Question about Cell Phones
Why does my Sony Xperia u keep freezing and completely losing signal, I have recently updated to android 4.0
My xperia u freezes all the time and loses signal completely. I have to reboot my phone for it to work again.
SOURCE: I am using a sony ericsson xperia x10i and it has
Hi Adrian, I agree with you on the fact that battery consumption should have been a bit better, but I have found an application which is helping me a lot to improve it :-) You just need to download from Android market the application apndroid (free) and disable all APN connection when you don’t need them.
Then just simply tap the widget icon (I suggest you to add it on your homescreens) to enable it again for making use of the data Tx over mobile network when needed....doing this my battery is now running over 2 days with WiFi and GPS always turned ON. I hope this helps.....btw no freeze experienced so far.
regards
Jeff
Posted on Apr 20, 2010
SOURCE: My Xperia X10 always restart and can't run and open again.
i don't thrust your name you thief:D
no i don't know.. i'm sorry
Posted on Aug 14, 2010
rockmeister
  • 2047 Answers
SOURCE: i do not have the
This is very simple to sort out. All you have to do is go to your browser open the google webpage and search for the Android Marketplace the result you get will give you a link to download the android marketplace software to your phone.
This will help you get the android market place on your sony ericsson xperia x10 mini pro.
Hope this solution has been helpful?
Posted on Dec 03, 2010
  • 1040 Answers
SOURCE: I have Sony Ericsson XPERIA
hi,
Different network operator's have different settings of GPRS. Therfore, contact your network operator and ask them to send the settings of GPRS. You will receive the Settings via SMS. Install the settings and re-insert the SIM. If they dont have the settings then ask them to tell you the procedure for creating the manual setting. follow that procedure...
Hope this has helped you.. Please rate the answer. Thanks..
Posted on Jan 04, 2011
  • 32 Answers
SOURCE: my network signal disappears randomly..im
Check out the site HERE
Posted on Mar 10, 2011
How do you update
Karen, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Update Android Version on Tablet
How to update Android smartphone or tablet
The Official Xperia Website Sony Xperia Global UK English
Update your Kindle reader today if you want to keep using it
Mar 22, 2016 | Tablets & eReaders
How to Blocked my Xperia Z1
Unless you had it signed up or installed an app, you cant. You can have your service provider cut service to the phone, and that is about it. Is your GPS on?
Jul 28, 2014 | Sony Xperia Z1 Black Smartphone - Unlocked...
Sony xperia t troubleshooting
restore settings
or this one note all data will be deleted
How to Soft Reset or Reboot or Restart SONY XPERIA T LT30p ?
To soft reset SONY XPERIA T LT30p, press the POWER BUTTON KEY for several seconds, we will see the menu to restart or turn off. Choose restart/reboot than the SONY XPERIA T LT30p will do the soft reset or restart. This is safe to do because non of important data or applications will wipe or erase.
#Option 1, Hard Reset SONY XPERIA T LT30p with Software Menu :
  1. Make sure the battery is charge properly
  2. Turn on SONY XPERIA T LT30p smartphone
  3. Don't forget to backup all important data
  4. Go to menu: Setting > Backup & reset > Factory Data Reset > Erase internal storage > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA T LT30p
  6. The SONY XPERIA T LT30p will continue the step until ready to use in clean factory default.
#Option 2, Hard Reset SONY XPERIA T LT30p with Flashtool applications:
  1. Flashtool in the applications from Sony can be download from Sony website.
  2. Flashtool software need to installed in you computer and ready with USB data cable
  3. Make sure SONY XPERIA T LT30p battery is charge properly or full charge
  4. Power off SONY XPERIA T LT30p
  5. Boot SONY XPERIA T LT30p to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
  6. Follow the menu at you computer display, it is easy to understand the steps.
#Option 3, Hard Reset SONY XPERIA T LT30p with Hardware Key Button:
  1. Make sure the battery fully charge
  2. Do not forget to backup all important data
  3. Turn off the SONY XPERIA T LT30p
  4. Press and Hold together: Power Button + Volume Up Button for several seconds
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA T LT30p
You can choose the step options above to do hard reset while the SONY XPERIA T LT30p get problem or not running well. But we always suggest to do routine backup before your smartphone get problem. If SONY XPERIA T LT30p already stuck or run slowly or not responsive, then better try to do backup as you can because all important applications will be wipe or removed from SONY XPERIA T LT30p after doing master reset, but some data which saved at memory card will be safe, better to remove the microsd memory card before doing the hard reset.
Jun 16, 2014 | Cell Phones
My sony xperia tipo(DUAL) touch screen freezes after every 15-20 minutes of standby . plz helpp !!!!
There is a solution by Sony for this problem.
Just follow the instructions: http://talk.sonymobile.com/t5/Xperia-miro-Xperia-tipo-tipo/TIPO-TOUCHSCREEN-FIX-PATCH-HERE/td-p/262920
Sep 27, 2013 | Sony Xperia Tipo Dual ST21i2 Black Android...
How to recover deleted photos and videos
GT Recovery for Windows is a professional data recovery for Android phone or tablet. It can restore deleted photos,videos,audios,documents from Android SD card and internal memory. Whenever you lost important pictures or deleted photos by accident, you can use it to scan and recover the images on your Android devices.
Here are the steps to recover deleted data on Samsung Galaxy S4.
With this way you can recover deleted data on any brands of Android device such as Samsung, HTC, Huawei, Sony, Motorola, Lenovo, LG, Sharp, etc.
Sep 08, 2013 | Sony Ericsson Mobile Phone Xperia U ST25i...
Recover messages and photos in sony ericsson vivaz u5?
no root !
Can you retrieve deleted text messages on Android? Yeah, this video will show you the full guide for Android text message recovery. Don't hesitate and recover deleted text messages from Android 4.0, 4.1, 4.2, 4.4, 5.0, 5.1 and more versions right now!
Not only can you recover SMS messages from Android backup but also can recover Android SMS messages without backup. This video is showing you how to recover deleted sms messages on Android without root your phone.
Some common situations that lost text messages you can recover from:
1. accidentally deleted texts on your android phone
2. lost text messages after Android 5.0 updated or other Android upgrade.
3. save text messages from water damaged, crashed, broken or smashed Android phone
4. Android deleted text messages randomly by itself
5. Factory restore Android phone.
And more..
Jun 20, 2012 | Cell Phones
My xperia x10 with android 2.3.3 freezes and thenkeeps on restarting for itself. i have flahed it twice but it's not solving the problem.. please...please..please help me.....
I also have an xperia x10 with the same problem - i've updated from 1.6 to 2.1 with no issues back when 2.1 first came available. Now updating to 2.3 causes the same symptoms as the origonal poster.
Any help would be great
Aug 27, 2011 | Sony Ericsson XPERIA X10 Cell Phone
My xperia x8 phone is not working properly its hanging a lot and my music and video files are not being played properly
hi my name is neil and i just got a sony ericson phone(xperia x8) but i can't figure out how to send music,videos and pictures through bluetooth..can somebody help me please...?
Feb 20, 2011 | Sony Lands Phones
Cell Phones Logo
227 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
