Siemens s 1674
F43
2 Suggested Answers
  • 6277 Answers
SOURCE: Washer machine Siemens model: WM
Here are my general guidance notes for a possible cure ;-0)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 28, 2011
F43. Terminal?
motor brushes on bosch machines typically last 6-7 years its the first thing to check
Mar 19, 2014 | Bosch Washing Machines
Fault code to bosch washing machines f43
F43 normally indicates a fault with the motor or the main control board
Dec 22, 2012 | Bosch Washing Machines
F43 ON THE SCREAN
F43" error indicating "motor malfunction"
Oct 15, 2012 | Bosch Axxis WFL 2060 Front Load Washer
F43 ON THE SCREAN
Oct 15, 2012 | Bosch Washing Machines
Konica 2125 is showing the error code F43
most likely need the exposure lamp replaced other causes could be the cvr board or relay 1 or a fuse on the acdb
Oct 04, 2009 | Konica Minolta Office Equipment & Supplies
Washing Machines Logo
Top Washing Machines Experts
