Question about Dryers
Maytag dryer pyg2300aww
What setting do I use to dry close?
michiganfan9
  • 179 Answers
SOURCE: my maytag performa gas dryer
clean your dryer vent going from the back of the dryer to outside also run a lint brush down where you put the lint screen in if this does not help replace your coils
Posted on Dec 29, 2008
  • 77 Answers
SOURCE: Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
Posted on May 12, 2009
jumptrout51
  • 3361 Answers
SOURCE: How to replace heating element Maytag Performa
Your model number indicates a gas dryer. It does not have a heating element. It has a glowbar igniter,a flame sensor and a gas valve. Either the glowbar igniter is bad or the flame sensor or the gas valve coils or the thermal fuse.
Posted on Jun 22, 2009
woodchuck789
  • 4070 Answers
SOURCE: Maytag model pyg2300aww gas dryer- spring
There is a spring in this diagram. Part 6. It hooks to the idler. It's the only spring I can find on the diagrams. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=PYG2300AWW&productCategoryId=0151200&brandId=3048 &modelName=DRYER&diagramPageId=00006&componentDescription=MOTOR%20&%20DRIVE&documentId=M0512356&blt=06
Posted on Oct 29, 2009
marka19
  • 1430 Answers
SOURCE: how do i change the dryer drum belt on a maytag
Try this free video www.appliancehelponline.com/servicemanual.html
Posted on Feb 26, 2010
My Maytag pyg2300aww will not shut off when I open the door,I just replaced the high limit and thermal fuse..Everything else is working fine..Thankx
I would take a look at the door switch, its a push button on the top of the door opening. The spring might have went, causing the switch to stay closed, hence it staying running
Aug 04, 2010 | Maytag PYG2300A Gas Dryer
Maytag performance pyg2300aww is making a screaching sound
HOW DO YOU CHANGE THE DRUM BELT ON MAYTAG DRYER MODEL PYG2300AWW
Nov 23, 2009 | Maytag PYG2300A Gas Dryer
How to replace heating element Maytag Performa gas dryer pyg2300aww?
Jun 22, 2009 | Maytag Dryers
May 12, 2009 | Maytag Dryers
Maytag gas dryer PYG2300AWW
If it acts that bad, I would try to find me a new dryer.
May 12, 2017 | Maytag Dryers
My maytag performa gas dryer model # pyg2300aww gets warm but takes four cycles to dry.
Dec 29, 2008 | Dryers
Maytag performa model#pyg2300aww takes four cycles to dry
how long is dryer vent run ? does it go up or out to the side ? Sounds like the dryer vent is clogged. A long run on your vent will also cause this problem with a small amount of lint. Try cleaning out your lint screen on the dryer vent they can get pretty caked up with lint. If you have a long dryer vent run post back the length and direction and I will get you the maximum length for your specific run. You may need a booster fan if it is excessively long or straight up as through the roof.
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
I have a Maytag PYG2300AWW dryer and would like to know how to instal the glider clip that allows the tumbler to pass over it to reduce friction.
When I turn the dryer on it hums and the motor doesn't turn. Is there a capacitor on the motor that might not be starting the motor
May 06, 2008 | Maytag Dryers
Dryers Logo
18 people viewed this question
Top Dryers Experts
