Question about Brother FAX-575 Plain Paper Thermal
When im sending a fax, the machine stops and says receive, what does this mean?
I am trying to fax papers to my college. My fax machine is sharing one line with my house phone. everything is setup already, but everytime i dial my school's fax number, the machine dials, and then it says "Receive" and does nothing else. Please help me!
  • Sharaya Johnson Jul 12, 2013
    okay i've tried everything. and now it says "sending", then it stops and says "no response" so this means no one on the other end is answering..correct??
checkitright
  • 1362 Answers
SOURCE: receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
Posted on Jul 31, 2008
leroyal
  • 2120 Answers
SOURCE: fax will not send
Does the receiving or sending party have a DSL phone line?
Posted on Sep 01, 2008
SOURCE: won't receive faxes
Make sure the receive faxes button is set properly. If it is not set to fax only, you will need to manually receive faxes, the machine will not auto answer.
Posted on Dec 15, 2008
leroyal
  • 2120 Answers
SOURCE: buttons do not work on brother 1270 fax machine, has dial tone
Uneconomical to repair. Sorry
Posted on Jan 24, 2009
  • 159 Answers
SOURCE: Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
Posted on Jun 11, 2009
Panasonic kx-ft77 paper jammed and fax im memory
I have a problem with the fax machine in question is panasonic kx ft77 . When receiving a fax error expel warm up and stop receiving the document. Or does anyone know what the problem is and how to fix it ? Thanks in advance
Aug 16, 2013 | Panasonic KX-FHD331 Plain Paper Thermal...
I need assistance with fax error codes # 322 and # 358. What do they mean?
Error code 322- There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
Set the receiving machine to receive at a slower transmission speed
If the session fails after sending several pages of a large document, resend the document as several smaller documents.
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Error code 358--
The remote user pressed the Stop key,
The remote machine encountered a system problem such as no paper or a paper jam.
Try
Configure the local fax machine to use a slower reception speed.
Disable ECM mode on your machine.
Try sending a fax to another location.
Mar 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
Having trouble receiving faxes, takes several times of someone sending to me to receive.
First thing to check is the condition of the phone line, if the machine has a handset make a phone call from the handset, is the line clear? Is there any static or Echos on the line?
Is the machine on a shared line with computers or an answering machine?
Call the Fax machine from a phone, is the line clear? did the machine generate its handshake burst? Did anything else try to answer the line?
Check the phone cable input, it should be going onto the LINE jack on the back of the machine.
Apr 15, 2009 | Brother IntelliFax-1860C Plain Paper...
I can only receive faxes not send when i try to send it just keeps ringing will not transmit
If you dial a number and just hear ringing that means the other end is not answering. Even if a person or answering machine picked up the ringing would stop. The problem is at the other end.
Mar 10, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
Ican't send my fax to Manatee college. All the time report shows
If it is just thier phone number they may have a fax that is old or not up to date with industry standards. Since this is a college I think they have a newer machine. Thier could be some line noise. I would email or snail mail it.
Dec 18, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Brother 1840 bleeps
Try to unplug the handset and try again.
Unplug the phone cords from any shared devices.
Do you have DSL or any other digital type phone line?
Make sure the phone cord is plugged into the LINE port of the fax machine.
Jul 21, 2008 | Brother IntelliFAX 1840C Plain Paper...
Fax wont send
try sending to another machine and also from a different telephone line if possible.Also does this machine receive a fax.Noise on telephone line can cause such problems.
Feb 27, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Brother FAX-575 Plain Paper Thermal Logo
26 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
