Question about NetGear Computers & Internet
Authentication failed I can connect to the internet if the wire is plugged into the router but no wifi. Keeps saying authentication error
  • NetGear Master
  • 27,725 Answers
A Netgear wireless router attaches multiple devices to your Internet connection, either by ethernet cable or wirelessly.
If you can't connect to the Internet, the problem can be anywhere along the chain of devices and technologies that connect your computer to the Internet.
Knowing how to troubleshoot your Netgear or other wireless router is an essential part of determining where the problem is and fixing it.
Click your "Start" button, and choose "Run."
Type "cmd" in the text box (without quotation marks), and click "OK."
A command prompt will open. Type the following: ipconfig /all. Press your "Enter" key.
A list of numbers and other networking configuration information will display.
Find your network adapter in this list of headers.
If you use your computer wirelessly in many different places, you may have to scroll through a lot of different options to find your adapter.
If you connect to the Internet using a cable, look for a header that begins with "Ethernet adapter Local Area Connection."
If you connect wirelessly, look for a header that begins with "Ethernet adapter Wireless Connection."
You will usually only see an IP address displayed under one header in either category.
Record your IP address and default gateway on a piece of paper or in a text file.
If your IP address is 0.0.0.0 or begins with 169.254, unplug your Netgear router from its power source.
Unplug your cable or DSL modem as well.
Be sure to unplug both devices; turning them off with a power switch may not have the same effect.
Wait 20 seconds before plugging the modem in again.
Wait for the lights on the modem to light up.
Plug in your Netgear wireless router again.
Wait for two minutes. Use "ipconfig /all" again.
You should have a different IP address now.
Ping your default gateway.
At the command prompt, type "ping 192.168.1.1" (substituting your default gateway address for 192.168.1.1).
You should receive four responses, all of which will begin with either "Reply from" or "Request timed out."
If you receive "Request timed out," unplug your Netgear wireless router from the power source for 20 seconds, and plug it in again.
Wait two minutes before using "ping" again.
If you receive "Reply from" responses, check to see if your Internet connection is working again.
Open a Web browser. In the address bar, type "http://192.168.1.1" (substituting your default gateway address for 192.168.1.1).
Press "Enter." If you have password-protected your Netgear router, you will be prompted for a username and password.
The default username for a Netgear router is "admin."
When you have successfully entered the username and password, your Web browser will show you the configuration page for your Netgear wireless router.
If your Web browser never loads a Web page or prompts for a username and password, you're not communicating with your Netgear router.
Double-check the address you typed into your address bar.
If you've typed it correctly and your connection is wireless, either your wireless card has a problem or your Netgear router is not correctly sending a wireless signal.
Make sure your wireless card is enabled (using Windows' built-in Network Connections applet or the third-party software that came with your wireless card).
Make sure your connection settings (SSID, security type, and key or passphrase) are correct for your network.
Look at the lights on your Netgear wireless router.
The wireless indicator light should be green.
If it's orange or not on at all, your router is not sending a wireless signal.
Make sure all the settings on your Netgear configuration page are correct.
Most Internet providers use a dynamic IP address and DNS server addresses.
Some Internet providers require a login, and some do not.
To be sure, refer to the configuration information your Internet provider gave you when your Internet access was installed, or call your Internet provider's technical support number.
Click on "Wireless Settings" on the navigation bar on the left-hand side of the page.
If you were not able to reach the configuration page wirelessly and had to connect to your Netgear router with an ethernet cable, make sure these settings are still as you defined them when setting up your network.
If not, either change the settings to suit you, or change the configuration of your wireless card to match these settings.
Be sure to click the "Apply" button if you make any changes.
Click "Router Status" on the navigation bar on the left-hand side of the page.
Under "Internet Port," check your IP address.
If the address begins with 169.254, you're not communicating with your cable or DSL modem. Unplug your cable or DSL modem from its power source for 20 seconds, and plug it back in. Wait two minutes, and refresh this page.
If your IP address still begins with 169.254, there is a problem either with the cable connecting your Netgear wireless router to your cable or DSL modem, or with the modem itself.
If your IP address is 0.0.0.0, there is a problem with your Internet connection, and you should call your Internet provider's technical support.
Record all your configuration information before trying to reset your Netgear wireless router to the factory defaults.
Resetting may fix your problem, but it will wipe out all your configuration information, and you will have to reconfigure your Netgear router from scratch afterward.
To reset most Netgear routers, use the tip of a pen or an unbent paperclip to press and hold the reset button on the back of the router until the test light blinks.
Release the button, and wait two or three minutes.
Connect to the router's configuration page in a Web browser.
Log in with the default username and password, and configure your router.
You may have to connect to the router with an ethernet cable to perform this initial configuration.
Posted on Jul 12, 2013
Sutibun
  • 186 Answers
SOURCE: Connecting wired Virgin Broadband through third-party WiFi Router
Clone your mac address in the router
Posted on Oct 02, 2008
  • 1214 Answers
SOURCE: Connection Failed
First, have you done a master hard reset of the router by depressing the hidden button on the back of the router?
2nd, what Operating System are you running?
Reply back and I can give you more information/instruction.
Posted on Feb 16, 2009
  • 135 Answers
SOURCE: authentication failed!
You need to contact your isp for DNS, see:
Click here!
Posted on Feb 19, 2009
SOURCE: Wireless Computer Cant Connect to 3com router!
I just had a similar problem. Only two days after successfully using my wireless, my wireless PC did not connect but my two wired ones still did. The only radio within distance on the LAN info was called 3COM (!) but on clicking this I was told no station within range! I went to access my pages on one of my other machines but at first I made a stupid mistake by putting in the 3com access code into google, (so used to surfing with google!) instead of into the file open, or the address line! Once in, I found everything had defaulted to factory defaults. My password had gone and was back to 'admin'. My settings had all gone, so I re-did the whole thing, new passwords, new encryption numbers, the lot, saved the profile, and touch wood it is OK now. I cannot think how the whole router system would suddenly revert to default, however I did notice on the log page that just after I re-did the settings, someone tried with several computers persistently to access my broadband, but failed.
I hope this might help someone but I would be curious to know what happened. Did someone 'hack' my settings and remove them? I use WEP as I have never been able to get WAP to work.
P.
Posted on Jul 19, 2009
anandg27
  • 1272 Answers
SOURCE: iPhone keeps dropping wifi signal on Netgear DG834G router.
Hi, please perform the below steps to configure settings on the router:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router, usually with http://192.168.0.1 or http://www.routerlogin.com.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
5. Click on WAN setup from left menu. Check the box for 'Disable Dos Protection'.
6. Set the MTU size to 1400. Click apply.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jan 08, 2010
What does authentication error mean when I try to connect to my wifi?
You need to input the authentification code which was supplied with your router.
Aug 09, 2015 | Tablets & eReaders
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
I cannot connect to my wireless router. can someone help me please?
verify your wifi ssid, password and security setting on your tablet. Are you able to connect to your wifi using another device?
Nov 18, 2014 | Cobra Vehicle Parts & Accessories
Authentication problem
trying dumbing down the authentication on your wifi router. Try these:
turn off 40mhz wide channels
try wpa instead of wpa2
try tkip instead of aes
if all else fails, try wep.
Feb 11, 2014 | Craig CMP741d Tablet
I have a asus TF300T transformer pad , we have got good wifi and the router is fine but it will not connect to the internet keeps saying authenticating but wont connect
I would reset the router and reinstall the connection with the password and ID settings. There may be a letter or numeral wrong.
Dec 07, 2013 | Computers & Internet
Connot connect to century link with wiresless
assuming you've connected previously without error REBOOT both your computer and your router. give a few minutes for your router to boot up, connect and start broadcasting the wifi. if your system doesn't connect after that, scan it for malware and spyware with reputable software
Dec 02, 2013 | Computers & Internet
Authentication error
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Jul 12, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
Hi. My wifi internet connection requires online password verification, So i have to open web browser and provide userid and login to start using internet. But my Ps3 browser is not showing the pop up...
The PS3 browser doesn't work so well with that kind of stuff. You generally do all the authentication during the setup with your wirless router.
Try changing your password, using a different brand of routers, or simply change your security type like TSPK-WEP, or plain TSPK
Jun 05, 2011 | Video Game Consoles & Games
Dash will not connect to my network. Keeps saying "wlan0 link is down, failed to obtain ip address internet is unreachable" Please help!!
My problem was my router's authentication type was set at "Shared". Once I changed it to "Automatic", I connected without a problem. I remembered this same issue with a new laptop that we couldn't connect to our WiFi. On the laptop, I went into the wireless properities & changed the security type to Shared. Unfortunately this isn't an option on the Dash, so you have to change it on the Router (using the router software). Hope this helps!
Sep 05, 2010 | Sony Dash Personal Internet Viewer HIDC10
Computers & Internet Logo
79 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
