Question about Remington Electric Chain Saw
Chain saw oil I have a MOD150 remington 14" electric chain saw M15014us. It does not seem to be getting any oil even after repeatedly pushing the cap. How can I fix?
  • 10865 Answers
SOURCE: chain comess off bar ever7ytime u cut
put the chain on and adjust the chain tension so that it is a little snugger than it has been. that should solve your problem. if it doesn't it may be time to replace the chain bar.
Posted on Feb 12, 2009
  • 188 Answers
SOURCE: Remington Pole Saw Model # 106890-020 - Chain Oil Cap broke
Call Master Parts at 1-800-446-1446, or go online at www.masterparts.net. They have the part (107512-01) you need. I hope this helps...
Posted on Apr 27, 2009
  • 188 Answers
SOURCE: what kind of chain oil to use for a 10in remington electric
According to the manufacturer... "Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil." So, I suggest for any Remington electric chains saw not to use bar and chain oil. I hope this helps...
Posted on Jul 07, 2009
dontbother10
  • 2220 Answers
SOURCE: What type of oil do a Remington 14
Use any commercial bar oil. It is available at most home centers and hardware stores. I use the Ace Hardware brand. Bar oil contains tackifiers to attempt to keep it on the bar and chain, the parts that need lubrication. HTH
Lou
Posted on Oct 10, 2009
dontbother10
  • 2220 Answers
SOURCE: Need chain oil resevoir for Remington electric
I suspect you did an on line search, we can do no better. Remington has ceased production. Parts availability is limited to what is on hand. It might be advisable to save the money you would expend for parts and put it toward the purchase of a new electric saw.
Poulan has been in business a very long time and offers 8 different models. Some can be found at Lowes. HTH
Lou
Sooner or later you will encounter a part that isn't available for your Remington. Yours may be worth more as parts than as a complete assembly. eBay?
Posted on Oct 11, 2009
There is a compartment to add some kind of liquid. what do i have to add and how much?
if it is electric saw the reservoir is for bar oil the oil lubes the chain where it slides on the bar and needs to be topped off while using
Jun 22, 2012 | Remington Electric Chain Saw
I have a Remington 14' Limb n' Trim electric chainsaw. There is an oil reservoir (I think - it has a little rubber cap) and I am not sure if it is for motor oil. If it is, what type of oil should I use?
jmccabe2465-
The reservoir is for bar chain oil, which all chain saws require to allow the chain to operate smoothly and reduce heat build-up from friction.
Hope this helps.
Regards,
DIYpro
May 04, 2011 | Remington Electric Chain Saw
What type of oil does remington 3.5 electric saw uses?
You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 (30 weight non-detergent oil) with additives to make it adhere to your bar and chain.
An excerpt from a Remington manual follows (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F.
• Colder use SAE 10 oil.
• Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
• It is normal for oil to seep when saw is not in use.
• Empty oil tank after each use to prevent seepage.
Some manuals go from page 6 to page 14. This one is very good.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 25, 2010 | Remington 16" Electric Chain Saw
Remington electric Pole Chain saw - what type of oil do I use?
-Colder use SAE 10 oil.
-Warmer use SAE 40 oil.
take a look on amazon: Amazon com SAE 30 motor oil
Apr 24, 2010 | Remington Electric Pole Saw
What kind of oil uses on remington 14" electric chain saw?
You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 with additives to make it adhere to your bar and chain.
FILLING OIL TANK
1. Remove oil cap.
Lou
Thank you for using FixYa.
Apr 11, 2010 | Remington 16" Electric Chain Saw
No manual / chain came off ; need to put back on model ld4016aw remington
I couldn't find your model number but did find an "Owner's Manual" for a M15014US. The chain installation should be similar.
http://shoppingcart.msservicecompany.com/Default.aspx
In the "Search for your unit by Model #:: window type & enter "M15014US" search.
Click the "View Model" link to the right of "M15014US - Remington Electric Chainsaw"
Click the "View Owner's Manual" link.
The chain atop the bar needs to be like page 16, figure 25 or it is installed backward.
You can save the Owner's Manual and the Illustrated Parts Diagram. I recommend you do. HTH
Lou
Nov 03, 2009 | Remington 16" Electric Chain Saw
I have a Remington Electric Chain Saw and have lost the manual. Where can I get one? Model No. M15014US 14'' Bar 114731-01S Chain 114735-01S I have tried searching the Web for one and can't get a...
Remington.com
Enter M15014US (your saw) in the “Search for your unit by Model” window. You can find both an Operator's Manual and IPL. I recommend you download both.
Item 4 lists available bars for your saw, a 14" bar for your saw is pn 114731-01S, $17.85 if available.
Item 5 lists available chains for your saw, a 14" chain for your saw is pn 114735-01S updates to M14SC
, $12.95 if available. You can probably take your chain to a neighborhood chainsaw shop and have a replacement made cheaper.
Remington has ceased production and replacement parts are limited to what is on hand. HTH
Lou
Oct 29, 2009 | Remington Electric Chain Saw
Replacement number for a model # 150-14US
A 14" bar for your saw is pn 114731-01S updates to pn M14SB, $19.99 if available.
You can find both an Operator's Manual and IPL here:.
Enter M15014US (your saw) in the “Search for your unit by Model” window. I recommend you download both the Owners Manual and Illustrated Parts Breakdown
Lou
Oct 17, 2009 | Remington Electric Chain Saw
Oil
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
May 25, 2009 | Remington Electric Chain Saw
What type of oil do I use for a Remington Electric Pole Saw?
Mar 13, 2009 | Remington 16" Electric Chain Saw
Remington Electric Chain Saw  Logo
53 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
