Panasonic uj-870 wont read/boot discs, need it to boot my recovery software because hd is wiped. Very frustrating
Need it to boot my recovery software because hd is wiped. Very frustrating
    New Friend:
    Problem Solver:
  • 12 Answers
The optical reader has more than likely went bad and so you will need to replace the drive. That of course is the easiest solution, but there are some work arounds
Posted on Jul 13, 2013
  • james_buel Jul 13, 2013
    Work around a like what? Be as technical as you like. If you feel like explaining, I'm working with very little at the moment.
Forgot my password and the password reset disk isnt working
You can do a Factory Recovery, this will wipe all your data. When recovered write down password and retain in a safe place for future use.
Dec 26, 2012 | HEWLETT-PACKARD Pavilion g7t Notebook PC...
Brought acer travel mate back to factory using recovery discs now it wont reboot.I put discs back through with no result
Check the bios settings, in boot settings you must set CD unit as first boot device, then you start PC with recovery disk 1 inside.
Sep 05, 2008 | Acer Computers & Internet
My toshiba a215-s4807 satellite, with windows vista won't boot with my mat uj-851s cdrom drive hooked up. I had the same problem with my older version, the mat uj-850s but just figured it was brok
You can change the boot up order of devices in the BIOS. Go into the BIOS setup then to Boot up order and move the CD/DVD dirve as the first boot device and the hard drive as the 2nd boot device.
Then you boot up with a disc in the CD/DVD drive.
May 01, 2012 | Computers & Internet
HOW TO USE THE ASUS F3E RECOVERY DISK TO
Pop back into the bios and make sure the boot order is correct (cd first), and make sure that you exit and SAVE.
Look out for the press any key to boot fron cd.
If no luck, can you try the disc in another computer to see if it is bootable
Jul 19, 2010 | ASUS Computers & Internet
How to wipe out HP mini hard drive
To restore your hard drive using Disaster Recovery, follow the steps below.
1. Shut down and power off your HP Mini if it is not already powered off.
2. Connect an external USB optical drive to the HP Mini.
3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc.
4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer.
5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.
Mar 28, 2010 | HP Mini 1000 Netbook
My MATSHITA BD-CMB UJ-120 wont read burnt CD ,DVD
yes,you need to change a new uj-120 or repair it.
http://www.it-battery.com/new-panasonic-uj120-bluray-bdrom8x-dvdâ±rw-ide-notebook-drive-p-1747.html
Feb 11, 2010 | Panasonic Computers & Internet
It is basically frozen up with virus's. How do I just wipe out everything and start from scratch?
You can use the OS installation disc or recovery disc if your computer has one. Insert the disc and re-boot the computer. It should ask you to boot from cd-rom and to press any key. If it does not then you will need to go into the BIOS of the computer and change the boot sequence to cd-rom first. Then when you get the disc to boot do a new installation. This will erase the drive and install the operating system fresh. You will then need to install all of the drivers for the laptop and software. If you have a recovery disc then it should bring it back to the factory state and will have the drivers and software on the disc also. Remember to back-up any pictures or files you do not want to lose if you can. Let me know if you have questions or problems.
Oct 11, 2009 | IBM ThinkPad T40 2373 Notebook
Cannot reload system software without blue screen
I use a panasonic UJ-870 DVD drive and it works. You don't necessarily need a proprietary drive. Otherwise try (if you can) switching the drive off then quickly on just before the Q1 restarts at reboot.
Mar 17, 2009 | Samsung Q1 Tablet PC
How do I reinitialize my Dell Inspiron 2650?
You should have a CD that says something like OEM CD. Or OPERATING SYSTEM. Put that disc in and reboot your PC. You should see a prompt to press any key to boot from CD. Press enter and follow the prompts to reinstall your operating system... If you don't have that CD you'll need to purchase one from the store or look at installing a free Operating System like Linux. Option 3 (less likely) You have a recovery partition installed and you should see a prompt during boot up that says "press F10 to start recovery" in this case all of the information on that CD is store in that partition on your HD.
Jan 04, 2009 | Dell Inspiron 2650 Notebook
Four Beeps on startup on a Panasonic uj-810b
sounds like it's trying to boot to the dead drive- pay attention to the screen when you power on F12 or F1 whatever get's you to boot menu- change the order to exclude the broken drive- it should stop beeping.
Jan 14, 2008 | Panasonic (UJ-825-B) DVD±RW Burner
Computers & Internet Logo
David Payne
David Payne
