Question about Frigidaire GLEQ2152ES Electric Dryer
Buttons, sounds, lights all go on but the dryer will not dry
  • Official Brand Answer
  • 4,342 Answers
Hello toofdr - Often this occurs because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn on but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Posted on Jul 15, 2013
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 | Dryers
Samsung dryer only dries on timed dry cycle. And where is the light bulb in the dryer??
sounds like the timer is sticking in some cycles and works only in timed dry? as the points in other cycles are seized and stuck close? as for the bulb should be along the back wall of tub or near door
Feb 13, 2015 | Samsung Dryers
I have the LG Model# DLE1101W dryer. The dryer will power up but when I go to start the dryer after I put a second load in, I get a series of dinging sounds when pressing the start button and the drye
Id like to see if I could help you so you will have to use more definitive terms, "Start" I'm guessing that you mean that the drum doesn't turn? (the lights come on and you push the start button and the drum does not turn) If that's the case I would start with the door switch, Best to start with the most obvious first. Try jumping it to over ride wait your response
Sep 17, 2014 | LG DLE1101W 7.3 cu. ft. Ultra Large...
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Aug 08, 2013 | Whirlpool Cabrio WED5550XW 27" Front-Load...
Stops before clothes are dry
Sounds like a motor going out . You need to replace the motor .
Jun 29, 2010 | Kenmore 65924 Electric Dryer
General Electric Heavy Duty Dryer willnot start when start button
WARNING: High Voltage may bzzt you... careful.
Your dryer thinks that it is at the end of a dry cycle.
First thing to do is disconect the dryer from the 220v mains and let it sit for about 10 min.
then, spin the timer four or five times around and then stop it at a TIMED dry cycle, not an automatic cycle. (example: 60 minutes).
Plug unit back into the wall.
SLAM door on unit and press button again...
Mar 12, 2009 | Dryers
Dryer doesn't work.
Dry will not start, light is off. Power is on and working fine to dryer - is there a reset button?
Performa oversized Capacity Plus Model #PYE3360AYW .
Jan 18, 2009 | Maytag MAV3905EWW 13 Cycle Washer
Control lock stays on and nothing else works on the panel. No other lights, no other controls. Disconnected power overnite but nothing changed.
The sound button is the button that you wish the sound to go on when the load is finished drying. Thanks for the advice, I was worried I just bought them and already broken.
Nov 17, 2007 | Whirlpool GEW9250P Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
53 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
