Id57h I need to get a service manual for the id57h or directions on how to remove the hardrive and replace
Hardrive removal
Simple as pie... you will see the harddrive mounted horizontally in a small shelf after you tae the cover off. You have to unscrew the philips screws that hold it in the shelf and unplug the connectors. make sure you label the wires so you know which ones came from that harddrive... they is usually room for 2 harddrives and two complete sets of connectors, don't mix them up. (One is the master and the other called a slave.) There is an adapter for the harddrive that you should always keep should you need to replace the harddrive, (comes in two pieces on either side) the new ones don't come with the adapters to fit them in the case; they are bare bones. If you don't want to go through the gymnastics of taking the other tower apart and installing the 2nd harddrive in it to read it... an internal HDD adapter can be purchased from Tiger Direct for a nominal cost. I allows you plug you internal HDD into a USB socket in any PC (desktop or laptop) and read it as you would a Flashdrive.
Jun 02, 2014 | Gateway E-4300 E4300 Matxhrn Lux Pc - XP...
How do to install slave drive Seagate Barracuda 7200.9. Does it has to be to the motherboard or to a card in my computer? How do I set the pins in what order?
if y0our going to slave one hardrive you need to set that hardrive jumper into slave format....check your hardisk if where pin should it e placed...usually there is a direction where to set the jumper for slaving the hardrive.
Oct 28, 2009 | Seagate Barracuda 7200.9 ST3400633A 400 GB...
Carriage belt replacement
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Aug 10, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
Need to remove a hardrive
You open the case and remove it.
Replace it with a new one.
I think this is what you are asking.
Replace it with the same kind--if it's an IDE drive, you'll need a new IDE drive. SATA drives need to be replaced with like kind.
Size doesn't usually matter except in an older system.
Once you place a new drive in the system, you'll need to run the recovery disk that came with the computer or get a copy of the same version of Windows and use the code that should be on the case.
Jul 23, 2009 | Compaq Computers & Internet
Looking for visuals to assist me in removing my harddrive-below
verry eassy to do turn laptop over remover cover from hardrive there will be screws holding hardrive in place remove them, push hardrive back till it stidesout of socket and lift it out.i run acers do it all the time. your hardrive cover on bckside will be aboyt 4 inchs long about 3 wide a couplescrews holding it in place.IM me you need assistance ok glad to help
Jun 29, 2009 | Acer TravelMate 2423WXCi Notebook
When i was in 30 min of play in the sims2 ,message popup saying internal grahics hardrive
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, pls try:
  • update the video card drivers;
  • physically remove the graphics card and clean the little gold pins with a pencil eraser; or
  • if the video card is built in, then remove and perform the procedure on the memory.
Good luck and Thank you for using FixYa. Happy Holidays.
Pls be informed that due to my current rank and rating, even a Helpful would be detrimental to my status. Should this solution not address your concern, it would be appreciated if you could just not rate it at all. Cheers.
Dec 24, 2008 | Compaq Evo N610C Notebook
Replacing harddrive
Service Manual of V5000:
http://h10032.www1.hp.com/ctg/Manual/c00700903.pdf
Service Manual of V2000
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00444244/c00444244.pdf
yes the hdd of the V2000 and V5000 is interchangeable. it uses both IDE type hdd.
Apr 11, 2008 | HP Compaq Presario V2000 Notebook
Problem: Cannot Load Windows/Windows Setup Does Not Detect Hardrive
My Hp Compaq tc4400 Does not load Windows and when i try to install a new one and error Message apears saying that it cannot detect any hardrive, but when i press F9 for boot selection Notebook Hardrive is dected and availble, i tried removing the hardrive and re-insert it also it dint work could somebody help plssss
Feb 01, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
