Question about Vehicle Parts & Accessories
My ac blows cold air on one side and hot air on another
    Scholar:
  • 71 Answers
It could be two things. I immediatly think that you have a low A/C refrigerant level. This essentially causes air bubbles in the lines that in turn will cause warm air.
My other though is only relevant if you have dual climate control zones. This could be due to a sticking blend door on the hot side.
Posted on Jul 12, 2013
4 Suggested Answers
sxygaman
  • 95 Answers
SOURCE: 2008 azera with dual a/c blowing hot air only on drivers side
trap door in dash closed not letting cold air pass across
Posted on Aug 12, 2012
westburyauto
  • 66 Answers
SOURCE: Dual climate control not working
Sometimes this problem is caused by low refrigerant level in a/c system -- but it could be a temp. control actuator... this is a small electric motor, like a servo, which opens / closes a temp. control flap/door located inside the hvac housing. the actuator is located on the outside of the hvac housing, probably under the dash, close to the heater core, pass. side foot-well.
Posted on Aug 29, 2012
sxygaman
  • 95 Answers
SOURCE: 1977 deville top ac vents not blowing; only floor vents blowing cold air.
vacum hose leaking or not functioning at all trap door to left of glove box in dash
My 2011 dodge durango citadel has cold air blowing on drivers side AC and warm to hot on passenger side ac
Dual air. The actuator is bad. It is between the fire wall and HVAC plenum. The dash has to be removed along with the plenum. Costly job at the garage.
Feb 03, 2016 | 2011 Dodge Durango Citadel
My heater does not blow in floor in a dodgeram 1500
the heater vacuum motor and lines needs to be checked.Also get the blend door checked.
NO HEAT ON FLOOR VENTS
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
No heat from vents
Heater blows cold?
These will help.
Thanks.
Nov 28, 2012 | 2006 Ford Taurus
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Ac blows cold then hot air
Is the compressor running when it blows hot air ?
Jul 31, 2012 | GMC Sierra 1500 Cars & Trucks
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
My AC blows hot air out the driver's side and cold
My 02 Century has dual temp controls . One for driver for passenger. Make sure you don't have the dual climate enabled and just set for heat on your side and AC on the passengers
Apr 04, 2010 | 2001 Buick LeSabre
Drivers side AC will blow hot air.
the blend motor on the vehicle is probably bad
Aug 20, 2009 | 2003 Chevrolet Silverado 2500HD
Center vents cold side vents hot please help bthibs
hello,good day,seems your recirculating pump need tobe check,ty
May 15, 2009 | 1996 Mercedes-Benz C-Class
AIR CONDITIONER ONLY BLOWING COLD ON ONE SIDE AFTER DISCONNECTING BATTERY
Turn your AC off. Turn the car off Crank the car turn ac on drivers side to 60 passenger side to 90 press auto wait 1 minute turn AC off (very important) turn car off turn car back on switch driver's side 90 passenger 60 press auto wait one minute turn AC off( very important) turn car off turn car on AC 70 both sides press auto your ac should be blowing cold If not, you have an expensive problem
Aug 25, 2008 | GMC Sierra Cars & Trucks
Vehicle Parts & Accessories Logo
138 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
