Emerson 40" LC401em2f
Lighting storm happened last night and my TV has gone out. Everything attached to that power strip works except the TV. (Ps3, Xbox, Wii, Satellite box, and wireless headphones base all work) The light does not come on at all and makes no response when trying to turn on either. When the TV gets plugged in you hear something inside the TV. I don't know how to describe it other than a normal TV noise like the noise you hear when you turn on a TV internally. Then you hear another but different normal TV noise about 20 seconds after you unplug it. I opened it up and all of the caps look good and it has a ceramic looking fuse. I am going to try and pick up a new fuse today but I fear that is not the problem. Any ideas?
snakehead
  • 1074 Answers
SOURCE: tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Posted on Apr 04, 2007
melnavz
  • 1226 Answers
SOURCE: Plasma TV-power light does not come on
Hello!
most probably the fuse inside the circuit blown out, You should open the back of the tv to become circuit board visible. But this hard when novice do it.
To be sure that everything will be alright i would rather suggest you to bring the tv to the nearest service center. maybe warranty work for that.
best regards,melnavz
Posted on Mar 03, 2008
  • 92 Answers
SOURCE: No power
First off I did not see make or model. When plasmas die you have failure in either the power supply of the sustain boards. Do you have any voltage readings from va or vs ?
Craig www.classtorations.com
Posted on Jun 09, 2008
  • 16 Answers
SOURCE: NEW EMERSON 20" LCD STERO TV/DVD- NOT WORKING
the flash was the fuse inside the set blowing it usually takes out one or two diodes in the power supply section but maybeyou got lucky and its only the fuse.
Posted on Oct 09, 2008
  • 2336 Answers
SOURCE: AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Nov 27, 2008
My emerson lc401em2f is flickering with different colors almost like arolling-flickering? how can i fix it?
If you wish to get some details; check the site linked here. Pull up older posts.
Flickering can be adjusted. Type in the keyword "Flickering"; in the search box, at the top of the display window, to get gathered related posts.
Mar 07, 2015 | Emerson LC401EM2F 40" Inch LCD Full HD TV
My Emerson TV Wont turn on... No sensor lights working either.
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Apr 28, 2014 | Emerson LC401EM2F 40" Inch LCD Full HD TV
Emerison lc401em2f
More than likely its the tcon board.
Mar 29, 2014 | Emerson LC401EM2F 40" Inch LCD Full HD TV
Enerson lc401em2f
Buy a replacement and pay for the extended warranty.
Dec 18, 2012 | Emerson Lc320em1 TV
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
Hi, my problem with tv emerson plasma 42 etv4206pdp it does not turn on, after rainy and lighting day. i check the main power area and cant find anything grong. i dont know what else to do. if you had a...
It might have been blown out by the lightening storm. that happened to two of my tvs that were plugged in during a lightening storm. they both, and two dvd players, would not work after, but the ones that were not plugged in were fine. You should unplug your major electronic equipment during a storm, unless you have a power surge plug/equipment.
Oct 04, 2009 | Emerson EWL3706 37 in. LCD Television
Tv dead after storm
you could open it and look to see if the fuse is blown
Sep 22, 2007 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
