Question about Human Touch Robotic Massage Chair Cream Htt 10crp
Who can I contact to fix this chair?
THe chair makes a sound at the top or the chair like it is not catching and just spins
How do I fix wheelchairs in which a tire loses friction with the floor and just spins while the occupant is moving and turning?
On a manual chair, this can be several things.
- Client sitting off-center
- Warped frames
- Bent wheels or mounts
- Many makes of chairs allow the front wheels to be angle adjusted- make sure they are adjusted so the barrel of the stem is exactly perpendicular to the ground. Sometimes they get loose or bumped.
Aug 05, 2014 | Health & Beauty
Can you stop a task chair from spinning?
There might be two levers on the underside of the chair; one to adjust the seat height that moves forward and backward, and one that locks the chair from spinning, pushes in or out. Push in to lock.
May 01, 2014 | Health & Beauty
My maytag hav2558aww wont turn on wash cycle
Possible that the grinding noise comes from the drum, irregular movement or broken paddles.
You can try and attempt only if equipped with a fundamental understanding of the working .
I shall give you some tips to this click 1..: Washing Machine
2. Replacing bearings
Jan 24, 2013 | Maytag HAV2558 Top Load Washer
I have pyramat chair where do i run rca cables from
How to Connect a Pyramat
Pyramat gaming chairs are high-end video recliners that integrate audio speakers and subwoofers to increase video game immersion. Pyramat chairs feature speakers and woofers placed at the head and elbows of gamers for a surround-sound effect. The chairs come in two types. Game chairs are similar to regular computer or office furniture. Gamebags are reinforced beanbag chairs with installed speakers and controls similar to the game chairs. Each of these must be connected to the console or computer to run properly.
Instructions Things You'll Need: Pyramat game chair or gamebag 12-volt AC adapter 3.5 mm audio cable 3.5 mm RCA audio adapter 1 Close all programs and power off the computer or console that you are connecting. Power surges or connection problems could cause damage to the devices if still plugged. 2 Connect the 3.5 mm audio cable to the control area on the arm of the chair or side of the gamebag. 3 Plug the other end of the 3.5mm audio cable into the stereo jack on the computer or console. Use the RCA audio adapter if the console has only A/V cable support. 4 Connect the 12-volt AC adapter to the chair and insert the other end into a grounded power outlet, preferably one with a surge protector. 5 Power on your game chair or gamebag using the control and turn on the console or computer. 6 Adjust the sound settings on the chair and your video game device to suit your preferences.
Tips & Warnings Do not get your game chair wet as this can damage the speakers and controls.
All necessary parts should be included with your game chair. If it is missing anything, contact Pyramat customer service for replacements.
Mar 07, 2011 | Pyramat Sound Rocker Gaming Chair
Adaptor for xb57-12.0-2000....gaming chair
If your gaming chair/adapter was ordered from shipping I recommend calling for a refund.
In case you can't refund the RCA adapter, you should definitely change the RCA cables.
If you still can not fix your problem, get it fixed for FREE with expert assistant at
http://www.fixya.com/support/p920984-pyramat_sound_rocker_gaming_chair_pm220
Copy and paste this on your address bar.
If you have anymore questions, contact me at mohammad7597@hotmail.com
Jan 08, 2011 | Pyramat Sound Rocker Gaming Chair
Not agitating
Thanks for writing to Fixya.com.
This is sounds like the little gear checks under the agitating cap , take a screw driver and pop the cap on the top of the agitator, and look at the 3 little plastic, catches, there is a gear there where it goes back and forth , and when it turns, these little catches, connect, and make the agitator spin. If it has a belt system then please make a note of the belt.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Apr 07, 2010 | Hotpoint VBXR1090B Top Load Washer
When i press the pedal on my sewing machine the pedal doesn't move. Sounds like the belt is working really hard but not catching. I can manually spin the knob and make it spin. Is this an easy fix?
It most be the belt. some belts have knots to catch the wheel. same use smooth belts. check to see which one it uses.It may have stretch out get a new one.
Aug 06, 2009 | Yamata FY900 Mechanical Sewing Machine
Spin cycle not working properly
On the transmission there are two shift arms. One shift arm controls the agitator and the other shifts to spin the cloths. If the washer has been making a "clicking" sound when it trys to spin, the solenoid that shifts the spin shift arm is not catching and the drum will not spin. The other possibility is the spin clutch is slipping and make a "grinding/ratcheting" sound. Neither, unfortunately are inexpensive to fix.
If you can describe the sound and when it occurs, I might be able to get closer.
Let me know.
Regards,
May 15, 2009 | Maytag Ensignia MAV4757AWW Top Load Washer
Machine does not agitate, will spin and rinse including.
Hi,does the top part of the agitator move freely when you move it by hand?Or does it catch,if it does not catch the the cogs other wise known as dog ears are worn out.Do not believe the little cogs that catch inside the top part of the agitator can be replaced.You may have to replace the whole agitator unit on some models they are around 40.00.
Apr 11, 2009 | Maytag PAV2300 Top Load Washer
Human Touch Robotic Massage Chair Cream Htt 10crp Logo
35 people viewed this question
Top Human Touch Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
ray gallant
Are you a Human Touch Luggage and Travel Expert? Answer questions, earn points and help others
