Question about Pool & Spa
Kreepy krauly My Kreepy just tracks around the corner, at 10 ft per minute, where the wall meets the bottom of the pool. It doesn't climb the wall and therefore does not move back and forth across the bottom. I have roughed up the pad and replaced the inground seal. I have also replaced the swivel cone and beariing but to no avail. I have confrimed the balanced of the water ans shocked the pool to eliminate any algae Still no soap. Any other ideas? Richard
SOURCE: KREEPY-KRAULY Ties itself into a knot while cleaning.
We removed 2 portions of hose located at the Krauly end, and attached those at the filter end, then we took the 2 portions located at the filter end, and placed those at the beginning of the Krauly end.
Apparently the problem was that the 2 portions of hosing at the Krauly end had become "twisted" and continually enabled the Krauly to move in the knot tying direction. By replacing these 2 portions at the Krauly end with "un-twisted" portions from the filter end, this ended the twisting cycle.
The Krauly has been running for 48hours straight now without a single knotting episode.
If we see the knot tying direction beginning again, we will repeat these steps, continually replacing with un-twisted portions.
At 1st we thought we needed to purchase some new tubing, but we didn't have to, only needed to move around some hosing.
Posted on Jan 05, 2010
  • 11 Answers
SOURCE: Hi my kreepy krauly wont stay flat on the bottom
Do you have any hose weights fitted to the kreepy hose? If you do,take it off and see if it makes a difference.Is this happening while the kreepy is operating?
Posted on Mar 27, 2010
  • 331 Answers
SOURCE: My kreepy won't move across the bottom of the
Replace the flapper valve with a new one, this piece wears out over a season.
Posted on Apr 14, 2010
  • 331 Answers
SOURCE: My kreepy Krauly will start up and within 5 stops working.
If it is a year old, replace the flapper valve. Also check your water flow and make sure it is adequate. These units are subject to wear on the foot and flapper and these should be changed each season
Testimonial: "Great thank you for this info...I believe that I need to buy another type....too many problems with this type of cleaner."
  • 331 Answers
SOURCE: Kreepy Krauly keeps getting stuck on the pool wall
Manufacturer may have an additional accessory bumper you can get to prevent this. Depends on your model
Posted on Apr 16, 2010
My kreepy krauly wont clean the deep end of the swimming pool.
Your situation is unusual in that most of the time these will stay in the deep end and not get to the shallow end. Make sure that your hose is the proper length and the hose weights are in the right positions
Up to 4 feet water, 1 weight at one foot away from Kreepy
4-7 feet water, add a second weight at 6 feet from Kreepy
7-12 feet water add a third weight at 10 feet from Kreepy.
It can take some trial and error to get the Kreepy to cover the whole pool. This includes adding or removing hose sections, and adjusting the pool return "eyeballs" to different directions.
Feb 21, 2014 | Universal Kreepy Krauly In-Ground Pool...
Kreepy kraully not cleaning complete pool
If the pool hose has been connected to the Kreepy Krauly in the one position for a long time, the pool hose gets set is a position so the kreepy Krauly travels ith same path all the time. Try rotating the pool hose 90 degrees and or change the angle of the hose connector in the skimmer box.
Mar 07, 2012 | Pentair Kreepy Krauly Inground Automatic...
My Kreepy has a Starfish seal on it. It is being used in a pebble tec pool. I bought it new less than a year ago. Here are my problems...The Kreepy is getting stuck by my stairs (they are more like...
If the cleaner is getting stuck on objects (steps, ladder, corners, benches, etc), you need to remove the dive float restrictor and install a wall climb adjuster. It is part number K12065. Anyone that sells Pentair products should have one. This will keep your pool cleaner from becoming stuck. It might also help with the seal problem, but that is most likely something caught in the flapper. Check to be sure that the pool cleaners getting proper flow and that the flapper is clear of debris.
Jul 09, 2011 | Universal Kreepy Krauly In-Ground Pool...
Kreepy bull shark gets stuck in the corners and stains (dark brown/black) the pool where it is stuck.
There are several things that you can do to prevent these pool cleaners from sticking at steps and corners. First, your return line water flow might be positioned incorrectly to force the cleaner toward the corners. Check for this and use the eyeball diverter valve to redirect the water flow if necessary. Make sure that your automatic regulator valve is installed properly and free of debris. Make sure that you have proper hose balance (the cleaner should set at a 45 degree angle to the pool bottom). Adjust the hose weights if necessary. You may need to add a wall climb restrictor or a ladder guard. If none of these correct the problem, consider adding the Thruster, which aids in random pattern coverage by automatically repositioning the hose to help free the cleaner from obstacles.
Apr 14, 2011 | Universal Kreepy Krauly In-Ground Pool...
I have great water pressure in my pool, but the minute I attach my Kreepy Krawly, the pressure drops and there is a large vacuum in the pump reservoir. the Kreepy hardly moves at all thereafter.
It sounds like your you might not have all of your suction lines closed. Check to ensure that the main drain and all suction lines are closed, except for the suction line to which Kreepy Krauly is attached. If this is not the problem, it could be that the pool pump and filter system that you have may be too small It should be capable of providing at least 25 gallons per minute. These are common issues with these pool cleaners.
Feb 02, 2011 | Universal Kreepy Krauly In-Ground Pool...
Hi my kreepy krauly wont stay flat on the bottom of the pool???
Nov 21, 2009 | Universal Kreepy Krauly In-Ground Pool...
My kreepy krawly stays on the side of the pool and wont clean the bottom.I have placed the weights in the correct position. Any suggestions?
Try no weights.
Try weights in a incorrect position.
How is the it it steering it to the sides and keeping it there?
Sep 30, 2009 | Universal Kreepy Krauly In-Ground Pool...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
