Question about Yamaha Music
G# and A# Ghost Notes!
The D note in an octave, when played along with D, G and A of the immediately above octave, gives out a sound that includes the sound of a G# (between the G and A of the octave played). I can hear the G# even though I haven't touched this key. And it is always very loud, in maximum velocity (I believe). The same happens when I play this combination in an octave below and also for the combination E3 E4 A4 B4 (which is a step higher than the previous combo). When I play "E3 E4 A4 B4" the ghost note is A4#. For any other combination, everything is normal. I have a digital grand piano yamaha DGX-640.
    Problem Solver:
  • 6 Answers
First try looking in your transpose settings. Refer to your manual to see if any arpeggiation/unnatural chord settings were inadvertently created by you or made by another user. If you believe it is a software problem you can not solve, back up your memory bank, remove your memory card, and hard reset your keyboard. Insert your memory card and check to see if your problem still exists.
If it is a technical problem, it sounds like you may need to get it checked out by an engineer/repairman. Sometimes when a digital keboard's keys collect too much dust/debris they can trigger multiple keys that aren't being pressed. Think about it like a key getting caught on an upright piano and pulling back the hammer next to the one that was played. A digital piano works off of one or several printed circuit boards or PCBs. The printed circuits usually can not short circuit because the wires and circuits sit in fixed positions. If an alien conductive fiber or series of conductive fibers connects a conducter to another, or if there is any humidity inside your piano it may cause circuits to misfire when a circuit is connected in the area. This could explain why notes you are not playing are being activated in the area in which you are playing.
If you are in a humid area and you suspect that this may be the cause you can attempt to draw out the humidity before getting a an expensive diagnostic done. Find a box large enough to house your keyboard. [If it is on a stand take it off and] place it inside the box. Cover the keyboard with plastic wrap (so as to prevent any foreign objects from getting into the instrument) and very carefully surround the piano with white rice. Remove the plastic wrap, close the box and leave it alone for a few days. The rice draws out any moisture from the electronic components. Very carefully (again so as to avoid getting any rice inside it) remove the keyboard from the box; remove any dust from the body, face, keys, and other components. Try your keyboard now. If humidity/moisture on the PCBs was the problem it should be solved. If not it is time to take your piano for a tune-up.
Hope this helps!
Posted on Jul 13, 2013
4 Suggested Answers
  • 5603 Answers
SOURCE: A bought an Yamaha DGX
The function setting is for the PANEL sustain (Page 68 of your manual)
The other method of sustain is by footswitch or pedal option. See page 13.
If you use a footswitch, it needs to be a normally open contact type. If you plug a Roland type in, it is opposite polarity and will sustain UNLESS the pedal is pressed. Make sure nothing else is plugged in the sustain jack... headphones that are inadvertently plugged in there would sustain.
Posted on Mar 07, 2011
  • 5603 Answers
SOURCE: as i play notes on
Check if you MIGHT be in a "guide" or learning mode. Some Yamaha synths have a mode that will play and then wait for you to hit the right key before moving on. If this is not the problem, a fix is not DIY and will require repair. I assume you are NOT using MIDI as in that case it is called "dreaded MIDI drone" and is due to data looping back into the unit which is an external fault.
Posted on Aug 18, 2011
rokrgyrl
  • 6 Answers
SOURCE: playing certain 3 or 4 notes at a time causing sound of one or more extra notes.is there a quick fix?
Have a professional tune it for you. It may be that some strings have loosened/tightened.
Posted on Sep 14, 2012
Yamaha YPT 400: ALL re are not working
Hi, If by "re" not working you mean note D then try the following.
Keyboard off, hold down top C key while turning on. This factory resets. Does D key now work - if not. Has it ever worked - if not then it could possibly be the ribbon connector between the keyboard and the motherboard. If one of the cables gets bent then this would stop all notes associated with that connection to stop working. This will only have occured if the keyboard has never played these notes or if it has been taken apart.
You could also try the self test mode : Keyboard off, hold C#,F, G# in the 2nd octave up whilst turning on, cycle through tests to sound if it plays all the notes one at a time then the sound chip is ok and it points to keyboard switching. If test mode does not come up in 2nd octave try 3rd octave ( cant remember which one it is from memory )
Let me know how you get on.
yamaha-ypt-400-all-re-not-working#solution-section-o0etyz1v3mt3zyequ52mc4su-5-2_0.jpg
Feb 07, 2016 | Yamaha YPT-320 Keyboard
When I hold in C and then press Csharp in the same octave,the C-sharp goes silent.It goes the other way around as well.They work when I tap them separately.And that problem occurs in every octave of the...
It sounds like the piano is in mono setting. One note at a time can be played. Find out how to set it at poly mode, allowing multiple notes to be played at the same time.
Jul 09, 2014 | Yamaha P-155 Electronic Piano
Playing certain 3 or 4 notes at a time causing sound of one or more extra notes.is there a quick fix?
Sep 06, 2012 | Yamaha P95 Digital Piano
Hi, The C note in 4th octave, when played immediately after or along with D and B of the 3rd octave, has a touch response problem. It is terribly lower than the level set and to your surprise, gives out a...
The key contacts are dirty. Each key has two contacts to implement VELOCITY sensing. When a certain one fails to contact, then the note is sounded at full volume. The contacts are conductive rubber pills pressed onto circuit traces. Clean only with 99% isoprophyl alcohol and Q tips very gently. It takes a LOT of dis-assembly and care to do this. It might be better to take this to a repair shop. There is a possibilty that a liquid was spilled into your keys as well. Cleaning is the answer.
Jul 02, 2011 | Yamaha Music
I'm using the Yamaha P-85 Digital piano. Unfortunately it has lately had some problems. When I'm playing to notes next to each other (especially e and f (mi & fa) or b flat and b (si & si...
In playing fast you have to make sure to release the note fully and let the key come up. These keys have TWO contacts that are used in the scheme to measure note velocity. If BOTH contacts don't open, the note will NOT re-fire. The second symptom you have written would be a characteristic if one of the disconnect diodes has shorted. These diodes direct the strobe signals that scan the matrix of key contacts to avoid other octaves responding when multiple keys are depressed including those in other octaves. Servicing of the unit is required. It is unlikely you have the tools to DIY this problem. ONE THING to try is to tip the unit and gently tap it to see if some debris MIGHT have fallen in that may be shorting some of the matrix connections.
Apr 25, 2011 | Yamaha P85 88Key Portable Digital Piano
I plug two roland pk-5a to have 1 octave above the other one but the problem is I can't play in the BASS MODE or MONO MODE with the HOLD function on and stop the note I play on one unit when i play a note...
If you have two MIDI sources that you send on the same MIDI or to the same MIDI sound generator you have to use a "MIDI MERGER" or you will get notes stuck on. A MIDI merger assembles complete messages before sending them to their destination. Without it, the messages are mixed which makes them garbled.
Mar 24, 2011 | Roland PK5A MIDI Controller
Roland fantom g8, problem, The last 2 octaves do not issue sound
Read page 135 regarding the note range settings. Look also for keyboard split information. You may have the keyboard set to NOT play notes in the top octaves for the particular voice you are using.
Feb 23, 2011 | Roland FANTOMG8
When I play my Bass Clarinet, the bottom joint won't play the higher octave. It will play everything except the 3rd octave B-E. I can't find any leaks.
usually If a certain note doesnot play the note before it is not seating correctly. Check all pads that they are sealing behind the bad notes, also make sure the octive key is sealing.
Feb 11, 2011 | Yamaha 5C Standard Bb Bass Clarinet...
I have a 6 month old keyboard and have found that middle octave A and lower octave note C are sounding really off when played together. What could be the problem? The store where I purchased it has...
Thisis hard to troubleshoot... The keyboard insynths are usually scanned as a matrix... If a disconnect diode has failed, then wrong notes can be triggered. There is USUALLY rows of the diodes on the circuit board where the keys hit. There are usually TWO contacts per key in order to sense key velocity. The lkey contacts are usually conductive rubber pills pressed against circuit traces under the keys. One sometimes needs to clean these contacts using 99% isoprophyl alcohol and Q tips.
I would do further testing of ALL combinations of notes played together to see if possibly any others show up as that could point to a particular failure.
Oct 27, 2010 | Casio Ctk574 61 Key FullSize Portable...
Yamaha Electronic Piano- certain notes malfunctioning
Either the first or second closure matrix line for the "A" keys is bad.
This may be a cracked or shorted circuit board.
A bank of diodes is used to prevent sneak electrical path if more than one octave has notes pressed.
First thing is to clean ALL the key contact areas and the conductive rubber pills with 99% isoprophyl alcohol.
This involves dis-assembly of the key area. If you are not competent in electronics, best left to a pro shop.
The keys are scanned in a matrix, two contacts per key and all the individual notes are in common (all the "A;s", "B's"...) And each octave is strobed for the first set of contacts and then for the second set of contacts. an the whole octave is read in parallel.
The reason for two contacts is one closes first and then the other as a key is lowered. The time between these is measured and is the note VELOCITY which for a piano controls the loadness of the note. IF ONE of the two fail, the loudness will vary as yours does.
Nov 24, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Music Logo
112 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
