Question about Sierra International 18-2956 Marine Head Gasket for Johnson/Evinrude Outboard Motor ()
What are the signs of blowen head gasket on a 1999 subaru legacy 2.5l
My car is over heating .I have replaced the termastate twice and got new radiator cap. I have bleed the radiator line too. it drives fine just overheats.when it does over heat the water not all the time it is coming out from underneath the car.cant tell from where. the overflow tank will fill up radiator will empty its like it not going thur the motor. the heat work off and on .I guess its like it does something different everytime its drove.no one know whats ghoing on.including me I just need my car.
    Top Expert:
  • Sierra Master
  • 45,620 Answers
Have a pressure test done on the cooling system to find the leak first then have a compression test done to check for head gasket or cracked head.
Posted on Aug 07, 2013
How to replace valves on a subaru legacy 2.2 1999?
this will require both head removal so if you are not competent to do the job have an accredited shop do it for you. There are timing belt/chain issues, head tensions, gaskets etc and if done by a qualified shop there will be a warranty issued with the job.
May 02, 2014 | 1999 Subaru Legacy
Misfires white smoke
head gasket would cause over heating and possible white smoke, your problem sound like the m.a.f. sensor needs replaced
Sep 08, 2013 | 1999 Subaru Legacy
My 91 Subaru Legacy keeps overheating. When the needle starts to rise, it blows cold air instead of heat. Had a faulty hose replaced recently and it fixed the problem for a few days, but she's acting up...
if there are no leaks then they have problems with head gaskets blowing compression into coolant when cold remove rad cap fill with coolant run engine then rev up engine look for bubbles in coolant if so then replace head gaskets
Jan 13, 2011 | 1991 Subaru Legacy
My 1996 subaru legacy outback has started overheating it comes up to temp and stays there for 6-7 miles and then goes up like a rocket. this started when i started using the heat. if I turn off the fan...
i had the same problem with my 1996 subaru legacy grand wagon,which is identical to yours.it had a cracked head,the gasket was fine.not cheap to get done but id get it done now before more serious damage is done.
Dec 04, 2010 | 1996 Subaru Legacy
I got a 99 Subaru Legacy 2.2L Sedan. Recently hit and deer and blew head gaskets, overheated motor and had to replace. Everything starts smooth but when the car heats up, it acts like it's not getting gas....
I think you need to check your fuel pressure. If it's not between 41 & 45psi, you need to replace the fuel regulator. OBD doesn't always give the exact response to enable acurate diagnosis. Try this anyway, get back if still a problem.
Mar 19, 2010 | 1999 Subaru Legacy
1990 subaru legacy 2.2ltr auto with 189 kms. car heats up and pushes water out from reserve tank.no heat inside.new thermostat and water pump.no water visible in the engine oil and runs smooth.engine...
could be a crack in the cylinder wall on the low side, causing the compression to push the water out and not mix with the oil as its not leaking between oilway and waterway.
head gaskets are a weakpoint on the 2.2 and 2.5 as they are bored out to reach this capacity and this leaves less area for the gasket to bite down on around the cylinders. Fit a WRK steel gasket and get the heads torqued down properly, its a nasty job from an access point of view tho
Jan 12, 2010 | 1990 Subaru Legacy
1993 Subaru Legacy Sedan 2.2 liter engine, has and over heating problem. Replaced thermostat, replaced water pump, and replaced radiator with all new. Still over heating! Any ideas??
Usually the main reason for a Subaru to over heat is a blown head gasket. If it is pushing fluid out through the overflow bottle. I would suspect a blown head gasket.
Nov 30, 2009 | 1993 Subaru Legacy
Intermittent overheating 96 Subaru Legacy.
if it overheats while your in motion then u can eliminate your fans, as your problem. and do you mean 5-50 thousand miles? id chech your coolant for hc contamination. most likley a head gasket
Mar 15, 2009 | 1999 Subaru Legacy
Sierra International 18-2956 Marine Head Gasket for Johnson/Evinrude Outboard Motor () Logo
Top Sierra Boating Experts
nmccully
Jeffrey Turcotte
Jeffrey Turcotte
perry richard
perry richard
Are you a Sierra Boating Expert? Answer questions, earn points and help others
