Question about LaCie 500GB Rikiki USB 3.0 Portable Hard Drive
LaCie Rikiki stops working. The led does not blink.
I change the cable for other in good condition. I tried in many PCs. I suppose a hardware fault. Can I try to connect it in another way ? How to dismount ?
  • 3,799 Answers
This kind of fault is usually the case to drive interface. You can remove the drive and try to plug it into you computer using the IDE or SATA cables your drive needs. You will then be able to tell if it is your drive or the case.
Posted on Jul 12, 2013
SOURCE: external hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Posted on Sep 08, 2008
  • 39 Answers
SOURCE: Computer will not boot with Lacie Desktop Hard Disk connected.
You can enter the bios on bootup by pressing a special key to force your computer to go into BIOS mode. What key this is varies by computer, often it is F8, F10, sometines F11. Anyway, use the key for your computer, and change to boot modus to not first boot from USB.
Posted on Feb 09, 2009
  • 10406 Answers
SOURCE: My LaCie Rikiki is no
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Posted on Dec 12, 2010
  • 88 Answers
SOURCE: I just bought Lacie rikiki
Hi.
This is normal. You will never get all the capacity for a USB key or a hard drive. The missing space is for format purpose and hard drive maintenance.
Hope it helps
Posted on Feb 08, 2011
  • 150 Answers
SOURCE: My laptop doesn't recognize Lacie Rikiki Go 1TB.
Hello roblau99:
First lets try this. Shutdown your laptop and reboot. Once your up and running, plug in your portable hard drive. You might try a different USB port. If windows doesn't let you know its there then you need to look for it by going into your administration tools menu. Of course this depends on what version of windows your are running, if it is windows.
Maybe you can answer this? Have you been disconnecting that hard drive without telling windows you are going to disconnect it first? If the answer is yes you may have corrupted that drive which is why windows is not recognizing it.
Good Luck and just let me know if you need more help.
Sincerely, Peter N.
Posted on Mar 22, 2011
New LaCie 500GB Rikiki USB 3.0 Portable Hard Drive don't connect and rikiki usb3.0 don't install
well we all have had that problem I have sent back items that were bad when I toke them out of the box before
Aug 20, 2014 | LaCie 500GB Rikiki USB 3.0 Black - 301949
The usb cable on my LaCie rikiki is broken
You can buy USB 3 cables online. like the
5ft USB 3.0 Superspeed Black Cable Cord for Seagate Backup Plus 4TB 3TB 1TB 500G on Amazone for $8.00
USB 3 0 Cable eBay
Perhaps other firms are cheaper?
Perhaps your local electronic store has these cables in stock?
Jan 26, 2014 | LaCie Rikiki Go 1TB USB 2.0 Portable -...
La cie rikiki usb cable broken
Replacement cables are available for purchase on ebay for under $5
Jan 26, 2014 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
4big Quadra drive not appearing in disk utility or LaCie desktop manager
Could be defective. Try swapping power cord and usb cable with know good ones. You could also plug it into a different (known working) usb port.
Good Luck
Nov 28, 2013 | LaCie 4TB Biggest Quadra U SATA II Hard...
Usb cable is causing a short circuit
the first cable (throw it away), the secound use that one or a new one. then you will need to locate the drivers on the internet, download them and install.
Jul 20, 2012 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
I just bought Lacie rikiki hard drives. As I put it into my computer the assistant starts. Unfortunatelly after few minutes the process stopped and the capacity is 465 GB instead of 500 GB. Is there any...
Hi.
Hope it helps
Feb 08, 2011 | LaCie Rikiki Go 1TB USB 2.0 Portable -...
LaCie 500GB portable hard drive is giving error 43. It was working fine for a few weeks and now I can't get into it from either of my computers. I tried uninstalling the USB Controllers but still same...
The symptoms indicate there is a problem with the drive, how it is connected, or with the computer used for troubleshooting. The next best step is to change physical variables, and find a simpler problem than a broken product.
  • Change the data cable (USB, FireWire, Ethernet, etc.) A failure in the cable can cause this issue.
  • Change the external power supply or cable. If a different LaCie product is available, borrow the power cabling from that unit to see if the problem is in that component. On drives that are powered via USB or Firewire, try using the included power sharing cable and connect it to a second port.
  • Change the computer you are using. Computer problems can manifest themselves in many ways. Even if the computer appears to be working properly, this is a worthwhile test.
Then run
Dec 22, 2010 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
Dec 15, 2008 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
LaCie 500GB Rikiki USB 3.0 Portable Hard Drive Logo
227 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
