Question about Garden
Challenge Extreme 3.5hp lawn mower manual
Where is the spark plug on this mower, please?
    Master:
  • 969 Answers
Front center of motor, look for plug wire.
Posted on May 28, 2014
  • 5 Answers
SOURCE: Poulan 6.75 Lawn mower will not start
trouble shooting tips: oil is too full
fuel jet and float are plugged
spark plug lead wire may be damaged inside and needs to be replaced.
Posted on May 02, 2009
defadad
  • 351 Answers
SOURCE: how do i change wheel height on lawn mower
You do not change the wheel height, you change the cutter height,there should be an arm sticking up neart he rear wheel, you just push it to the side a little and push it either forward or backward.
Hope this helps
Posted on May 11, 2009
  • 88 Answers
SOURCE: no spark from spark plug in honda lawn mower
the pionts could be bad try changing them
Posted on Aug 30, 2009
  • 8 Answers
SOURCE: lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
Posted on May 01, 2010
motor1258
  • 6674 Answers
SOURCE: Lawn Mower runs rough & dies has black sooty spark plugs
A good place to start would be to remove air cleaner assembly and give it a good wash and service and take a close look at choke assembly/lever to be sure it isn't sticking in on position, while trying to run it with air filter off..
Posted on Dec 05, 2011
Lost manual for challenge extreme petrol mower 3.5 hp
Hi Jennifer, Search online by make and model number + manual. This should get you a number of hits that you can then access.
Jul 09, 2015 | Garden
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
What is the proper spark plug for MTD 11B-021C516 lawn mower
Contact MTD if your manual doesn't cover this, or buy a shop manual.
May 23, 2014 | Mtd Garden
Challenge extreme
Any small engines shop will have these. Not expensive.
Apr 04, 2014 | Tecumseh Garden
I cannot locate my manual; can you please tell me how to change the oil?
Simplest thing to do. Remove spark plug wire for safety. Remove oil filler plug. Tip mower to the side the filler neck is on with a bowl waiting on the ground next to the mower to catch the used oil. When empty, tip mower back upright and refill with 20 oz of 30 weight non-detergent oil. Put filler cap back in and check level. Replace spark plug wire. Thats it!
Jun 25, 2010 | Craftsman 675 Torque 190cc 21" Briggs ...
How to change a spark plug on a club cadett model # 959435
Hello. Changing the spark plug requires a couple of tools, all available at any auto parts store, and the right replacement plug. Regarding the plug, look in the manual or take the old plug to the auto parts store and have the clerk cross reference for you to be sure you get the same one or a comparable. Look at the links below to learn more about changing spark plugs in lawn mowers than most people know. Have fun with it.
Here is the link to a video to show you the steps. http://www.ehow.com/video_4426873_changing-spark-plugs-lawn-mower.html
http://www.oneprojectcloser.com/how-to-change-spark-plug-in-a-lawnmower-example-briggs-stratton-engines-in-craftsman-and-murray-mowers/
Apr 16, 2010 | Poulan "" Push Mower
The self propeller stopped working on model 565,can you help?
Is it possible that the belt has come off or has broken? May have to take a shield off or look underneath. Be sure to use extreme care not to put hands under the mower unless the spark plug wire is disconnected.
Mar 07, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How do i change wheel height on lawn mower
Hope this helps
Apr 29, 2009 | Garden
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
