Question about Epson Replacement Lamp ELPLP30 f EMP-61 EMP-81 - V13H010L30 Projector Lamp
My projector has a blue flickering hint in the picture, is it a lamp related issue, or is it a lcd problem.....?My lamp do needs replacing because the indicator says so.......but will replacing the lamp fix the hint issue?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
Blue flickering hint, means the lcd panel is break,
or polarizer is break. We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Posted on Jan 04, 2015
Canon lv-5220 multimedia projector flickering after start up
If it happens with no input hooked up then it could be the lamp. Or Worse.
Dec 05, 2012 | Canon LV-5220 Multimedia Projector
Projector picture flickering
Dusting is not going to help. I could be the lamp if it happens with no input hooked up.
Dec 05, 2012 | NEC NP200 Projector
My InFocus IN2102EP projector is recently projecting a small white spot. If it was a PC, I'd say that a pixel was out. I've try blowing compressed air in various places, and have removed and replaced the...
Sounds like the DMD chip is on it's way out.
Check if the intermittent problem is related to the external air temperature. Try blowing cold air around the unit with a personal fan to see if it does the same thing.
Check if the air vents and filter is clean
Apr 12, 2011 | InFocus IN2102EP Projector
Tv picture flickering
The first reason for this fault is the lamp itself, just about to expire.
Check the lamp and then if OK power the projector up with no signal. Does it flicker then? If it doesn't it is a signal lead or the signal itself, if it does suspect the lamp.
Hope this helps.
Nov 09, 2010 | Televison & Video
My projector does not show any picture,only show blue screen, does the lamp need replacement an if it does how it will cost
If you are seeing the blue screen at startup, then the issue is more than likely not the lamp. What is your input source and what inputs are you connecting to?
If you are using a laptop PC, note that the VGA output by default is not active. You have to go into display settings and change it to dual monitor for VGA output to work.
Oct 05, 2010 | Hitachi CPS210LAMP Projector Lamp
HD70 DLP Projector: The projector is used and about a year old. It cur...
Did this start occurring after you replaced the lamp?
The reason I ask is I had the same issue after changing the lamp and it was caused because when I took out the old lamp I noticed dust in the lamp housing which I attempted to blow away.
This caused the problem because some dust got further into the projector, specifically around the color wheel. I sorted it out by taking the projector apart following the instructions here:
http://tantht.blogspot.com/2009/02/how-to-remove-dust-blobs-from-optoma.html
(note my HD70 was out of warranty, if yours is not, I would recommend contacting Optoma to get it fixed).
Follow the above instructions to step 14 and then locate the color wheel which is at the front of the projector behind a dark gray, plastic type square shaped cover.
You have to be very careful here, but remove the color wheel (there is one screw holding it in place) - note it
May 18, 2010 | Optoma HD70 DLP Projector
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
Picture keeps flickering after 15 min
if you hear chirping, too, replace the colorwheel. also check the lamp timer. if it's close to 2000hours (or the inside of the lamp is bulging or blackened), replace the lamp. if the lamp is new and the colorwheel doesn't chirp, replace the ballast/power supply.
Nov 17, 2009 | Optoma HD70 DLP Projector
Flickering dots on Benq PB6200 projector.
it's not the lamp. if you've replaced the cords and still have the problem, reset the settings to factory default to make sure the resolution matches. if still not ok, there may be an issue with the main board.
Oct 04, 2009 | BenQ PB6200 Multimedia Projector
Epson Replacement Lamp ELPLP30 f EMP-61 EMP-81 - V13H010L30 Projector Lamp Logo
119 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
