Question about Coffee Makers & Espresso Machines
Coffee bosch tca 5401
I have a bosch tca5401 and the brewing unit is stuck and stand-by button and steam button flash alternately...what can I do to fix it?
dahaka
  • 347 Answers
SOURCE: brew unit stuck
Hi molly girl.
You can try to clean your Brewunit. Most of the times when that message appears, it means the brewunit is dirty
You can have more info in the manual if you dont have it:
http://www.miele.co.uk/Resources/OperatingInstructions/CVA%20620.pdf
Posted on Jan 11, 2008
SOURCE: Keruig Coffee maker (B60)
Keurig alluded to the fact that it is the heating element that buring out and causing these problems.
Posted on Nov 01, 2008
  • 1089 Answers
SOURCE: Spidem Divina coffee machine
Hi
Remove the dredge drawer. Open the door. On the left side of the brewing unit, and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. If your brew group did not come out please give us a call.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,( it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Done
Posted on Jul 16, 2009
  • 5 Answers
SOURCE: When brewing, it steams and spits the water out
this is what happened to me, I didn't have the filter basket all the way down so the pot lid didn't open the valve that lets coffee flow so the coffee and grounds ran into the water resevior and plugged the filter, so I did the worst thing possible and took the filter out so the grounds got into the check valve that keeps the hot water going in the right direction. that makes it spit and sputter and brew slow.
after trying to flush it out forever I tore the metal plate on the bottom off and unhooked the rubber hoses (don't do this unless you have a needle nose pliers, you'll never get them back on) one should go to the brew head and the other is the water inlet, this has the check valve. you can tell which is which by blowing through them and seeing which one goes to the brew head. if you can blow through the other one the check valve is stuck open, I blew air into it with an air compresor and this forced the check valve shut and now it works fine. I know this is the same symptons as calcium deposits but I had cleaned it twice.
try flushing it with water first but sometimes it takes extreme measures
Posted on Sep 27, 2009
SOURCE: I've lost my manual for the Oster coffee maker
Pot needs cleaning. Fill reservoir with 4 cups of vinegar. Press the SELECT button until the red CLEAN indicator light turns on. Let it perk through. It will take 45-60 minutes. It brews a few cups, stops and then should brew the remainder of the vinegar. When the cycle is complete the light will burn off and the coffeemaker will turn off. Discard vinegar solution and run a couple of pots of clear water through. Hope this helps.
Posted on Mar 26, 2010
Machine is not starting right - brew unit gets stuck and if removed in order to reset the alignment of the gearing wheel in the machine, it does not align in order to get the brew unit back in place.
When the upper and lower, dregs box and descale light, are flashing alternatively, this means that either the grinder or the brew group motor, sensors or switches are not responding to the CPU or pwr board. This will need to be brought to a Saeco Service center for repair. I would not attempt to repair without proper working knowledge of the cpu and pwr system.
Apr 30, 2016 | Saeco Odea Giro Plus Coffee Maker
The brew group is stuck and will not come out
I hope one of this two solutions solve your problem.
1- The brew group is out of place. Turn the machine on. Close the service door.
The brew group is automatically placed in the correct position.
2-Coffee grounds drawer is inserted. Remove the dregdrawer first, then the brew
group.
Jan 15, 2011 | Saeco Odea Giro Plus Coffee Maker
Hello The lights on the front of the machine wont stop flashing so I can't press the cup symbols to make coffee. The hot water is coming out though through the steamer spout. Thanks!
Circuit Priming
When the machine operates for the first time and when
all the water has been dispensed, the machine circuit
needs priming. In this case, the 4 buttons of the control
panel will flash at the same time.
• Press the ON/OFF button . The 4 buttons will
flash.
• Place a container under the cappuccinatore.
• Open the "hot water/steam" knob by turning
it anticlockwise.
• Press the hot water button.
• Wait for water dispensing to stop.
• Close the "hot water/steam" knob by turning it
clockwise. Remove the container.
When the first priming ends, the warming up
starts. Before brewing coffee, water and steam,
please wait for lights 15 and 16 to be permanently on.
The machine is now ready to brew coffee and dispense
steam. Please see related sections for operating details.
Note: if priming is not completed, the 4 buttons
will keep on fl ashing. The machine cannot be
used.
Jan 14, 2011 | Saeco Nina Bar Espresso Machine
The alarm light to empty the coffe grounds drawer AND the descaling light flash alternately I cleaned the brew group. Machine comes ready, but when I press to make a coffee it comes back with alternate...
Hi, the problem with your machine is with the grinder motor (not working).As soon as you press the coffee the CPU senses the motor is out of circuit and the lights start flashing alternately.
You can test it by doing this. Press and hold the steam button and switch on the machine, you will see the lights going around in anticlockwise direction. Release the button then turn the dial to left (Min) and press the steam button the grinder should work. The dial on the right (Max) the brew group will come up..and half way it will come back to normal position. Press the coffee button in that position will work the pump. Servicecenter can fix this if the machine is less than 2 year old FOC.
Oct 10, 2010 | Saeco Odea Go
I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Mar 23, 2010 | Saeco Odea Go
I have a new Saeco Odea Giro Coffee Machine and have turned it on for the first time. I followed the instructions but the red alarm light is flashing and no "steady flow of water comes out of the wand". I...
Is it the red light flashing and the water button light also on? That means air in the system.If the flow of water is not steady, make sure water tank is fully push in.
The next thing you can check is the test mode which is not given in the manual.Hold down water button and switch on the machine,you will see the lights turning on alternately in anti clockwise direction. Release the button.Turn the dial to the right and press the coffee button, water pump will work.Turn on the steam/water knob and keep pressing the coffee button until all the air is purge out. Dial on other positions will test other components of the machine,such as grinder, solenoid valve , brew group,etc: I hope you can solve your problem with this information.
Feb 15, 2010 | Saeco Odea Giro Plus Coffee Maker
The brew group does not seem to engage properly. All the lights work, along with steam and water out of the wand. The red light flashes and switches between red and cup back and forth. It does start the...
Hi
Check behind the drip tray for coffee grounds. Make sure that your drip tray is locked in. If its not fully locked it, this could be your problem. If everything is removed but the brew unit, grab the handle without pushing the press button, and pull. If the brew unit comes out, it wasn't locked in. Put the drip tray in. Set the brew unit on the drip tray. Now slide the brew unit towards the machine with a little force and see if that locked it in?
Jan 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Nov 26, 2009 | Gaggia Baby Espresso Machine
Gaggia baby 18 momths old water coming through steam bit but no water coming through coffe bit any suggestions libby
HI
If you have a pre-grind button on your machine, push it but don't put any coffee in the brew unit. Push any of the coffee buttons, and see if water will come out then. If it does not, then you have a plugged brew unit and the brew head needs cleaning. I have directions for cleaning.
Jul 13, 2009 | Gaggia Syncrony Compact Coffee...
Coffee Makers & Espresso Machines Logo
102 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
