Question about Dryers
Whirlpool WED9200SQ0 got error code f01 - Dryers
2 Suggested Answers
  • 17 Answers
SOURCE: Error Code
Here's some magic help on the dryers: I have a duet sport- Whirlpool hides the complete service manual inside the cover at the bottom front of the machine- remove the bottom 2 screws, drop the cover & you have all test & service instructions--- (:
Posted on Dec 16, 2007
How to reset whirlpool duet dryer model WED9200SQ0
Hello, sorry that you are experiencing a problem. To reset the Dryer we would recommend unplugging the unit of turning off the breaker for 2-3 minutes. If this does not correct the issue we would recommend having a certified technician out to correctly diagnose the issue. If you would like further assistance you can send us your name, address, phone number, model/serial number and the date of which you purchased the appliance to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 18, 2017 | Whirlpool Washing Machines
Whirlpool Duet dryer model WED9200SQ0 shows error code F01 what does this mean and how do i fix it
F01 is a main board fault...
https://youtu.be/n_e7CcpfCNk
If the main board is good then there is also a fuse which may have blown.
https://youtu.be/HGegabpM3jM
You will need a soldering iron... if you feel capable then proceed of find someone who is..
It's actually quite easy to do...
Apr 17, 2017 | Whirlpool Dryers
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
What is fault code F01 What does this code relate to?
either that or f51 is a thermal shutoff fuse issue
Aug 18, 2014 | Whirlpool Dryers
Error code F01 E02
For how long did you unplug the power cord? If it was under 5 minutes, unplug it for longer. Check if that clears the error code. If it doesn't, the motor control unit needs to be replaced.
Please double check your model number to get the correct part. Most of the Whirlpool washers have model numbers that start with 3 letters.
I hope this helps.
Dec 20, 2013 | Whirlpool Duet GHW9150P Front Load Washer
MAYTAG 3000 F01 CODE
It's probably a weak or failed component on the board. It's a common issue on those machines and the Whirlpool Duets. It's usually burned at the motor relay or heater relay.
F01 error code flashes when there is a primary control failure.
The only thing which will solve an F01 error code is a new machine control board. These is a catastrophic control board failure. Nothing can correct it. The part number you require is W10205977.
Dec 17, 2013 | Maytag Dryers
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
Aug 18, 2011 | Washing Machines
Door will not open,error code f01
Problem isnt solved, seems like several people are having the same problem with whirpool front load washer with the F01....sad nobody will help you, they want money.....as high priced as those machine are............dont buy whirlpool......
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't start. Error code f01 shows.
Hi F1 means your CCU is bad and needs to be replaced sorry :( If you have any other questions please feel free to comment again. Mike e63dqt.jpg
Nov 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
257 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
