I have a Mitsubishi wd-65831 I just got a new cable box with hdmi hook ups it's jus it I plug everything in the cable pops up briefly then goes to black screen any ideas?
    Champion:
  • 247 Answers
Try using a hdmi cable that terminates into rca/ audio video standard then plug the hdmi end to the source and the rca to the dvi or componenty.ypb and u are good to go but ensure u select component on your tv
Posted on Jul 18, 2013
  • 579 Answers
SOURCE: mitsubishi 65831
If the lamp has failed, don't fall for just paying big $$ for a new one from Misubishi. Instead, of buying their whole lamp assembly, just buy the bulb from me or many other sources on the net and install it into the assy yourself.
Posted on Dec 31, 2007
SOURCE: HDMI input failure
Hey guys, had the same problem. Found this solution on the web. Worked for me.
JVC HDMI Port Fix
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is reenabled.
Here’s how to get to Service Menu:
Before entering the SERVICE MENU, confirm that the setting
of TV/CATV SW of the REMOTE CONTROL UNIT is at the
"TV" side and the setting of VCR/DVD SW of the REMOTE
CONTROL UNIT is at the "VCR" side. If the switches have not
been properly set, you cannot enter the SERVICE MENU.
1) Press [SLEEP TIMER] key and while the indication of
SLEEP TIMER 0 MIN is being displayed, press
[DISPLAY] key and [VIDEO STATUS] key (Fig.2)
simultaneously.
2) The SERVICE MENU screen of Fig.1 is displayed.
3) Verify what to set in the SERVICE MENU, and set
whatever is necessary (Fig.1).
Refer to the SERVICE ADJUSTMENT for setting.
4) Press the [BACK] key to return the SERVICE MENU.
This should work.
Posted on Jan 06, 2008
MJS_1
  • 150 Answers
SOURCE: Toshiba 52hm84 DLP-HDMI Component has been compromised?
This is a wild guess, but I believe that you are being **** by the movie industry. The HDMI protocol includes a form of DRM (Digital Rights Management) for high resolution content called: High Bandwidth Digital Content Protection Basically this means that the media (disk or broadcast) instructs the player (in your case the cable box) to insist that any downstream devices (your TV) is industry and DRM compliant. Specifically this evil protection scheme is designed to plug the analog hole and make it impossible for you to record or copy the movie by using an analog output from your TV. This even restricts the size of the TV you can play the movie on, thus preventing pubs and bars from displaying the content on big screen TVs without paying royalties. The message means that the manufacturer of your TV has refused to toe the industry line. 1984 Anyone ? Martin
Posted on Apr 24, 2008
SOURCE: jvc hd-56g786 hdmi black screen
how do i get into my service menu to powerdown; please explain
Posted on Jul 10, 2008
Mustgo
  • 2359 Answers
SOURCE: the "new device found" screen keeps popping up
Inspect for damaged pin on INPUT 1 socket. (left most of the three HDMI connectors)
A quick pull on the cable can damage the pins.
=== If you see mis-aligned pins then please power off the set before making corrective action. ===
============== Here's a textbook instruction from Mitsubishi
If the New Device Found Screen Displays No HDMI Control Option If the New Device Found screen shows no option for HDMI Control, one of these conditions applies: • HDMI Control is turned off in the menus of the new device Action: a. Highlight EXIT and press ENTER to close the New Device Found screen. b. Display the device's setup menus and enable the device's CEC capabilities. c. Wait for the TV's New Device Found screen to appear again. d. If the New Device Found screen does not appear, power off the device. Power on the device and wait for the New Device Found screen to display with the HDMI Control option.
Next time you see the NEW DEVICE FOUND screen pop up.
Toggle the CEC field (on the right side of the pop up) to OFF.
Posted on Jan 05, 2011
Wd-65831 status light constantly blinks
have you tried a new lamp? part# 915P049020
web site: http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-65831
I strongly recommend the original part# as many replacements will not work properly in a Mitsubishi.
May 16, 2015 | Mitsubishi Diamond WD-65831 65" Projection...
Mitsubishi wd-60737 HDMI port 1 connected to cablebox. Screen is black and no sound. Cablebox is on, all cables connnected correctly and was previously working. Nothing new was done.
have you tried resetting your cable box? you can do this usually by either holding its power button in until all 3 lights light up, or by unplugging it from power , wait @ 30 seconds & plug back in .
Feb 07, 2015 | Mitsubishi Televison & Video
WD-65734, cable DVR, audio receiver and digital remote: picture goes black for 1-20 seconds and then returns, but audio is stable. Status led and lamp led are NOT on. Any suggestions? Thanks,
well are you using an hdmi cable, cause if you are there is a known issue with the communciations where it will lose communication if you reremove the hdmi cable then turn the box off slide the cable back into the box then turn the box back on it should restore the pic and audio just fine. if this is your fix then its one of three things a faulty hdmi cable or an out of date hdmi cable meaning the version is no longer support for the video production. or it's the hdmi output on the cable box. or it's a poor seat/faulty hdmi input on the tv. easy fix is try to replace the cable or use componet cables (red/blue/green) if this is not the setup of your tv/cable box then i will need more info.
Aug 20, 2012 | Mitsubishi WD 65837 65 in. HDTV
When i plug in hdmi cable to the wd52525 there is no hdmi imput on the device page. can't get it to work
If it is not there or grayed out you may have to try the soft reset first--set also has a hard one but only to be used as last resort.
Soft one: set on, menu,1,2,3 enter.
Jun 08, 2012 | Mitsubishi WD-52525 52" Rear Projection...
TV was working fine. Plays DVD's fine. Can't find HDMI from the cable, hence to TV reception. TV set works fine however on DVD's so it is not the set itself. Can't find the HDMI 1 hook up only the HDMI...
Tries tv and cable or satalite boxes unplug,replug it back for like about an hour later.By letting tv resetting itself back to the factory setting and those pay boxes upgrading it softwares.The tv HDMI signal for the tv incomming broadcasting signal should be back,if not, tv might have a dead HDMI cable or that the HDMI 1 hub it plug in is shorted and dead.
Feb 12, 2011 | Mitsubishi WD-57733 57" HDTV
I dont really have a problem. I just dont know which port to hook dvd player to. I need maybe the layout of the back panal, on what goes where.
U have a lated DVD player,like less than three years old?U can hook it up with one cable wire.It call a HDMI cable.Very easy to hook up,just one end of the HDMI cable to the tv HDMI tv port hub,the other side of HDMI cable to the HDMI DVD player port hub that it.Now u,must know with HDMI hub port u put ur signal in like 1 to 4,now go to that HDMI port hub,and will find ur dvd disc picture in playing in.
Apr 26, 2010 | Mitsubishi WD-52528 52" Television
Hdmi 2 wont work on mitsubishi wd-y65
It sounds similiar to a problem we've had with ours, all components would work in hdmi 1, but hdmi 2 would only work intermitently. They ended up replacing the digital board (fortunately we have the extended warrenty, I'm sure it's not cheap). Sorry hope this helps.
Feb 14, 2009 | Mitsubishi WD-Y65 65" HDTV
Mitsubishi with monlink new DVD player HDMI How to make work
the monolink is the hdmi on the mitsubishi. it acceps up to 1080i
Dec 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 65831
sounds like the projector globe is gone. i think you will need to replace it. if you are lucky there should be a pannel on the side or rear of the tv that allows you to replace the globe. pricey though.
good luck
smeags
Dec 31, 2007 | Mitsubishi Diamond WD-65831 65" Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
