Question about Video Game Consoles & Games
I have a NETGEAR ( WNCE2001 ). I'm using it to
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 74 Answers
You may need to reset you router
Posted on Jul 17, 2013
SOURCE: IP address Problem when connecting to xbox 360 live
i had the same problem buddy. The problem might be that you hacve another system on the wireless network that uses that same IP address. This can cause a conflict that will prevent the xbox from logging on. Try deactivating other systems on the network to see if thats the problem
Posted on Sep 26, 2007
JOHNNY2hotty
  • 41 Answers
SOURCE: My Xbox 360 won't go ot the Internet
first i had the same problame with my x-box is you are using a hub router try putting it into pairing mode then search for networks on the x-box and this should resolve your problame
Posted on Apr 23, 2008
SOURCE: Can't connect to Xbox Live
yes
Posted on Dec 23, 2008
  • 265 Answers
SOURCE: xbox live 'internet' connection failing.
This will be why...
you need to wire the xbox to the router.
if you wire it to your laptop then its just a network connection between the laptop and the xbox.
Im not to sure but if you keep the same setup you may be able to share the internet connection.
Posted on Apr 06, 2009
  • 23 Answers
SOURCE: xbox 360 ics apipa
(this is a solution that i gave someone who had a wireless router... you will also need to forward the same ports even if you have a wired router...)
Ok... I have the best solution to this problem... Obviously you have wireless internet... so that means you have a wireless router... you need to login to the wireless router settings... usually it is192.168.1.1 that you type into your browser by default... if it is not192.168.1.1 in order to find your router address you need to click on start.... run... type in cmd... then in the command prompt type in ipconfig/all... your router address will be the number next to default gateway... put that into your browser and login to the router... dont exit the command box just minimize it because you will need it later...if you have not changed the password its usually either password...admin.... or nothing at all.... once you are logged into your router you need to forward the open the ports for your xbox 360 for it to be able to connect to xbox live with an open NAT... (meaning you can connect to everyone without problems) once you get to port range forwarding you are going to have to put in 6 ports for best performance... name them all XBL or XboxLive... and forward these ports... 87-89 UDP.... 3073-3075 UDP..... 80-80 TCP... 88-88 UDP...3074-3074 BOTH... and 53-53 BOTH... make sure they are enabled... find out what your start ip address is... i changed mine to 192.168.1.200with a maximum number of users at 50... (this will come in handy and i will tell you why later...) turn on your xbox 360 and go to network settings and manually change your settings... so if you have your ip address range from 192.168.1.200 - 192.168.1.249 like me... change the ip address of your xbox 360 to 192.168.1.240 (the computers that connect to your wireless router always take the low ip addresses... so setting your xbox 360 ip address to 192.168.1.240 will make it so there arent any ip address conflicts...) remember the box i told you to minimize? you are going to have to input the numbers in the command box into the boxes in the xbox.... 255.255.255.0 for the subnet mask...default gateway for the gateway... enter in th e dns settings... first one is primary... second one is secondary... save and you are done with that... if you have your ethernet cord hooked up from your computer to your xbox 360 click on start... control panel... network connections...click and highlight the network bridge and your wireless connection...once you have them both highlighted... right click... and click on bridge connections... and everything should work fine...
Posted on Jul 10, 2009
Firmware upgrade
Why the need for firmware upgrade?
The power light is green, it is working, the problem lies with your internet connection.
1. Check the cabling.
3. Check with your ISP as to what the problem is.
May 02, 2014 | NetGear Computers & Internet
Set up wizard for wnce2001
Try this link for solution http://support.netgear.com/app/answers/detail/a_id/14157/session/L2F2LzEvdGltZS8xMzI4NTM2MTc4L3NpZC9sM0F0cipQaw%3D%3D
Jan 31, 2012 | NetGear WNCE2001 Pre80211n Wireless...
Can i use my netgear adapter to pick up xbox live on a new xbox 360 from stealing my neighbors wifi signal
not really, as it can't share that signal with your xbox. It can only join their network. If you had a router, and you set it up to "extend" their network, then you could have your xbox connect to the router which would be on their network.
Of course this is illegal and I advise you don't do it.
Apr 22, 2011 | NetGear USB 2.0-Stick WiFi 108 Mb WG111T...
Can't get wnce2001 netgear adapter to work. Also have netgear wnr2000 router. Push and connect, I do have all green lights, but samsung tv states service is unavailable due to network interference.
I have a netgear wnce2001 universal internet adapter. It was previously configured to the wireless internet in home to work with Xbox. Just yesterday the WLAN line went out. Hooked ethernet and USB cable up to computer. Proceeded to the netgear wizard to reconnect adapter to network. Got as for as step 3 and then told that there is difficulty connecting to the existing network. Does anyone have any suggestions to help solve my current problem? How can I reconnect?
Oct 04, 2010 | NetGear Computers & Internet
I have a Netgear Wireless G router (DG834G) & Virgin Broadband
have u went threw the settings on ur xbox 360 for online? make sure all cables connected properly xbox can be tricky for that
Jul 16, 2009 | Video Game Consoles & Games
Xbox 360 netgear router
that happens alot when one or more device (for instance, the xbox 360 and a cpu) are trying to use the same ip address make sure you have the xbox 360 and all other devices (cpu's/printers) that are connected to the router set to aquire ip address automatically
Feb 05, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Networking an xbox 360 to my p.c
Turn on the 360 and on your computer, open up Media Player and check that the sharing is enabled and your 360 is allowed in the permissions.
May 17, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
23 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
