Question about Frigidaire 25 in. FDP750RC Free-standing Dishwasher
Tecnik integrated dishwasher 795/2
When i switch the washer on the water comes through the arms eventually but not very strongly, it manages to get the bottom arm to continually spin but not strong enough to get the plates clean and the water only trickles from the top arm and this arm does not move. I presume it must have something top do with the pump although it must be working as the water is continually spraying but with no pressure? please help thanks
  • 640 Answers
Make sure all filters are clean.make sure the wash arms are not cracked at the seam.if all that checks good you could have an obstruction to the pump.also check to see if you lose any water when running a cycle because the drain valve may be stuck open.the other possibility is that the impeller on the pump is worn or broke.
Posted on Aug 27, 2007
Dimensions for tecnik 795/2
This dishwasher was made for tecnik (moben/kitchens direct) by bosch. Any Bosch, Siemens or Neff fully integrated 600mm dishwasher will replace this machine.
Apr 08, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
TECNIK TDK 795 FAULT
is there the power supply still to the washer??
Mar 01, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Tecnik Integrated 795/2
Unfortunately you may have lost the controller or if you are lucky just a loose wire. You can get to all of this by taking the door cover off. If it is not a loose wire the control would be my next best guess. Sometimes they just go.
Sep 06, 2012 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Hi, We have Tecnik Dishwasher TKD 795/3 it wont seem to drain the water, we have tried to clear the pipes but they seem to be clear, Can you give us any tips on how to sort this problem out? Thank you
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Jun 25, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
I need to remove the furniture door off my integrated dishwasher
I have the same problem.I need to take off the door from the integrated dishwasher.I can see a possible screw on the either side of the door but difficult to visualise this to find out what kind of screw it is.
Can someone advise me regarding the method of take the door off the integrated dish washer.
Paul
Feb 11, 2009 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Water not draining
were is the drain plug located and how do we remove? help
Jan 25, 2008 | Frigidaire 25 in. FDP750RC Free-standing...
Tecnik built in dishwasher
These arms spin based on water pressure generated from the washer itself.
Run the washer. As soon as the washer is full of water and the wash cycle starts, open the door and verify that you have at least a couple inches of water in the machine. If there is not enough water in the machine, the pump will not be able to provide pressure. If this is the case, the filling sensor is malfunctioning and will need to be checked.
There's a pump that provides water pressure. It's at the bottom of the machine beneath the lower rotating arm, probably beneath additional plastics. Remove these two items and verify that there is no debris blocking water from reaching the pump as if this is the case, water pressure cannot be generated.
Good luck... let me know what happens, and please rate accordingly.
Nov 11, 2007 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Frigidaire 25 in. FDP750RC Free-standing Dishwasher Logo
288 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
