Question about Poulan Pro PR550N22SH 22Inch Briggs Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) ()
Throttle too low
How do I turn up the throttle
    Master:
  • 969 Answers
No adjustment, automatic governor.
Posted on May 28, 2014
What is the proper carberator adjustment
Start with 1 full turn out from the closed position on both the idle and high speed mixture screws. After the engine has warmed up, hold the throttle wide open and adjust the high speed mixture screw until the engine runs at the highest RPM then turn the screw counter-clockwise about 1/8 turn.
Next, turn the low speed mixture screw in whichever position gives the best idle.
After making these adjustments, check the throttle response. If the engine hesitates when applying the throttle, turn the low speed mixture screw counter-clockwise about 1/8 turn.
Jan 30, 2015 | Garden
Gas controll only operates in high or low controll will not stay ingaged between high and low.
The mower is designed to mow at high throttle only... Low is for warming up or idle purposes...
Jul 28, 2014 | Husqvarna "MZ6128ZT 61"" Briggs And...
Engine quits when throttle is opened
Most weed eaters are two stroke. You have a high and low idle screws on the carburetor. Assuming you have the right fuel mixture. Turn both screws in lightly until seated. Turn two turns out. You should see an h for high and l for low. Stat with low screw first turn in or out until running smooth. Then do the same with high idle screw holding full throttle. Once running smooth in high . Go back check low idle. Should run fine after this. Also check plug see if carbon fouled.
May 21, 2010 | Craftsman 25cc Gas Line Trimmer
My poulan wild thing 2375 bogs out when throttle
Make sure that the air cleaner and muffler are not plugged. Check the carburetor screws and nuts for tightness. After turning both needles CW to stops (lightly), back them out CCW 1-1/2 turns each. Start the engine and allow to warm up. Open the throttle and adjust the H needle CW somewhat until the engine speeds up, but is 4-stroking. Correct adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW till the engine runs fairly smoothly, but allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain doesn't turn, but the engine keeps running. Hope this helps!
Apr 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Low-end Bog
tried this on the carb turn the mixture screw in a 1/4 of a turn
Oct 09, 2009 | 2003 Honda CR 125 R
2002 camry le 4 cyl idles really really low, sputters, and turns off, i have to put it in park and keep reving it and when the light turns green quickly put it in drive and go or it will turn off. also,...
This vehicle is equipped with an electronic throttle control motot that operates the throttle plate. and controls the idle if your throttle plate is carboned up if will decrease air flow into the engine causing a low idle. This is very common if your battery was replaced or disconnected.
Sep 17, 2009 | 2003 Toyota Camry
Husqvarna 51 wont stay idleing
those are the throttle adjustment screws H is high L is Low for the air mixture of the idle.
Jul 28, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Throttle grip locked.
This could be the slider inside the carb,The cable,or The throttle itself.
start by removing the throttle and checking it.
Please rate this a fixya
Feb 03, 2009 | 2006 Harley Davidson FXDLI Dyna Low Rider
I recently moved and when I received my 2006 dyna low rider out of storage the throttle is locked.
Hello!
Is the Throttle Lock (THUMBSCREW at the bottom of the throttle housing, in between the two cables) turned all the way clockwise? TURN THE THUMBSCREW COUNTER-CLOCKWISE to release the lock. Be careful - do not to turn counter clockwise enough to were the thumbscrew comes out of the housing. The thumbscrew is held in the housing via a c-clip. If the thumbscrew was turned counter-clockwise too far, and the c-clip came out of the grove on thumbscrew, it is possible that the c-clip and 'shoe' , which are located inside the throttle housing ( aka Control Housing) have jammed the throttle boss, not allowing it to rotate freely. If that is the case, the Throttle/Control Housing needs to be opened and you have to take a look inside. Other than that, check to make sure that there is no obstruction at any of the moving parts of the Carb, especially where the throttle cables connect to it.
If the problem still exists after you've verified that the cables move freely, notify me and I'll go further into it with you.
GOOD LUCK
-Marko
Poulan Pro PR550N22SH 22Inch Briggs  Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) () Logo
107 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
