ford Explorer "Door Ajar" stays on and Alarm frequently goes
if the door ajar light is on then get a can of PB BLASTER at your local parts store and spray all the door latch assembleys really good and open and close each door about ten to fifteen times this will usually free up the ajar switch
Feb 01, 2009 | 2002 Ford Explorer
Ford taurus door ajar light stays on
have you had the door panel apart before for anything, the switch is on your latch inside your door. I hope this helps you. I am just trying to be helpful, and will help you all the way through your repair if you like, My compensation is my rating. please be generous..lol
Dec 19, 2008 | 1996 Ford Taurus
Vehicle Parts & Accessories Logo
52 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
