Question about Refrigerators
GE PROFILE PSC23SGRBSS NOT WORKING
Aprox 2 wks ago Refrigerator temp went up to 42 degrees & freezer up to 8 degrees--adjusted to colder on touch pad--2 days ago--only saw green "hr" on control pad & door light for ice dispenser was faintly flickering--later that day--quite completely.
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
  • 10 Answers
SOURCE: Refrigerator and freezer are both warm
sounds like the thermostat is faulty.
Posted on Feb 12, 2009
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
TheMobilian
  • 8220 Answers
SOURCE: GE Profile Artica refrig is freezing food
Replace the cold control
Posted on Apr 09, 2009
  • 146 Answers
SOURCE: Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Posted on Aug 22, 2009
Testimonial: "Thanks for your help. The control board was faulty. This is what I suspected but I wanted a second opinion before buying the board. "
GE bottom freezer PF22missaww i came home from vacation and it was at 60 degrees , unplugged it for 10 minutes and plugged it back in , ran fine for a month , came home from work and the unit is warm again...
GE Profile bottom freezer erratic.
GE Profile Bottom-Freezer Refrigerator with Electronic controls with digital temperature readout (Should include Models PDS20MFS, PDS20SFS, PDS22MFS, PDS22SFS, PDS22MFS) May also apply to other models.
Diagnosis: Search of Internet yielded no definitive fix. It appeared to me that the some minor frost buildup might be symptomatic of unseen frost elsewhere. The electronic controls could possibly be messed up.
Fix: Not knowing whether it was frost or the electronic controls (or both), did the following:
1. Turned off the refrigerator. (It is not clear how to do that. Download the owner's manual for your model from the Internet. If it is like mine, the freezer and refrigerator APPEAR to have separate controls. In fact they are linked. To turn both freezer and refrigerator off, press the WARMER button on EITHER the refrigerator OR freezer until the display shows OFF for both the freezer and refrigerator.)
2. Unplugged the unit. Let it set for 18 hours with both doors open.
3. Plugged it in (which may have reset the electronic controls.)
4. Turned it on. To do so, I followed the instructions that said to press the COLDER button on either the refrigerator or freezer. Press the same COLDER button a second time and it should go to the factory presets of 0 degrees for the freezer and 37 degrees for the refrigerator.
5. Allowed the temperatures to stabilize for a week, after which temperature adjustments can be made.
Jun 13, 2017 | Refrigerators
The GE Profile PDS22sfsarss is now 4 1/2 years old. One year ago, the temperature panel stopped working and a repair person told me to just order that circuit -- which I did and replaced it myself....
Not certain this will help your situation, but here is what I did to mine.
3. Plugged it in (which probably reset the electronic controls.)
Jun 11, 2017 | GE Profile PDS20SFS Bottom Freezer...
GE PROFILE REFRIGERATOR MOTHER BOARD PROBLEMS i REPLACED THE MOTHERBOARD AND IT STILL DOSEN'T KEEP THE PROPER TEMPERATURE. It varies from 36 to 45 degrees.
Go into the diagnostic mode on your touch display .
1) . Press any button on the display 1 time except the temp adjust buttons.
2) Press the temp up and down on both the freezer AND refrig (all 4 at the same time)
3) when 0's show , release the buttons and press any button except for the temp adjust buttons .
4) NOW , fress the temp adjust buttons until the freezer side displays 0 and the refrig side displays 7 . 0 and 7 is for the thermistors test .
5) After 0 and 7 display , press any button again except temp adjust , and this will start the thermistor check .
6) You will have 7 thermistor tests , indicated on the refrig display , starting at 1 , then 2 then .......
7) The feezer display will tell for the corresponding thermistor , indicated by the refrig display , if the thermistor p = pass , s = short , b = bad (replace board)
After determining if or which thermistor is bad , then adjust the display to 1 on freezer display and 6 on the refrig display . This ends the testing procedure and resets the refrig back to normal .
Sep 26, 2009 | GE Profile PFCS1NJWSS Stainless Steel...
Freezer is too cold (-14 degrees) and fridge is too warm (51 degrees). The freezer keeps gettting colder but the fridge part keeps getting warmer.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The temp sensor for the freezer may be reading the warm air in the fridge so is not cutting the compressor off.
Sep 25, 2009 | GE Profile PDS20MFS Bottom Freezer...
My GE Profile bottom freezer and frig's temps are also up..help
has a FF error shown up on your display. If so that is your freezer fan, and if not it still might be the FF motor is running to slow.
Jul 20, 2009 | GE Profile Stainless Bottom-Freezer...
FRIG DOEN'T GET COLDER THAN 49, WHAT COULD BE THE PROBLEM,FREEZER WORKS GREAT (GE PROFILE) ABOUT 2 YEARS OLD-
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp control. Make sure the fan is running when the compressor runs. Make sure the vent(damper) opens and closes as you adjust the fridge temp control.
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Feb 12, 2009 | GE Refrigerators
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
