Question about Sony VAIO (PCWA-A200)
Power managment the "AC PLUGGED IN" AND "RUNNING ON BATTERIES" WARNING BOX AT THE BOTTOM RIGHT HAND CORNER OF THE SCREEN, FLASHES BETWEEN ONE AND OTHER EVERY 2 SECONDS AND THE BRIGHTNESS OF THE SCREEN CHANGES BRIGHTER AND DARKER AS IT FLASHES MAKING IT IMPOSSIBLE TO USE THE COMPUTER. HELP PLEASE
  • blakey202 Aug 28, 2007
    SONY VAIO MODEL PCG-581M
    Brigadier General:
  • 6,966 Answers
Hi, A Sony VAIO PCWA-A200 is an 802.11b Wireless Access Point Router. Your post "...AC PLUGGED IN AND RUNNING ON BATTERIES...." indicates a laptop issue. To be of better assistance, post the brand/model of your laptop.
Posted on Aug 27, 2007
  • Louie  Role
    Louie Role Aug 29, 2007
    Hi again,
    The "AC PLUGGED IN" AND "RUNNING ON BATTERIES".... indicate just that; your laptop is plugged in to the AC mains however, the batteries are not charging nor is the laptop using the power from the AC mains. This is indicative of a hardware problem in your power supply/charging system.
    In theory, once a laptop is plugged into the AC mains, the battery is being charged while the laptop uses power from the adapter.
    "...DARKER AS IT FLASHES..." Since you're running on battery which is presumably getting weaker, every time the warning flashes, the screen/display is getting lower and lower power hence the brightness growing darker.
    Since this is a hardware problem that requires opening the unit and doing electronics diagnosis, possibly soldering,it might be to your advantage to seek the services of a qualified professional. Should the unit be still under warranty, then perhaps you can bring it to a Sony Service Center with proof of purchase/ownership and warranty documents.
    Hope this be of help/idea. Post back should you need further information.
    Good luck and kind regards.
Will not turn on
Before sending your phone in for a flash2.gif or attempting to do it yourself (wotanserver), I would suggest the following. Take out the battery and leave it out overnight. Then put it back in the following day and try turning the phone on. If this didn't help, then flashing is required. You can try flashing with SEUS (Sony Ericsson2.gif Update Service) which is free (wotanserver requires credits=money). Good luck!
Dec 15, 2007 | Sony Ericsson K800i Cellular Phone
When I unplug the printer from my Dell Latitude D610 laptop, the battery icon appears on the bottom right hand corner instead of the "ON AC power" icon and the computers shut down due to a low battery....
Your AC power supply is not providing power - The printer is supplying your laptop with power via the usb port. When you unplug the printer, the laptop runs on battery until it goes dead. You will need another AC power supply,
Good Luck
Oct 03, 2010 | Dell Latitude D600 Notebook
What does the flashing red hand in the upper right
The flashing red light is warning you that the shutter speed will be too long for handholding the camera. Put the camera on a tripod or other stable surface, and/or use the flash.
Nov 08, 2009 | Nikon COOLPIX S9 Digital Camera
ZHow do I charge battery (new user)
just plug in your adapter that came with the unit.....leave it for the recommended time for charging and there you go.....if you don't have an adapter...you'll need to find out the required power that it needs and then purchase an adapter that will supply the necessary power....and also of course, the plug must also fit the receptacle on the back of your unit...with the correct polarity......good luck
silvio
Jul 08, 2009 | Dell Latitude C640 Notebook
Renault scenic flashing warning light on right of display bottom row right hand corner. i do not have a manuel so can you tell me what this means? looks like a circle with a line in.
check your brake fluid level( as this light is the hand brake warning light) but if it comes on with the hand brake in off position and ignition on it warning low fluid level in the braking system
May 16, 2009 | 2001 Renault Sportwagon
The word ''Acers'' apperas on the screen and its not loading
if you can find the motherboard battery, remove it and leave it out for around 2 mins, this should reset the CMOS (date,time, settings etc) make sure the laptop battery is out and its not plugged into the mains, the other way is to flash the bios by downloading the latest bios version for you machine providing that it boots to windows, the only other option is to flash via floppy with AC power on!!! NOT RECOMENDED as if it goes wrong your pc will be permanantly dead
good luck
Nov 13, 2008 | Acer Aspire 5610-4648 Notebook
Only works when adapter's plugged in.
try plugging and unplugging the charger/ac adapter several times to see if the switch that is built into the jack might be stuck from dirt or corrosion.sometimes you can take a toothpick and get them unstuck too.
Sep 25, 2008 | Icom IC-R5 Handheld Scanner
Blue rectangular box appeared on monitor and won't go away
Try pulling the AC plug out and leaving it overnight.
The processor may have tripped over itself.
Jul 30, 2008 | Olevia LT32HVM 32 in. LCD Television
Tom tom 1 4n00.012
Is the unit connect to a power cable while you're using it? Sounds like the battery just runs down. Check your power cable, is it properly connected to the cigarette lighter adapter? Maybe your cigarette lighter is defective and the unit is not gettting power, therfore running on battery all the time
Jan 25, 2008 | Tomtom ONE GPS Receiver
Sony VAIO (PCWA-A200) Logo
65 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
