Question about Home Security
I have a 8ch lorex edge + everything was grate but now black picture view and recording, cameras working fine
    Problem Solver:
  • 5 Answers
This tends to happen When the camera tapes you pleasuring yourself, try Unplugging the camera And blow the back of it off and stick it back in..
Posted on Jul 15, 2013
  • sergiy klymenko Jul 17, 2013
    I tried blow it, and now only black picture, (cant see anything)
2 Suggested Answers
SOURCE: Would Uniden and Lorex cameras work together? I
I was wondering the same thing. Have you talked to Uniden or Lorex about this?
Posted on Feb 09, 2011
Why do my lorex cameras intermittently black out?
THIS COULD BE A FEW THINGS I CAN THINK OF
1ST ARE CAMERAS WIRELESS ? IF SO SOMETHING COULD COME ON INTERMITTANTLY AND BLOCK SIGNAL FROM GETTING TO BASE UNIT, IF THIS IS SO ONLY A SPECTRUM ANALIZER WILL BE ABLE TO TELL YOU WHAT IT IS .
SECOND IF NOT WIRELESS CK YOUR RECORD SETTINGS IN SETUP YOU MIGHT BE OVER TASKING HD DRIVE , VIDEO CAPTURE ONCE PER SECOND IS NORMAL ANY FASTER IS NOT NEEDED UNIT WON'T HOLD VIDEO IF HD IS BUSY WRITING SO IT DROPS SECONDS OFF FINAL RECORD
Jul 12, 2013 | Lorex Home Security
Lorex security camera
Coax from camera needs to feed vcr, at line in, line out from vcr goes to input of tv ie av1 av2 video in what have you. go that far and see if it makes sense.Then you can set vcr to record continuous and watch it at same time on tv or monitor.
May 14, 2017 | Lorex Home Security
Lorex-edge model no lh314 series will not record and beeps and says hdd is not installed
You need top open the top of the case by removing the screws and check to see if the hard drive is operating (it will be warm to the touch and may be making a slight noise). If the hard drive is not working, verify that it is plugged in. If the hard drive is bad, you can replace it with a SATA hard drive. The Lorex system will see the new hard drive and ask you to format it for use with the system.
Feb 02, 2013 | Lorex EDGE L314501C4 4-Channel Network...
I can't seem to remotely connect and view my lorex cameras. What am i doing wrong...it was working fine till I got Verizon FIOS
You may need to reopen the ports necessary for the Lorex to be available for remote viewing. You should be able to look at the function on the Lorex menu to get the port numbers, then call Verizon to have them forward the ports. Without port forwarding, your video stream is being blocked at the Verizon FIOS Modem.
Feb 01, 2013 | Lorex Home Security
Screen black. Everything else works perfectly.
To my understanding that you do not see live view in camera mode to record and camcorder playback old recorded tapes correctly and you get picture in LCD.
If it is true then please check lens cover that need to be slide down to get live view in camera mode. If problem still exist then 2 possibilities, either aperture in lens mechanism is bad or ccd imager is defective.
In that problem, camcorder needs qualified tech to fix it.
Let me know any further query.
Nov 03, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Black screen in shoot mode
The most common cause of this is a failed image sensor. Usually the playback mode will let you view pictures taken before the issue happened just fine and you will also be able to view the menu system just fine. When viewing the screen in an image taking mode, however, there is typically discolorations, horizontal or vertical lines, image bluring or distortions, or simply a black screen.
This situation, if caused by the image sensor, has to serviced and cannot be fixed by the user. If you are within your one year warranty and no user damage has been done to the camera, the camera will be fixed at no charge. If beyond the 12 month period however the customer may opt to have the unit repaired at a cost or take advantage of the Canon Loyalty Program and upgrade to refurbished S3 IS at an alternate discounted price.
Hope this helps.
Sincerely,
HeavyDLB
May 31, 2008 | Canon PowerShot S2 IS Digital Camera
Lens
No live view or black pictures, but readable menus means a bad CCD or less likely, possible shutter on cameras equipped with one (more scarce on newer digitals)
Apr 22, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Nikon S6- LCD screen black
I have The same problem with my S6, and was wondering if you found a solution? Ive done everything but contact Nikon or a camera shop.
Apr 16, 2007 | Nikon COOLPIX S6 Digital Camera
Home Security Logo
110 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
