Question about Philips Magnavox 51MP392H Rear Projection Television
Magnavox 55p8288 does not turn on.
Front light flashes 4 times then pause etc... just want to know what the code means, and how to fix would be cool.
    Champion:
  • 247 Answers
Lamp is overdue needs replacement
Posted on Jul 14, 2013
3 Suggested Answers
SOURCE: magnavox 55p8288 tv not turning on
My problem is the same as the other two ppl. The Tv does not come on only the power button keeps flashing on/off.
Posted on Dec 13, 2008
circuitworld
  • 335 Answers
SOURCE: 55p8288 turns off on its on and won't turn back on
Seems like the lamp needs replacing, take the lamp out and see if its warped or bulb filament cracked. If so replace the lamp you can get one here.
http://tvtechwork.webs.com/
Posted on Oct 18, 2010
Our Trinitron KD-27FS170 Tv will not turn on. It sounds like it is turning on/off but no picture or sound. The Stand-by/Timer red light is flashing 4 times, pause, then 4 times, etc.
This typically means you have a bad capacitor, you can inspect for any swollen or bulging capacitors however unless familiar with desoldering boards best leave it to a repair technician.
Jan 13, 2015 | Sony FD Trinitron WEGA KD-27FS170 TV
Led light flashes 4 times, pauses then repeats
Which light blinks 4 times and pauses wash normal heavy etc if the model in the blue box is correct the to enter diagnostic press any 3 keys within 8 seconds I usually use normal and the 2 keys to the right all lights should light up if touch pad is up top where you had to open door to accomplish this then close the door after a pause the clean light will begin to flash example 7 flashes pause 1 flash these are your fault code it will do this 3 times for each code. The tech sheet should be behind the toe panel located below the dishwasher door which just repeats what I explained.
Feb 04, 2014 | KitchenAid KUDE70FXSS Builtin Dishwasher
I have a jazzy 1121 power chair and the lights on the joy stik are flashing and the chair just stoped working
Doggy count the number of flashes ie 4 flashes pause 4 flashes if you are not getting any pauses
what lights are flashing the battery level lights or the speed lights? Are all the battery level lights flashing or there are 3,4,5,6 or 7 etc. lights flashing? if you are getting a pause between flashes the number of flashes will tell you the error. Your owners manual should tell what each code means. Hope this helps
Mar 06, 2011 | Health & Beauty
My Lynx L4 4-Wheel scooter green light flashing but it said it is charge it wont go forward
the green flashing light indicates an error with the scooter. Count the number of flashes 4 flashes pause 4 flashes pause etc and your manual should give you the meaning of the flashes Check to make sure that you are not in freewheel move the lever at the back of the scooter up and down a few times and make sure you leave it in drive mode turn on the power and see if the light stops flashing and the scooter will operate correctly Hope this helps
Oct 03, 2010 | Activeforever Lynx L4 Portable Mobility 4...
We are trying to move the chair and the service light keeps coming on
The service light indicates a problem. Count the number of flashes. ie flashes 4 times pauses flashes 4 times etc. If you have the owners manual the flash code section will tell you what the number of flashes mean: 3 flashes left motor 4 flashes right motor. You will have to contact a service company to repair the chair once you find out what flash code you have. If Medicare pirchaed the chair then they will pay for most of the repair cost. Hope this helps
Aug 25, 2010 | Electric Mobility Invacare Pronto M41...
Stays on for 2 seconds and switches off
A 2-2 code on that unit means over current shutdown. 95% of the time that code indicates defective convergence output IC's.
Jun 09, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Will not start just died.
Engine? Those flashes should be 2 digit numbers . Cycle key, on, off, on, off, on & leave on & recount those flashes. Example: 3 flashes, pause, then 3 more is code 33. Or 2 flashes, pause, 4 flashes, is code 24. 5 flashes, pause 5 more, is code 55 which means end of message. Then get back.
May 31, 2009 | 1989 Dodge Caravan Cargo
No picture on magnavox 32MT6015D
THAT THIN WHITE LINE IS YOUR HORIZONTAL LINE MEANING YOU ONLY HAVE THAT. THE GOO NEWS IS YOU HAVE HIGH VOLTAGE MEANING YOU ONLY NEED VERTICAL TO FIX IT.. I WOULD REPLACE THE VERTICAL TRANSISTOR OR CHECK FOR ANY BURNED RESISTORS ON THE VERTICAL SIDE
Feb 22, 2009 | Philips Magnavox 32MT6015D TV
Magnavox 55p8288 tv not turning on
Nov 30, 2008 | Philips Magnavox 51MP392H Rear Projection...
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
35 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
