Question about Jensen Awm970 Am Fm Cd Dvd Wall Mount Camper Trailer
Remove Power from Jensen?
Would like to remove power from my Jensen while camper is in storage to prevent from draining the battery. Is there some way to do this other can remove a fuse or disconnect the battery?
2 Suggested Answers
jjbrown1523089
  • 36 Answers
SOURCE: Why does my Jensen TV keep looping?
try leaving off for about 15 minutes then turn back on may have a button battery for mrmory if so will need to remove for a couple minutes hand
Posted on Jun 28, 2014
Testimonial: "James how do I know if it has a button battery?"
Hello, I have the Jensen Media Pro 5000. System worked fine in October before winter storage in a building. Pulled the camper out to use in June and the system failed to turn on. There was a blue l
This is a common fault to almost all systems during winter. some of them even won't power up too. Contact any service technician. The internal wiring connection/s should be checked for proper contact with its sockets. http://electronicshelponline.blogspot.com/
Nov 14, 2014 | Jensen New Original MEDIA PRO 5000 Remote...
Jun 28, 2014 | Jensen Televison & Video
How can I enable again the usb
Look for BIOS reset jumper on motherboard, power off machine, disconnect power, press power switch to drain any residual power and move the jumper if there is one, then move back. failing that remove the battery, leave for 10-15mins, put battery back and see if it resets.
May 01, 2014 | HEWLETT-PACKARD HP X1600 G2 12TB SATA...
Battery/elecrtic
You might unhook the battery and with the camper plugged in to shore power the 12v lights should work. If not check the breaker that goes to the inverter. If that is not tripped then check the power output at the converter. I would expect the inverter is shot. I replaced the one on my Jaco two years ago with (Progressive Dynamics 60 Amp Power Converter with Charge Wizard and the remote pendant)
Apr 02, 2014 | Jayco 2010 Jay Feather SPORT 165
My rear wiper on my 2003 chevy suburban 1500 stoped working and my battery is being drained
Hello the wiper motor axel is stucked by rust and the hole viper motor must be changed or renewed with a used/better one.
To prevent the battery from draining remove the multiplug connector from the rear viper engine.
(Remember to remove the negative cable from the battery)
When the viper motor is stucked the power circuit can`t close in position and this is why your battery is being drained for power.
Hope this will help you
Dec 17, 2012 | 2003 Chevrolet Suburban 1500
Why does my mp3 have a white screen
Remove any additional items in MP3. Such as micro memory stick and restart. Corrupt memory sticks cause this error. Also you could leave MP3 on and let power drain. Then recharge
Oct 01, 2012 | Jensen 2GB Flash MP3 Player SMPV-2GBUB -...
I have 3 power wires on my Jensen MCD5080 marine am/fm/cd, a +12dc switched (acc)red wire , dimmer orange wire and a +12v dc battery (constant batteryemory yellow wire) do i hook them all to the same power...
The yellow wire (constant) is for functions such as clocks, retaining fm stations, etc. The red wire (DC power) is what runs the unit. You said this is going on a golf cart right? But you say you don't want switches and don't want it to drain the battery during storage. Well, you can't have the best of both worlds. If you don't like the visual of a switch in the open, at least put one close to the battery under the seat. That way you can switch it off in storage. The switch would go to the red wire. You might even think about switching the orange wire if you expect to keep it in long term storage. the dimmer wire usually hooks to interior light controls. Like when you turn your lights on to drive at night, the radio won't be so bright inside, but in the day time, it will be. This is not a necessity. Happy wiring
Aug 15, 2011 | Car Audio & Video
POWER IS ON SCREEN IS BLANK. WE USE TO SEE JUST THE ARROW BUT NOW NOTHING!
This can be due to the accumulated static charge is preventing the notebook to power up. Therefore, please run the steps to drain this power. I have included the steps to do so.
Power drain process:
1. Shut the computer down.
2. Disconnect the AC adapter and remove the battery.
3. Press the power button down for about 30-60 seconds.
4. Reconnect the AC adapter and the battery.
5. Restart the computer
May 26, 2010 | HP Mini 1000 Netbook
Auxiliary battery use
The extra battery is there because of the glow plugs and intake heater of the duramax. During cold weather both of these systems draw high amperage from the batteries. A single battery will function, but not as well as a pair.
Apr 08, 2009 | 2005 GMC Sierra 2500HD 4WD
Jensen TV
Perhpas the TV has a timer function that is turning it on at a certain time. Does it seem to occuring at the same time of night? check the TV settings for a timer.
The only other possibility is that the camper is losing AC power in the middle of the night, and when the power comes back on perhaps the TV is turning on.
However, i rather suspect the first problem...
I am a certified RV technician, so if you have other problems with your camper please let me know
Sep 05, 2008 | Televison & Video
Jensen Awm970 Am Fm Cd Dvd Wall Mount Camper Trailer Logo
24 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
