Question about Garden
Troy bolt self propelled 675 series I changed spark plug oil and new gas it was working great n just stop won't turn on again. When I pull cord sounds like it wants to start but doesn't. I have clean air filter as well
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Try putting in the old spark plug. new arts may be defective
Posted on Jul 15, 2013
  • 93 Answers
SOURCE: BRIGGS/STRATION 675 SERIES, 190CC SELF PROPELLED
Rust on the Flywheel and Magneto wire brush off., Pluged Fuel Filter or Bad Gas.
Posted on Sep 14, 2009
  • 93 Answers
SOURCE: Honda, self propelled lawn mover. GVC 160. Used
Could be Flywheel Key, Coil and Do buy a New Spark Plug. Make sure Head bolts are tight.
Posted on Sep 15, 2009
SOURCE: Troybilt self-propelled mower - model 556 won't start
pipe from carb to engine broken. couldn't tell until covers & fuel tank removed. also part of deck holding engine came apart on mine. due to excessive vibration???
Posted on Mar 16, 2010
SOURCE: old craftsman pull cord
Your carbs main jet is blocked most likely.
Take the carb bowl off and look at the bolt near the top of the threads.
You should see a very very small hole. If you can see through it you need to clean it with a fine strand of metal wire.
Also work the float up and down to make sure it isnt stuck or unable to flow when the float hangs free.
Put it back together and try it out!
Good luck and be careful!
Posted on Aug 03, 2010
daneinwv
  • 124 Answers
SOURCE: I have a Craftsman 625
My name is Dane and I am going to try to help you solve your problem.
I believe that you have clogged jets/passages inside of your carburetor. This can happen when an engine gets little use, allowing the fuel in the system to get old and begin breaking down. If fuel is left in a Carb for more than a year, it can eventually turn into a jelly like consistency, and clog the fuel system. What I believe is happening in your case is that the float needle inside the Carb is not allowing gas to enter the carb fast enough to keep up with demand. That's why it will run for 10 minutes and then shut down. After it sits for a while, the float bowl slowly fills back up and it will run for 10 more minutes.
Now for the bad news. This is an extremely difficult carb to work on. It is all I can do to get these Carbs off an engine and back on again to clean them. They are tough because you have a big air filter housing and 2 long bolts with gaskets and then the carb itself and spacers, that you have to hold together as a unit and start the bolts holding the carb to the engine. If you are a good enough mechanic to do this, you will already know how to do it. If not, I honestly suggest you take it to a shop and let them clean it for you. A new Carb isn't all that expensive, so you may want to consider just letting them replace it instead of cleaning.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thank you! Dane
Posted on Dec 04, 2010
I have a troy bilt 690 series 190cc self propelled lawn mower that won't run. I have changed the carb, spark plug, oil, and gas. The fuel line is not blocked because when I pulled it off the carb it...
Pinch off or turn off fuel line to carb. Remove carb from engine. Remove carb bottom bowl. Observe screw that holds bowl to carb if it has a whole thru it clean it out with a bread wrapper twist after you peal back about an inch of wire. Remove float and needle, use same wire to clean out port. Use same wire to clean out center fuel pick up port in center of carb. Ensure upon reassembly the float is free to move. Float up no fuel flow, float down fuel flow.
Jul 30, 2013 | Troy Garden
Pull cord hard to pull and won't reel back in
should never pull cord unless correct amount of oil is in it !, My advise take back to sears and buy a Toro ! Did you have the blade break lever pulled back ?
Oct 11, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Troy Bilt self propelled lawmower won't stay on. It's been fine this year, today all I did was add gas and added the mulch shoot. I turned it on, it was fine. Started mowing, got halfway across...
The trouble you are experiencing could result from several different things. First, check the oil when the engine is cold and completely settled in the sump. You do not want to overfill the engine with oil. If the oil is on the full line (not above it),then the low oil sensor is not shutting off your engine. The oil level should be exactly on the full line-not above or below. Second, remove the spark plug and clean it with a small wire brush or sandpaper. If you are unsure about how to clean the spark plug, replace it with a new one. If both of these procedures have been performed and the mower still doesn't run correctly, the problem is almost certainly with the fuel supply, fuel quality and/or carburetor.
Jul 30, 2017 | Troy Bilt 5.5hp Self Propelled Mower
The pull start cord will only move about 3-4 inches and then it stops and then cord stops, Troy built- Briggs/Statton 21 inch self-propel lawnmower.
The mower's drive shaft may need to be lubricated. If you turn the mower over and try to move the blade by hand (with the mower off, of course) does it move, or is it hard to move? If it's hard to move or it won't move at all, lubricate the shaft by squirting some WD-40, 3-In-1, or other lubricating oil onto the drive shaft where it meets the chassis of the mower. Squirt enough oil to cover the circumference of the drive shaft, then try to spin the blade again. It should at least spin a little bit now. Squirt some more oil and spin the blade again, until the blade spins easily. Then turn the mower back over and try to pull the start cord -- it should pull normally now.
Jun 05, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Troy built 675 series will not start and has gas . Ive checked the spark plub connection and all is good .
have you checked the quality of the gas? is it old from last season? open the gas cap and smell the gas,does it smell like varnish? If your gas is bad it wont start because it has lost it"s flamability.also you don"t what to use old gas because it can damage your engine by causing your valves to stick or freeze up...If your gas is bad you need to drain your fuel tank and carb and replace it with fresh gas..You might want to go and get some fuel stabalizer at the auto store or wal mart and add it to you fuel can you use to fill you mower. That way your fuel will be good for up to a year when stabalizer is added to your gas..Have you checked for a spark at the spark plug? remove the spark plug from the motor, plug the spark plug back into the plug socket and lay the spark plug aganst the muffler, pull the pull start cord and look at the end of the spark plug for a bright blue spark. You might want to do this in the shade to be able to see it. If you don"t see a spark , i would try a new plug first and see..if still no spark then your ignition coil has gone bad,that is the whole unit from your spark plug wire to the coil..check these items first,,,
May 26, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have changed the air filter and bought a new spark plug but my troy built with Honda 160 cc engine will not start.
there is a possibility the c oil is bad, pull the plug and with wire attached pull cord to see if any spark
Aug 07, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Jul 18, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Jun 26, 2009 | Garden
Troybuilt 675 hp lawn mower doesnt start
self propelled not working on troy built 675 series bought 5/08. The belt is still on.
Jun 17, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
120 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
