Question about Lexmark 2381 Plus Matrix Printer
Fix page printing
Hi, I have a problem with my Ibm lexmark 2381 plus. I have installed it and worked fine for a while. I use it with my AS400 application. My problem is that when I print from my AS400 session, using tractor paper, the printer doesn't recognise the end of page so I can tear off the page. How can I fix this setting
  • ahmetshkoza Aug 27, 2007
    can you give me a hand and tell me step by step how to config the paper size?
    thanks for your help
    Genius:
  • 2,985 Answers
Not Familiar with this printer particularly But if you reduce 'paper' size presumably the printer will reduce the image to fit. Did you try that?
Posted on Aug 27, 2007
How do you change a printhead on a lexmark 2381 printer
throw it in bin they not easily fixable
buy a better one with cheaper cartridges
May 05, 2016 | Lexmark 2381 Plus Matrix Printer
My printer prints nothing only white papers
why my HP printer D1600 is printing only a white
paper with the date and hour index only?
Thank you in advace .my e.mail is
vrileoniko@hotmail.gr L.H.
Jan 09, 2010 | Lexmark 2381 Plus Matrix Printer
ZEBRA printing issues via AS400
*SAME
*WSCST
ZEBRA
*LIBL
*NONE
'10.27.9.21
Jun 26, 2009 | Zebra 105Se Thermal Printer
Dot matrix printer. very light print on last page of form
Hi and welcome to FixYa,
Based on your description, the printer is working, it is not a form issue, the printer head is good, an adjustment might be needed and it works, there is no reason to replace the Lexmark 2381plus printer even if it is 7 years old (not unless you would want to).
To the faint printing on the last of the 3 pages:
  • the take-up spool/wheel drawing the ribbon is not working (most likely). The ribbon is not moving hence the printer head is not striking fresh ribbon area. Check the ribbon cartridge, it may be stuck or the driving spindle where the ribbon's take-up spool/wheel locks into. It may need a bit of cleaning and/or lubrication;
  • the printer head is slightly adjusted away from the paper. Normally, there is a mechanical lever/adjustment that sets how many paper & duplicates are fed. Adjust for 1 only.
Good luck and thank you for using FixYa.
Jan 30, 2009 | Lexmark 2381 Plus Matrix Printer
Problem printing to wireless print server
I have a lexmark z715 printer that won't work my pc is a emachine windows xp please contact me at noahmackey@bellsouth.net
Jan 15, 2008 | IBM Lexmark Z715 InkJet Printer
4247 Printer with a 56 Print Error
47b6dfe.jpg Hi,
There are a number of potential causes for this error. the most likely is a dirty Printhead Home sensor ( see Pic). Try cleaning it with a cotton bud or compressed air.
Does the problem occur during a self test ? ( print at leat 10 pages )
Let me know if this doesn't sort it.
Aido
Dec 07, 2007 | IBM 4247 A00 Matrix Printer
Missing characters, missing print barcode lines
Hi, It's been a while since I worked on these, so I'll go out on a limb (as far as my rating goes) and say that the few times I've seen that happen usually results from a bad network card. Now you may not be using a network card, so if your not then I'm not really sure what would cause that to happen on the printer side. The environments that I've seen that happen in are with an AS400 and the network card just gave out. You most likely tried this, but you might want to make sure that the computer isn't using one driver for both printers. Good luck.
Aug 28, 2007 | IBM 4039 Model 16L Laser Printer
Printronix p5010 with AS/400 IBM server
I can get the P5010 printing on your AS400... But, there are to many things to check without knowing a little more about your environment.
If you can't ping the PTX P5010 from the AS400 or a PC, then you have a printer configuration problem.
Take the printer offline and hit the Print Config button. and then the enter on OPs Panel. Then post top or first paragraph of the config. so I can look at...
__________________________________________________________
If you can ping the printer from the AS400...
You will need to create a remote out que on AS400... command is crtoutq then hit F4...
if you can't post the printer config here... Fax it 972-233-7306, Attn: P5010, Toby
Dec 12, 2006 | Printronix Line Matrix P5010 Printer
Lexmark 2381 Plus Matrix Printer Logo
194 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
