Question about Garden
Honda gc190 Engine starts fine but when I try to wash the governor will not apply any power. I can over ride by pressing governor manually and lots of pressure. Wy would the engine governor be restricting engine RPMs.
3 Suggested Answers
  • 174 Answers
SOURCE: Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Posted on Aug 18, 2009
  • 151 Answers
SOURCE: Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
Posted on Dec 24, 2009
Govoner arm came off how to put it on in the right place
thats a honda engine
Search Results
Honda Engines ' GC190 Owner's Manual
engines.honda.com/parts/ownersmanuals/gc190 Download or purchase Honda Engine owners' manuals for the GC190.
Honda Engines ' GC190 4-Stroke Engine ' Features, Specs, and ...
engines.honda.com/models/model-detail/gc190 Official specs and features for the Honda GC190 OHC engine. ... is a small four-stroke gas engine designed for premium residential use. ... Owners Manual.
[PDF]honda 6hp gc190 repair manual.pdf
www.publicwalls.org/honda/honda-6hp-gc190-repair-manual.pdf
Apr 08, 2016 | Horizontal Engine 6 Hp Ohc Gc190mha2
How to adjust output voltage on Honda 3000 generator
Hal, you may be able to adjust some what by changing engine RPM(throttle *****) and playing with the governor if need be with no load and with load.
Portable generator voltage regulator
Onan generator adjustment run speed voltage
https://mtspowerproducts.com/admin/data_sheet/SS321Manual%20II.pdf
Mar 27, 2016 | Powerboss 020309 3000 psi 2.5...
How to remove pump from a powerboss 020309 power washer
Remove the 4 mounting bolts and it will slide of the shaft if it's not rusted. If it's a little rusty it will take time and some good rust buster applied between the pump and engine onto the engine output shaft. Hope this helps, it's not always the easiest thing to do.
Sep 29, 2013 | Powerboss 020309 3000 psi 2.5...
Honda GC190 can't pull starter cord
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily then the valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Aug 29, 2012 | Honda Garden
Honda GC190 engine shuts down on my Karcher 3000 PSI PW
Well would you believe that I have the very same problem. I suspected that the pump was seizing up, so we tried the pump on another unit and it worked fine. On inspection of the motor we found the cam (which also operates the decompression mechanism) was worn out. It's made of hard plastic. It is only about 7 dollars too, so cheap enough to fix. I have mine ordered now and feel pretty confident that that should fix it.
Aug 13, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
