Dishwashers Logo
Anonymous Posted on Jul 12, 2013
8 sec light on and no other buttons work - Frigidaire Dishwashers
  • Official Brand Answer 4,342 Answers
  • Posted on Jul 16, 2013
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1466579
Points
5907
Hi Jennifer - Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn on the unit. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
1helpful
2answers
I bought sj-5501 Sharp fridge . Yesterday I have no lighting on the front panel display of the refrigerator The refrigerator works right What could be the reason ? Thanks,
You can try one of these;
1. Hold down "Energy Saving" and "Lighting" buttons simultaneously for 10 seconds (or top left & right buttons). Display panel returns immediately
2. press the Freezer and Ref buttons at the same time for 8 secs and Bam!!!! Bac 2 normal!
3. pressed the power freeze and vacation buttons for about 3 secs and it worked
4. I held the top left and top right soft touch buttons on the screen itself (which I think is the power save and the lighting buttons) and held for about 8 - 10 secs and it reset
Hope it helps. Its in the combination of two buttons pressed simultaneously. Try your luck.
My toyota sienna 2001 was opening by remot control now it is not working roof light not working warnnig
hello
Prius2 is not powering up after one person swapped ower polarityof battery while changing it. We changed Big fuse at the front of the car and couple of small fuses. Now when pressing power button we have engine light and power button orange light fore just one sec. After it just stays dead. While pressing power button you can hear couple relays clicking for a sec and dc to dc giving hi frequency noise for the same amount of time. Help us please. This prius was manufactured in 2003. Many Thanks
Red light flashes 3 times
hold in on the power button for 10 sec make sure you put the cover on it good first if that dont work unplug it for a few sec then try to hold the power button down for 5- 10 sec that should work
Befsr41 ports will not light up
Please try to reset your router by holding the reset button for 30 secs. After 30 secs release the reset button. Than take the power cable out of your router and plug it back in after 30 secs. If the lights are stable than its ok, else your router has gone bad.
**If this works please rate else let me know in case of further help.**
The control locked light is on. No other buttons
push one button (any / not stop) push 4 sec, rel 4 sec, push 4 sec, rel 4 sec that will send in to self dig
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
3helpful
3answers
Trying to pair BT150 but it won't go into pairing mode
I had the same problem. The many instructions available don't have quite the right details. This worked for me:
1. Turn off the BT150 by holding down the answer button about 5 sec. until the blue light goes off and is not flashing.
2. Turn on the BT150 by holding down the answer button about 5 sec. until the blue light flashes.
3. Keep holding the answer button, and press and hold the volume + button for another 5 sec. until the blue light comes on solid.
Control locked onHe3
try unplugging then hold power button down for 10 secs or so with power removed this may help reset the control bd may even try holding lock button down longer than 3 secs i usually hold until light goes out
Router reset
the power light of your router should go flashing once it's being reset. If it is not doing that you can try this reset.
Hold the reset button for 10 sec. while holding the reset button unplugged the power of the router, wait for another 10 sec (still holding the reset button in), plug the power back and wait for another 10 sec. and now reslease the power button.
If it still won't work you can also do a software reset with the latest version of this router, You go to the setup page and go to the administration tab and go to the sub tab that says factory defaults, just tick yes and do save settings.
Hope this one helps.
A drop image on screen
hi i have panasonic NV DS 65 initially when i power on the cam it started then after 5 to 10 sec the power light automatically flashes and the buttons on camera doesnt work any more. but now the problem has got worsend the powen light keeps on flashing and no buttons work moreover a drop image is flashed on the screen.
plz have me solve my problem
sam_rav
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
