Question about Panasonic TX32LXD60 32 in. LCD TV
I have bought a Bose external TV speaker. Sound will not play through Bose and I am un able to turn the TV speakers off. Connection is ny Analogue cables
  • 54 Answers
SOURCE: Hooking up external speaskers to my Panasonic TV
you will need to buy a surround sound receiver. the new tv's do not have an external speaker jacks on them. you might also try a old stereo receiver hooked up to the tv's audio out jacks
Posted on Jan 24, 2009
Skizziks
  • 43 Answers
SOURCE: No sound from plasma to home theatre
First off it's always best to start from scratch when it comes to home audio. LoL. Many times I've been in this situation.
So with everything disconnected. You should have your HDMI, COMPONENT, RCA(R,W,Y)
HDMI and COMPONENT are the exact same thing and in all preference COMPONENT is far better thand HDMI for the pure fact that each wire is in it's own casing and insualted to avoid feedback from the other wires.
Anyways, with everything disconnected we begin
From you Cable/satellite box- Run your HDMI cable from you cable box to your HDMI 1 input on your tv.(If your speakers were to work on your tv you would automaticaly get sound and picture)
That should be all that you should be running from you cable box. Now that we have one thing running we go to the next thing.
From your TV run your audio out (RCA Red/White) to your amp. Usually your preference but more than likely your TV IN on your amp.
With your amp now set on TV, you should automatically get sound from your tv. and if your running an HD cable box even though your only running RED/WHITE to your amp, you will still be receiving Digital sound.
Most new amps Should have a digital input and if your running and 1080iUp this one RCA plugin will give you dolby digital sound from your dvd player to your amp. Then running a video rca up to your tv, will give you the picture, while the digital out on your dvd player to your amp will give you dolby digital sound.
It's a basic simple step to get sound. Like a continuing current. So just as long as you have your cable to -- tv -- home theatre. Everything should work. Otherwise I would go and check your cables and make sure they are not faulty.
I hope this confusing walkthrough helps.
Posted on Aug 31, 2009
  • 118 Answers
SOURCE: Connect Bose System to Panansonic TV
in the tv setup menu there should be an item that will allow you to change the volume from variable to fixed on the output of the tv
Posted on Dec 08, 2009
SOURCE: auxilliary audio connection
I don't expect a 2 channel amp would have a digital input such as optical. More likely you would be able to pull analog stereo (red and white RCAs) off the Panasonic and run to the JVC.
Posted on Dec 29, 2009
fkuk
  • 311 Answers
SOURCE: I have a set of external speakers that are about
do the external speakers have a amplifier or is it just speakers on their own?
forget the settings and connect your speakers using a phono cable to the:
prog out to audi amplifier teminal
should be in the bottom left of the connections pannal at the back
but this connection needs a amplifier
go here
http://service.us.panasonic.com/OPERMANPDF/TH42PX75U.PDF
for further details
most important page is 40 and 41
Posted on Jan 01, 2010
How do I turn off the internal speakers on a tv Sanyo DP42841
does the remote have a MUTE button ?that is the only OFF there is
Dec 31, 2016 | Televison & Video
Connecting tv external speakers
If you connected R/W RCA cables to the AUDIO OUT RCA jacks on the rear of the TV and connected the other ends to the TV AUDIO IN jacks on the receiver, you should be able to select an input on the receiver that will deliver sound to the Bose speakers. If you went to TV setup and selected external speakers, you directed output from the TV amplifier to external speakers which is not what you want.
Jan 27, 2014 | Televison & Video
Sansui hdlcdvd26s
see the diagram attached, you can have wrong connection. However clean the contacts and test the wires.God bless you
he speakers are not connected properly. Check the speaker connections. The sound level on the rear or center speakers is turned down. Adjust the sound levels. The receiver is not in the proper surround mode. Set the receiver to a surround mode. The speaker settings are incorrect. Check the settings as per the user's manual.41a9b9c6-64e2-4745-adf3-95fdac1fe686.jpgba7a1620-dfc0-4e45-8fea-6237135735f9.jpeg
Jul 26, 2013 | Televison & Video
Tthe sound wont play on my new vizio 3d tv
  1. Check your connection from the TV Audio output to the Bose Input, and make sure the TV is not muted.
  2. In the TV's Sound/Audio menu, configure the TV to output the sound to External Speakers, not the internal speakers.
  3. Make sure the Bose system is powered on, and not muted.
Mar 12, 2011 | Bose Lifestyle 48 System
I HOOKED UP THE AUDIO CONNECTIONS FROM MY CABLE BOX TO THE BOSE RECEIVER. THE SOUND DOESN'T SOUND MUCH BETTER THAN MY TV SPEAKERS. WOULD USING A FIBER OPTIC CABLE MAKE MUCH DIFFERENCE?
You don't state how you have connected it but even with an analogue cable the sound should be better than your TV speakers, unless you have fantastic TV speakers, so something else is wrong however yes it should be better with as the full stereo surround signal is (if supported by your cable box) is transmitted digitally over the cable, so any analogue problems such as bad connections etc will be eliminated. I would not however buy a cable until you figure out whether there is a problem with your cable box or the Bose, do you have access to another source and connecting cable you could try first? Also go into the cable box menu and check if the sound out is correctly configured. Please rate my reply. Thanks
Jan 03, 2011 | Bose 3 2 1 GSX System
Bose surrond sound not working...
Your TV may have a setting to make its Audio Output Variable or Fixed. That is, as you turn the TV's volume down or up it will either vary the output (as it seems to be doing in your case) or keep it Fixed so external electronics can still use it when the TV's volume is down or off. Some TV's do it another way - they have a selection to turn the TV's speakers OFF.
Feb 03, 2010 | Bose Cinemate Digital Home Theater System...
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
No sound from one speaker
techs are correct. sorry.
what type of TV are you using?
if it can be firmware upgraded via USB connection. that might do the trick.
May 15, 2008 | Bose Cinemate Digital Home Theater System...
Am setting up a bose GSX 3-2-1 home theater
Need to know the TV connections. On newer TV's there RCA jack connection or ext speaker connections. Usually the external TV speaker connections hook to the woofer and the rest of the speakers are connected to the woofer. The woofer acts as the sound system for the rest of the speakers. With this method you need to mute the internal TV speakers by a swiich on the TV or internal TV setup menus and select ext speakers.
Jan 26, 2008 | Bose Cinemate Digital Home Theater System...
Panasonic TX32LXD60 32 in. LCD TV Logo
18 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
