Question about Brother DCP-350C InkJet Printer
Unable clean error 46
How to solve unable clean error 46Brother DCP-350C InkJet Printer?
    New Friend:
  • 3 Answers
5 Suggested Answers
  • 13 Answers
SOURCE: unable to clean 46
Unable to Clean or Machine Error 46 means your purge counter is already full. Please refer below for the instructions on troubleshooting your machine.
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET or OK
b. 0 then press SET or OK
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET or OK
b. 7 then press SET or OK
b. 3 then press SET or OK
This is to reset the purge counter. Then press stop
5. Using arrow up button look for the following:
a. 0 then press SET or OK
b. 1 then press SET or OK (To reset unit)
a. 9 then press SET or OK
b. 9 then press SET or OK (To exit Maintenance mode)
Posted on Jan 21, 2010
Samyfam
  • 379 Answers
SOURCE: im getting a unable to clean 46 on my brother
If you look at the Brother website you will find a trouble shooting guide for your machine.
In the guide, for the error you quote Brothers guidance is to check for a stuck piece paper, however it also states that if the printhead is hard over to one side (righthand side if memory serves me correct), then to contact Brother. If you do so, Brother will tell you it needs to be serviced by a Brother agent, which will likely cost you more than a new one !
If it isnt a stuck piece of paper, the problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Posted on Nov 04, 2010
SOURCE: Brother DCP-195C Compact Colour Inkjet error
brother dcp 195c 46 error
Posted on Dec 24, 2010
  • 525 Answers
SOURCE: clean unable 46 error on dcp 135c brother printer
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Posted on Jan 23, 2011
Unable to clean error 46 Printer Brother DCP-6690cw
my DCP 6690 printer causes problem unable to clean 46 how can i solved this ..............
Jun 12, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
Hi I have Brother dcp 350 printer. I have the error 46 unable to print/clean i cant get the printer back to normal functions. I have change the inks (all) and I am still get the same error message 46....
The messages unable to print, unable to clean, unable 36, error 46 and error 32 are all print head errors.
1. Remove all the ink cartridges from the machine
2. Clean the contacts on the cartridges as well as inside the machine itself with a small amount of warm water or alcohol on a cotton swab until no ink comes off on the swab.
Note: if any of the other cartridges are low, empty, leaking or bulging replace them
3. Then turn off the machine and unplug it for 70 seconds
4. Plug it back it and wait for the insert cartridges message
5. Insert the cartridges and check to see if the problem is still there. If it is it means the print head has failed and in order to fix this the print head inside the printer needs to be replaced. The print head is the part of the printer that puts ink from the cartridges onto the page
Unfortunately this can sometimes cost more to replace then the machine itself.
Apr 18, 2011 | Brother DCP-350C InkJet Printer
What does the message "unable to clean 46" mean
the solution is to reset the purge counter ( waste ink absorber )
Feb 24, 2011 | Brother DCP-350C InkJet Printer
Clean unable 46 error on dcp 135c brother printer
May 19, 2010 | Brother DCP-350C InkJet Printer
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
i have brother dcp 6690cw and it said unable clean 46 i want solution for this
thank you so much
Apr 14, 2010 | Brother MFC 6490CW InkJet Printer
Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Mar 24, 2009 | Brother DCP-330C All-In-One InkJet Printer
Unable to clean 46
posted fix in another prob same section
Aug 23, 2008 | Brother DCP 130C All-In-One InkJet Printer
Error 46
did you already fix it? my printer is also dcp 130 c... it says unable to clean 46
thannks
Aug 08, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-350C InkJet Printer Logo
82 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
