Question about Freezers
Need codes from the digital display - Freezers
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
What make and model freezer?
Posted on Jul 12, 2013
  • mborghi62 Jul 12, 2013
    510 slant scoop ice cream display case
    model # 000016078300
    Framec
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
Getting error code 36 hour duration
I appreciate your inquiry, friend!
Based off what you have described your Frigidaire freezer is displaying an error code of 36 hours. Normally it will display that once power has been restored, it is indicating that the freezer has been without power for 36 hours. Hold the "alarm reset" for 3 seconds and that should help clear out the code. I hope this is helpful. -Matt
Mar 10, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My kenmore upright freezer has a digital display that shows alarms. it is showing a ff and a ce code. can you tell me what they mean?
You have a bad freezer fan and need to replace it. The fan is located behind the back wall INSIDE the freezer. The unit will warm up a little because the air wont circulate the way it is supposed to. You can try unplugging fridge for 30 seconds to reset the control board u can do it yourself although I don't recommend it because u need actual diagnosis but this seems it hope it helps try buying part from sears or amazon
Dec 10, 2013 | Kenmore Freezers
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Samsung RSA1WTMH i just blew my fusebox and my fridge freezer just flashing 1 led light
hope the following helps you, I had a similar problem with my RSH1 and it took me a few hours searching online before I found the following.
"Hi, I have it on good authority that this is the system check for Samsungs (RS21, SRS20, etc) during normal operation, is to hold the top two buttons down, just until display flashes - this will reset the electronics.
Secondly, if the top two buttons are held down for longer (8 seconds) the display goes blank and will show any error messages in the form of DASHES
I have experimented with unplugging air or frost probes - and the error code you get -on a blank screen is different parts of the last digit lighting up.
Example: when i disconnect the fridge air-probe, shut both doors, hold down top buttons around display - The SIDE of the last "8" digit lights up ! ...strange but true.
But, I need to know what it means when the BOTTOM of the "8" digit lights up"
I am still trying to find a list of the error codes the lines refer to but so far my unit is working fine.
Angus
Sep 21, 2010 | Freezers
Model g22012
If its the digital display with I think 2 or 3 buttons, then you cannot re-program the control.
It is factory set and I have never been able to get any clear answers from Traulsen on the steps to re-programming it for a different setting.
Best advice I can give you is to contact Traulsen directly and ask for tech support. Once you get them on the phone, explain that you just purchased this cooler/freezer and you need a control that suites your needs. They should have one that is pre-programmed to your needs.
Jan 07, 2010 | Traulsen 46 cu. ft. Upright Freezer G22011
No digital readout
Hello derek143
You Said,
I have a Whirlpool upright freezer AFG 371/H there is a digital display and lights and buttons, on/off temp alarm etc running across the top of the freezer. None of this works but the freezer is still freezing. i have no idea what the temp is.
I think you should try unplugging it for 5 minutes and then try restarting it and see if it reset.
Sep 11, 2008 | Freezers
Won't run
The first thing you need to check is if the contacts are getting power to the coil. A safety may be preventing the compressor from coming on. Read the wiring diagram. If the digital thermostat has a display, I would rule out the transformer. But I'm guessing at this point with what little info.
Feb 01, 2008 | True 49 cu. ft. / 1388 liter Commercial...
Frost free fridge/freezer
that is an error code call manuf. for solution
Dec 06, 2007 | Freezers
Freezers Logo
47 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
