Question about Vacuums
Unit will not turn on - no power at control handle
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vacuums Master
  • 102,366 Answers
What make and model vacuum?
Posted on Jul 12, 2013
Miele vacuum s5980 no power
your main circuit board is also your speed control the motor should not have a circuit board i don't believe. open your machine up all the way to the motor and cord reel. check voltage at cord reel should be 120 +/- 10. if voltage is correct then replace speed control board.
Feb 12, 2013 | Miele S 5980 + SEB 217 Bagged Canister...
When vacuuming carpet with the electric power brush it will ocassionly , go to zero suction mode and shut off the brush. I have tried to cause it to happen by playing with the joint areas ( handle to tube...
You gave a good start to giving us good information to help you with solving this problem-- But I need a little more information:
It sounds like you have the Electric Motor driven Power nozzle/ Floor attachment-- am I correct? (Not the type that has a little vacuum motor down at the floor attachment-- Not one that depends upon air flowing thru the unit to power the brush, -- am I correct?)
You can control the motor with a switch at the handle-- correct?
So here is the question: - when you say "the electric power brush -- goes to zero suction" -- what tells you that it 'went to zero suction'?-- the little red flag on the vacuum?-- or what?
I am suspecting something might be caught up in the floor wand-- or at the power nozzle itself-- or even in the flexible hose. Do you know how to take the hose off, and place the hand-held end, in the opening in the Miele Vacuum? Can you do that, and clear out the hose first-- and then the hose with the want connected?
If they are all clear-- we may need to open the floor plate on the floor nozzle, and check for something caught in the air passageway--
Tell us more
Mack B
Dec 28, 2010 | Miele Blue Moon Bagged Canister Vacuum
I just bought a bissell power roller prodry cleaner and turned it on and nothing happens. Is there another button I am not turning on to get it to work?
The power switch is on the back of the handle. If that dosen't turn the unit on take the handle off and put it back on make sure its tight. If still nothing then its defective. Bissell says not to return it to the store contact a service center. If you have never used it return it.
Dec 16, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Electrolux Oxygen 3 model 7020A contols not working
You need to replace the hose itself. The buttons in the handle a very cheap and go bad all the time.
Aug 17, 2009 | Vacuums
Hoover s3765 windtunnel power head does not run
I have the exact same problem as you have. Have you found a solution since you posted on Mar. 18, 2009? Thank you.
Mar 18, 2009 | Hoover S3765-040 WindTunnel Bagless...
Belt not turning
Hi.
Your Dc14 will have A clutch unit.
Check that when you pull back handle to vacuum that the clutch control knob which is located front lower left side of machine moves to drive position & is not stuck in off or park position.
Rotate it to drive if its at off or park when you have lowered handle.
If adter checking this you still have no brush rotation you will need to remove clutch unit to either replace thr belts or fit new clutch.
Try this site for further help http://dysonmanuals.llc.nu/
Oct 27, 2008 | Dyson DC14 All floors Bagless Upright...
Bissell power steamer - upright deep cleaner - Does not **** water
If this unit has an onboard heater ( a little red lite in the center of the handle) then most likley it is the problem. You see the heater which is located inside the large portion of the handle has a very small passage that snakes its way throught and heats the water as it passes. The problem is that the water and soap are mixed before the heater which is very very hot and when you turn the unit off and the solution stops moving and hardens in that little passage while the heater cools. To fix this you have to take the handle appart allong with the heater and clean it out. To prevent this in the future make sure to turn the heater off and run just clean water through the unit before you put it away. This unit also has a belt that runs the pump check to see if the belt is in good shape it could be stretched but not broken I would suggest replacing it anyway just to be sure. You can buy the belt allong with other parts for this machine at www.stevessewandvac.com
Aug 12, 2008 | Vacuums
Kenmore 23513 canister vacuum won't turn off
Is there two switches for the unit, one for the handle (pick up unit) and brush assembly, and one for the vacuum motor? If so it seems that the handle unit is o.k. but the problem may be the switch to the vacuum motor. I would suggest testing the vacuum motor switch with an ohm meter for continuity through the switch. If its at fault replace it. You can probably purchase one from Sears or maybe Radio Shack.
Good Luck!
p.s. do not work on vacuum if plugged in.
Apr 06, 2008 | Kenmore 23513 Progressive Bagged Canister...
Vacuums Logo
13 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
